Help! - hood and trunk release not activating...
Subscribe
Jun 6, 2010 | 12:49 PM
checked fuses - they are fine - any thoughts?
thanks!
Reply
Jun 6, 2010 | 01:15 PM
Do you have battery power? Did unlock the car with the remote?
Reply
Jun 6, 2010 | 01:18 PM
Quote: Do you have battery power? Did unlock the car with the remote?
yes - car started right up. When I wnt to check under engine cover - nothing from the switch, same for hood
Reply
Jun 6, 2010 | 01:22 PM
All the power that is supply to those switches comes from the alarm control unit. Do you have a durametric? Production year of your car? Did you hold the switches long enough until the hood pop-out?
Reply
Jun 6, 2010 | 08:16 PM
No Durametric
I did hold the switches but nothing... everything else works
oh - it is a 2002
Reply
Jun 6, 2010 | 08:23 PM
I think your alarm system is at fault because the triggering of the electrical hood release goes through the alarm control unit. If you got a tiptronic remove fuse #B8 and if you got a manual fuse# C3. Also look at the condition of that fuse. .. Just remove the fuse for 10 seconds and back on...
Reply
Jun 6, 2010 | 08:27 PM
Did you ever open the hood using the emergency release cable hidden under the right main headlight assembly?
Reply
Jun 6, 2010 | 08:31 PM
Also try locking/unlocking the door with your key (insert key into the lock). My key fob sometimes will not unlock / lock the doors, and if I do that, it resets it...
Reply
Jun 6, 2010 | 09:09 PM
Last suggestion before I go to bed. After you try what raineycd is suggesting. If you still have the same problem you can open the hood with a cable hidden under the right fender. You have to remove the plastic cover in front of the wheel and found a small metal cable. You pull on that cable to open the hood. After that disconnect the battery for a minute (you will need your radio code) and after try your switches again.... See dogdelta post to locate wire:https://www.6speedonline.com/forums/...pen-trunk.html
Reply
Jun 6, 2010 | 09:14 PM
thanks guys - will try these tomorrow
Reply
Jun 15, 2010 | 07:11 PM
UPDATE!
RODENTS!!!!
can you believe they actually got into the rocker panel
Reply
Jun 15, 2010 | 08:15 PM
Quote: UPDATE!
RODENTS!!!!
i see it alot. working on a 09 997 today with 4k miles and needs an engine harness already due to rats
Reply
Jun 16, 2010 | 02:43 AM
like always Jpflip to the rescue, rep for the doctor of 6speed!!!!
Reply
Nov 28, 2016 | 07:47 AM
pulled the seat out and checked the alarm ecu for water damage, found the 15 amp fuse on the box was blown, replaced and it all worked!
Working at a shop I've seen many many boxsters come in with critter damage. mice love to make a home on the oil cooler under the intake manifold haha
Reply
May 21, 2017 | 02:48 PM
Quote: I think your alarm system is at fault because the triggering of the electrical hood release goes through the alarm control unit. If you got a tiptronic remove fuse #B8 and if you got a manual fuse# C3. Also look at the condition of that fuse. .. Just remove the fuse for 10 seconds and back on...
Hello, I do have a 987 Cayman S, No power on the battery, and no reaction when clicking the front hood button.. Then I did open up at the front left wheel to unlock the hood using the emergency, but I was not able to release it. I gaveit a fair/hard tug grabbing it with a plier, but unfortunately no luck ...
Can the alarm system block the emergency release??
Any suggestions on what to do then?
| Mikael
Reply
