Brake fluid flush ahead of Track day suggestions
Super Blue / Motul / AP fluid are the options I'm looking at for my next Brake fluid flush in 2weeks. Car is stock except for flash/exhaust and doing my first track day 6-26 Infineon raceway. So getting the fluids changed ahead of time.
Considering I'm driving mostly street, stock brake pads/suspension what fluid would you sugest?
Thanks-
Thanks-
Thanks-
Thanks-
I have tried Motul and it also worked well....
Snap, same setup as me..
You can add Motul's fluids to that list also. Any of the higher temp fluids will make a significant safety difference, if you are flushing yourself switching to a blue one will make it easier to know when the flush is complete.
If you stick to your street pads for this event just make sure they are fairly fresh, they will wear like crazy if you brake hard. I switch out to PFC 97's (use to use Pagid Yellows) for the track, toss the pads when they reach 4mm of materiel thickness.
i've had great luck with regular prestone brake fluid from autozone in a pinch. it actually has a slightly higher dry boiling point than ATE, and you don't need to worry about wet BP if you change a couple times a year.
I'm sure someone will chime in with "i wouldn't put prestone in my Poursha," but I guarantee that someone has fewer track miles on ATE than I do on prestone.
I'm not slamming ATE, it's great fluid.
I hammer the brakes on my Car now. At first, I was worried about the Internet rumors regarding PCCB's, but after putting 14 hard track days on the brakes now, I have no qualms and am using them like I used to use my 15" Racing Red Brembos on my 944 Turbo.. The difference is that I don't get cracks in the PCCB's and I am getting better pad life as well... I am on my second set of P50's (Porsche Motorsports/Pagid Greens)..
So far, so good.
Cheers.
Cheers...
Is price a factor? I would not spend $48 on a bottle of SRF unless I am a track rat
I found a local shop that sells ATE Superblue and Motul RBF600 for about $17 a liter. They can be hard to find so to me it's more about availability if you are in a hurry. Tirerack seems to have good deal if you can wait 3 days.
FYI - ATE has superblue and a regular gold color version if you want to switch back and forth.
I have read DE instructors stating " I bleed my Brakes 1x per year with SRF ".. Thats why i am curious to try it.. Id like to know how long i can go before needing to bleed..
Mike
That's why I use SRF. This is my third season and I change it once a year before track season and never bleed the brakes ever. I've never had brake fade or other problems. To me it's a no-brainer. Some guys in my club are constantly bleeding their brakes with Superblue. They think they are saving money but by the end of the season they have used so many bottles of the stuff that the SRF is actually cheaper.
Mike
