Porsche Throttle body upgrade ?
Old Jun 15, 2010 | 01:20 PM
f1crazydriver's Avatar
f1crazydriver Is a GOD !f1crazydriver Is a GOD !f1crazydriver Is a GOD !f1crazydriver Is a GOD !f1crazydriver Is a GOD !f1crazydriver Is a GOD !f1crazydriver Is a GOD !f1crazydriver Is a GOD !f1crazydriver Is a GOD !f1crazydriver Is a GOD !f1crazydriver Is a GOD !
I know theirs a few dozen threads on throttle bodys. But is there any from Porsche that are bigger and straight bolt on ? I'm getting mine replaced at the dealer atm. So if someone can tell me asap. So I can get an upgrade that would be awesome.
TIA
Old Jun 15, 2010 | 01:34 PM
aroonkl's Avatar
aroonkl is a jewel in the rougharoonkl is a jewel in the rougharoonkl is a jewel in the rougharoonkl is a jewel in the rough
Enrique, it won't benefit much. Say throat is bigger but mouth and pipes is the same. Not much will fill in more.
And later if you go with big plenum, your new TB will be just a waste cause too small and won't fit.
Do it once & Do it right is the cheapest and less headache.
IPD 75mm, TB 75mm and 75mm Y-pipes.=
Ask me I was already in your shoes once.
TIA
Old Jun 15, 2010 | 03:08 PM
alex55's Avatar
alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !
the cayenne one
Old Jun 15, 2010 | 03:28 PM
MBailey's Avatar
TIA
I would get the 75mm throttle body and the 75mm IPD plenum. They will noticably help spool and top end power. There is also an 83mm TB and plenum but I dont think your car is heavily enough modified to benefit from extra size.
Old Jun 15, 2010 | 03:53 PM
robertp's Avatar
robertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud of
Be careful with this mod. Seems to be harder to tune and reliability is an issue.
Old Jun 15, 2010 | 04:11 PM
rdss's Avatar
rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !
Robert what is the problem the TB bigger cause for reliability ?? Thanks.
Old Jun 15, 2010 | 04:24 PM
LEave stock alone... we at 700 rwhp almost never upgrade it... no need...
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old Jun 15, 2010 | 04:35 PM
MBailey's Avatar
Enrique,
May be more info than you want, but here are some of my PBox plots before and after the 75mm TB/IPD Plenum mod. The red line is mph after the mod and the blue line is mph before mod. The green line is acceleration in gs after the mod and the black line is accel in gs before.
As you can see the mod gives faster spool and higher low range power. Power in the mid range is closer but still more after TB/plenum. There is also significantly more high range power. Overall the car goes 60-100 mph in 0.2s less after the mods. This is about a 6% improvement or roughly 30whp at this power level. The car was a GT700. Atmospheric conditions were essentially the same.
The TB/plenum were a PITA to install due to cramped work space but if you can lower engine a tad it is much more accessable. I have experianced no reliability problems.
If you cant see graph well enough, download it and magnify it in PS or similar photography app...
Old Jun 15, 2010 | 04:46 PM
Not going to knock it because I have one myself... are you talking about the TB upgrade or the Tb and some plenum? if thats the case then the figures you mentioned are not really due to just the bigger TB...
Also, your set up may have done it but that does not mean someone with stock injectors, 18gs for example, will also add 30rwhp....
If we start adding HP based on parts added then what if I add the plenum to the turbos( 30rwhp) then the headers, (15rwhp) then catless 3" exhaust(15rwhp), then bigger hoses and Y pipe( another 30rwhp).. you soon will end up with a 800rwhp but in reality its 650 lets say....
Dont get me wrong I have all the bells and whistles on my car... and I cant get 30rwhp more just by swapping TBs... but in your case I think your talking about the complete TB and splitter..... and will that help? sure.. but differently on each car...
I would rather put that $1600 into a turbo upgrade then the TB... but thats just me...
BTW, not disputing your findings... I just have my own view based on experience on a handful of builds... including my own...
9.66
click to view
Old Jun 15, 2010 | 05:06 PM
MBailey's Avatar
I agree with you Mark...
My results are with both the TB and the plenum. I think if Enrique is going to do the TB he should also do the plenum since the stock unit is a disgrace for such a fine car.
I agree that its easier and cheaper just to slap big turbos on the car and force the air through smaller passages. However, I wanted to keep the small turbos on my car because I liked how it drove on the street.
Sure his results will likely vary from mine since his car presumably has fewer mods.
Old Jun 15, 2010 | 06:06 PM
Prche951's Avatar
the voice of reason...$1600+ labor to maybe gain 30 whp
I have been considering this mod, but if I do it, it will be the vivid version for half the price, not the ipd.
Old Jun 15, 2010 | 06:16 PM
My car is in for warranty work. I'm going to pay out of pocket for price difference between lets say a stcok tb and the cayenne. But their seems to be mixed results on this.
I only have a flash and by pass pipes. Anyways, thanks guys, keep the opinions comming. I really appreciate the post with lots of information.
Old Jun 15, 2010 | 06:17 PM
I mean if you have the money its great.. but most guys are very cost conscious... with that said, I rather put that money into the plenum that goes from the airbox to the turbos... vs the TB/Splitter... but thats just me...
OR, put the extra money into a good set of turbos... so lets say you have 4K but for $5600 you can get so much more turbo... I would get the turbo... assuming all other basic power adders are in place...
9.66
click to view
Old Jun 15, 2010 | 06:23 PM
Powell's Avatar
Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !
I make 868rwhp on stock TB and plenum. I wonder how much I'd pick up with one!
Old Jun 15, 2010 | 06:50 PM
robertp's Avatar
This is my kind of tune. I would not change any piping.
