i want to go low 11's in a 1/4 mile
https://www.6speedonline.com/forums/...p-capable.html
Not going to be that easy... be it a a turbo A or turbo B...
there are too many variable that need to be under control... one is clutch... two is intercoolers and piping, three is injectors, four is a exhaust that will NOt pass emission in Cali, five a custom tune with NO 91 octane unless you want to blow up your car at 1.6 bar... so RACE gas only....
Then we go to:
weight reduction, tires tires tires, RWD conversion, and finally a kick *** driver...
Good luck can't wait to hear your results...
markski
Then we go to:
markski
2001 996TT 3.6L and stock ECU
there are more factors than just hp that equates to a low ET. I used to be an ET junkie but now focus more on trap speed and 60-130 times as its more of indicator of how much HP you are making.
i guess i'm looking to make 130-135 mph pass. i ran an 11.42 with my stage 3 s4 at 126mph so i'm basing it of of that. that was with a 1.6 sixty foot. that car only made 426 hp to the wheels on c16. i guess i just want to know if i should go big turbos to achieve that 10.90 goal. i already have an EP exhaust and will upgrade the clutch and intercoolers as soon as i decide which turbo kit to go with
this is a different ball game...
Clutch and tires are going to be huge factors in getting a good time. The power levels should be good for very low 11s, eveyrthing else is going to depend on whether you can get it down the track that fast.
#TeamAIM
#TeamAIM
Bit of advice to the OP. keep your expectations low. Despite the fact that these cars would SEEM to be quite the ET monster, they are a bear to drive at the dragstrip. And the AWD is the crappiest AWD ever installed on a car. You'll have much better luck RWD. Clutch is a HUGE factor in how it holds and actuates...
Here is an example of what you desire...My car runs consistent low 11's (11.1-11.3) with a best of 11.0 and traps 131-133mph with K24/18G turbos, SpeedTech exhaust, 75mm throttle body/plenum, SpeedTech full 75mm Y-Pipe kit, 60 Lb. injectors, dual fuel pumps, EVO turbo inlet pipes, B6 IC's, AWD, street tires, full weight at 1.2 bar. I now have a 1.32 bar program and the car actually feels quite a bit faster, but I have not taken it to the track yet with this most recent tune.
991.2 Turbo S GT Silver
991.2 GT3 Chalk (Manual)
2022 Cayenne White
www.speedtechexhausts.com
info@speedtechexhausts.com
2022 Cayenne White
