Clutch recommendations
Old Jan 28, 2005 | 08:45 AM
BCS996TT's Avatar
BCS996TT is infamous around these parts
Well, closing in on 29K miles (of which 25k have been modified ), and the clutch is starting to slip.
Given the hard driving and power the car is putting down, im surprised the stock clutch lasted this long.
With that said, what type of clutch do you guys recommend? I think it would be smart to upgrade to a stronger clutch, but I definitely dont want it to be super stiff as I drive my car often. Is there a stronger than stock clutch with stock feel available? If so, where can I get it and approx how much?
Thanks.
Old Jan 28, 2005 | 10:34 AM
OKHJOON190's Avatar
OKHJOON190 is infamous around these parts
i second that question
Old Jan 28, 2005 | 11:59 AM
KPV's Avatar
KPV
Third.
Old Jan 28, 2005 | 12:12 PM
Erik@Cargraphic's Avatar
Erik@Cargraphic is infamous around these parts
We sell a single mass cluthch kit, consists of lightweight flywheel, HD pressure plate & disk, T.O. bearing and all related hardware. I believe sachs manufacturers it. It is supposed to be good for 700+HP. Unlike a lot of HD clutches, it has a super light pedal.
Hershel uses it in his TT as well as all the TT's Cargrqaphic Gmbh & RS tuning builds.
Hope this helps
Erik
Old Jan 28, 2005 | 12:37 PM
OKHJOON190's Avatar
it needs to be able to handle my stick driving ... which sucks. I think i am the king of burning clutches. any other suggestions?
Old Jan 30, 2005 | 12:38 PM
45otto's Avatar
Kills Bugs Fast
45otto is infamous around these parts
***bump***
Come on, some of you must of some experience on this?
Old Jan 30, 2005 | 02:02 PM
jcramair1's Avatar
jcramair1 is infamous around these parts
I went with a Sachs clutch from Todd at EVO. I didn't need to go with it as I had little miles...but with moving to stage 4gt he recommended it. I've had no complaints with it at all.
Old Jan 30, 2005 | 02:16 PM
Orli930's Avatar
Orli930 is infamous around these parts
Go with the SACHS
Old Jan 30, 2005 | 04:21 PM
1999Porsche911's Avatar
1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future
If you're going through a clutch in 29K miles, better look into a TIP or learn to drive with a clutch properly.
Old Jan 31, 2005 | 06:53 AM
jayster's Avatar
jayster is infamous around these parts
clutches
I'd suggest Sachs Engineering clutch and LW fly, if you dont mind the gear rattle at idle. Hence the dual mass, 29k on a stock clutch is not bad , if you dont want to deal with the noise stick with the DM fly.
TIP: do the entire clutch including flywheel
and ring gear bolts as well as the guide sleeve, no matter which way you decide to go. Jay Putnam
Old Jan 31, 2005 | 08:31 AM
45otto's Avatar
Kills Bugs Fast
Thanks for the info...
Old Jan 31, 2005 | 05:05 PM
BCS996TT's Avatar
let's see... over 600HP on a stock clutch....the car has been modified for over 25K miles. I drive the car as often as I can and get on the boost throughout my 40 mile roundtrip commute...nevermind the number of meets, races (he he), etc.
If you didnt already know, that's going to put a lot of stess on a stock clutch.
Sure I could get 50K miles on the stock clutch.... if I drove like my grandmother
...there are many guys with 600+HP turbos who've gone through their clutch in less than 10K miles. I guess they dont know how to drive as well.
Old Jan 31, 2005 | 07:47 PM
olslategray's Avatar
olslategray is infamous around these parts
When I did the mods on my TT, I had to upgrade the clutch. When I went to boost the original clutch slipped. I also did the Sachs lightweight sports clutch kit. It cost around $2200. I love it. Not slipping. Yes it does have a rattle when in neutral but it is not that bad.
Old Jan 31, 2005 | 11:05 PM
mpwrmodena's Avatar
mpwrmodena is infamous around these parts
30k miles on moded car is actually alot of miles. I have a 920whp supra and I replace the clutch every 2 k miles (lots of drag racing). If your not good at driving Stick a light weight flywheel might not be great for you. Since there isnt alot of mass to the unit it will stop spinning when you stop at a light. Most of the time to get a smooth take off you must pump it 1 time to get it spinning before engaging into gear. Also You might notice a slight chatter since there is no damper in the flywheel. It like when you hit a metal bat on a wall and the virations travle down your arm. This is what it sends down the whole tranny. This might not be the case on 996 turbos but everyother car thats the case.
Old Jan 31, 2005 | 11:30 PM
PMac's Avatar
PMac is a splendid one to beholdPMac is a splendid one to beholdPMac is a splendid one to beholdPMac is a splendid one to beholdPMac is a splendid one to beholdPMac is a splendid one to behold
I don't know - the 996 clutch is the notorious weak point in the drive train. Generally speaking, most people seem to be getting around 40k from a clutch in a stock vehicle, assuming no drag racing, and normal driving techniques.
Throw a couple hundred extra horsepower, and I wouldn't be surprised if you get a little less life.
My last 911 went out at 38k miles, and I don't do drop-clutch launches, rarely launch over 1000rpm, and rev-match/heel'n'toe every downshift. And I don't ride the clutch either.
Given the alternatives (broken shafts etc.) I'll take a weak clutch as a compromise.
jaehoppa
Oct 22, 2015 09:17 PM
ship it
Sep 7, 2015 10:49 AM
falter
964 Turbo
Sep 4, 2015 01:41 PM
falter
964 Turbo
Sep 4, 2015 01:37 PM
ECS Tuning - VW
Sep 3, 2015 09:43 AM
