Engine/Trans Removal DIY
Old Jun 24, 2010 | 10:37 AM
Frank ( Sunnyside )'s Avatar
Frank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond repute
Originally Posted by BigBadBen
I did this last September in my garage...it's not a bad job. Pulling it is easy, putting it back in is the harder part
What prob's did you have putting it back in . Please tell. Nothing to serious I hope??
Old Jun 24, 2010 | 10:41 AM
jpflip's Avatar
The difficulty we encounter Pumalex and I was really with the clutch fork
Old Jun 24, 2010 | 10:46 AM
BigBadBen's Avatar
BigBadBen Is a GOD !BigBadBen Is a GOD !BigBadBen Is a GOD !BigBadBen Is a GOD !BigBadBen Is a GOD !BigBadBen Is a GOD !BigBadBen Is a GOD !BigBadBen Is a GOD !BigBadBen Is a GOD !BigBadBen Is a GOD !BigBadBen Is a GOD !
It's just a PITA lining everything up and sliding it back in properly. You have to be perfectly lined up or it will just bind up. The motor is obviously tilted down at the tranny end to slide the tranny out.
Then the other fun part is putting the clutch fork pin in. You have to bear hug the tranny from both sides and wiggle the clutch fork a tad to get the pin in. I use the 993 clutch fork pin as that part does not have the pin bearings which tend to fall off if you mess around too much putting it in.
Once the pin is back in it's easy after that.
Old Jun 24, 2010 | 01:25 PM
Thumbs up
Phew, I thought with all that talk of hugging the tranny and wiggles and crutches sorry clutches ... I didn't know where the topic was heading.
Its a good thing to know though. I have a Tip, so I'm sure there must be even more snags and problems to learn about. But as to the general principal... Good one. Cheers for the info.
Frank.
DLF
Cayenne 955/957
10
Feb 28, 2022 11:49 PM
markj
911
Apr 7, 2016 05:44 PM
AM v12v
Sep 7, 2015 02:17 PM
Wildcat1212
Sep 7, 2015 11:31 AM
