Passing Emissions with no cats exhaust??
Old Jul 9, 2010 | 02:22 PM
TurboTodd's Avatar
TurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond repute
In some states if you get collector plates you don't have to do the test. Might want to check into it for your state.
Old Jul 9, 2010 | 04:03 PM
ard's Avatar
ard
Originally Posted by johnselli
2. I've heard of the 2nd gear tranny pop out issue. Is that a fairly isolated problem and is it only confined to the 01 and 02 996tt? I was told the tranny in an 03 has upgraded brass synchros vs. steel in the 01 and 02 and that corrected the problem.
Thanks......
Not ture- can affect all years... There was an assembly DEFECT in the early trannies that contributed to this issue, but the overwhelming number of '2nd gear pop out issues' are not this defect but rather missed shifts grinding the gear down and not enough retention force to hold them in...
The brass vs steel is also not true. ALL years it is brass. (at least for standard TT and X50)
Originally Posted by RickEager@***.n
I also heard 100 cell cats won't pass in Cali. Is this true???
"100 cell Cats" is not "one thing"... what that means is one company's 100 cell cat may pass (ie Europipe at $900 each) while another company's 100 cell cat might fail (ie not naming names)
A
Old Jul 9, 2010 | 05:22 PM
RickEager's Avatar
RickEager has a reputation beyond reputeRickEager has a reputation beyond reputeRickEager has a reputation beyond reputeRickEager has a reputation beyond reputeRickEager has a reputation beyond reputeRickEager has a reputation beyond reputeRickEager has a reputation beyond reputeRickEager has a reputation beyond reputeRickEager has a reputation beyond reputeRickEager has a reputation beyond reputeRickEager has a reputation beyond repute
Originally Posted by ard
"100 cell Cats" is not "one thing"... what that means is one company's 100 cell cat may pass (ie Europipe at $900 each) while another company's 100 cell cat might fail (ie not naming names) A
Anybody in Cali running 100 cell Fabspeed cats... and pass emissions???
Old Mar 25, 2013 | 12:15 PM
enoyskt's Avatar
enoyskt is a splendid one to beholdenoyskt is a splendid one to beholdenoyskt is a splendid one to beholdenoyskt is a splendid one to beholdenoyskt is a splendid one to beholdenoyskt is a splendid one to behold
Some how I was able to pass smog with no cats.. lol, weird but true.
I took it to the place and said give it a test to see and I passed.
Old Mar 25, 2013 | 12:49 PM
'02996ttx50's Avatar
i have found a critical step that is necessary to pass smog, and it has to do with all the "readiness" codes. if the car is modded ( exhaust/tune ) whatever. it's a good idea to ensure all your obd codes are set to "ready" or they won't pass the obd section of the test. same with any cel having been turned off recently. if that is the case, you'll have to "reset" the codes to ready by driving in the prescribed fashion to "reset" the codes. then the car will pass provided no other issues exist, of course. if they are not "ready" you'll fail regardless of the results of the actual test/ sniffer or otherwise.
i just went through this and it took me two days of f****ng with it to get the codes to ready without throwing another cel. ( i get cels occasionally and i think it's a tb issue ). so once they set to ready there i was, unwilling to turn off the car untill they re-tested it. i was in fact not willing to leave without a "Pass"
Old Mar 25, 2013 | 01:08 PM
unvmy996's Avatar
You do realize this thread is 3 years old right,
Jun 10, 2017 07:45 PM
jyupitt1
Sep 23, 2015 06:26 AM
km90265
Aug 31, 2015 11:00 AM
bmwtmx
Aug 26, 2015 07:26 AM
