Techart springs
Old Oct 3, 2003 | 04:40 AM
SuperDarius996T's Avatar
SuperDarius996T is infamous around these parts
Techart springs
Hi guys
I'm interested in lowering my car,but not spend a lot of money with a complete set of spring and absorber....
I ask you if someone tried the Techart sport spring with stock 996 Turbo absorber.(Techart said this springs are Eilbach spring with special setting for stock absorber..)...and if is a good compromise and the car's andling good...
I take my car on track 4/5 times for year not much....
Thanks for help
Ciao
Dario
Old Oct 3, 2003 | 06:25 AM
buddyg's Avatar
Hi,
I just put on fully adjustable coil over KW suspension and I like it alot! You can adjust both rebound and combression as well as ride height.
Old Oct 3, 2003 | 07:07 AM
maxwell's Avatar
maxwell is a jewel in the roughmaxwell is a jewel in the roughmaxwell is a jewel in the rough
Darius,
I've had the Techart springs on my car with the stock absorbers for about 2 years now. It's great. It lowers the car 30mm and gives it a nice firm ride. It's not as good as a full coilover system, but depending on how you drive, you might not need that.
Old Oct 3, 2003 | 09:04 AM
luting_chen's Avatar
luting_chen is infamous around these parts
buddyg...^___^ is it KW V3?????
Old Oct 3, 2003 | 09:29 AM
buddyg's Avatar
Correct!
Old Oct 3, 2003 | 10:28 AM
Colin@PES's Avatar
Colin@PES is infamous around these parts
KW suspensions Variant #3 This is an excellent setup for street or track. The V3 system is adjustable for rebound and compression SEPERATELY. (that is a very key point as one of the other popular coil over systems does not allow seperate adjustment you raise one and lower the other. Not very logical but hey) They are also finished in a stainless steel shock body so corrosion that usually takes places on coil overs in non-existent on these. The KW V3 equipped 911's posted the fastest lap times of tall the 911's @ the 24 hr race @ "the ring" (nurburgring) So this system is for real. As a result of all of the available adjustment they are able to be tailored for the street or to a full blown track style suspension for D/E or lapping days. Call me @ 877-697-1688 if you have any questions about them. The cost on the system is $4000-$5000 depending on your needs.. One last not the KW V3 system uses a remote resevoir for the fluid in the shock, this helps to keep a certain amount in reserve and aslo to keep the fluid cooler allowing it to flow at a specified rate for a longer period of time (i.e. not turning to a frothy foam after alot of motion).
Colin Miller
www.pes-tuning.com
267-288-0161
877-697-1688
Colin Miller
www.pes-tuning.com
Old Oct 3, 2003 | 11:15 AM
msindi's Avatar
I had H&R springs on my 01TT with everything else stock and found the car to sit a bit too low for BOston ****ty roads and the ride was really rough!!
Old Oct 4, 2003 | 05:04 AM
Guys...thanks for help!!!!!
Monday i order the sring from Techart...
Ciaooo
DArio
Old Oct 4, 2003 | 08:56 AM
cjv's Avatar
cjv
Moderator
I saw on The Racers Group website the JRZ triple adjustable's are on sale for the first time ever, 20-25% off retail.
socalbreeze
Nov 14, 2015 11:09 AM
ELMEL
Sep 28, 2015 01:12 PM
Mico
Sep 26, 2015 03:04 AM
HIGHcard
Sep 24, 2015 08:09 PM
ModBargains
Sep 12, 2015 12:55 PM
