ECU fault codes
Old Aug 6, 2010 | 09:13 AM
jalmood's Avatar
jalmood has a spectacular aura aboutjalmood has a spectacular aura aboutjalmood has a spectacular aura about
ECU fault codes
Can anyone please tell me whats the cause of these codes:
P1101 fault code 594 input variables charge measurment.
P1249 fault code 231 boost pressure deviation below limit
Old Aug 6, 2010 | 10:28 AM
GTstreet996's Avatar
GTstreet996 Is a GOD !GTstreet996 Is a GOD !GTstreet996 Is a GOD !GTstreet996 Is a GOD !GTstreet996 Is a GOD !GTstreet996 Is a GOD !GTstreet996 Is a GOD !GTstreet996 Is a GOD !GTstreet996 Is a GOD !GTstreet996 Is a GOD !GTstreet996 Is a GOD !
594 input variable charge is p1109. Ask me how I know
Old Aug 6, 2010 | 10:34 AM
jalmood's Avatar
Originally Posted by TwnTurboJ
594 input variable charge is p1109. Ask me ow I know
Whats the cause of it?
Old Aug 6, 2010 | 11:06 AM
FAST FWD's Avatar
FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !
Here are the relevant manual pages. Several possibilities suggested, although the one common to both codes is problems at the intake/throttle body. Weren't you the guy who had all sorts of problems with the AP intake kit?
Jon
File Type: pdf
File Type: pdf
Old Aug 6, 2010 | 11:18 AM
jalmood's Avatar
Jon
Yes thats me, thanks for the attachment.
Old Aug 6, 2010 | 11:19 AM
ttboost's Avatar
Still sounds like a bad leak. Boost leak test and/or smoke test. Use a higher pressure like 30psi or so...
BLKMGK
May 31, 2016 04:32 AM
DLF
Cayenne Turbo
Oct 24, 2015 11:27 AM
Lucid Moment
Sep 12, 2015 01:12 PM
Yogi911
Sep 9, 2015 08:20 PM
Nuke
Sep 8, 2015 09:09 AM
