techarts spacer questions
Old Aug 7, 2010 | 08:52 AM
pwengland's Avatar
pwengland is infamous around these parts
Just had my first flat tyre tonight and realised my spare wont go on becuase the car has spacers on the rear.. couldnt get the spacers off with the limited leverage I had on the side of the road and the car on the jack. Wheels are techart formulas 19. The car looks good with the spacers on, but the rear tyres are rubbing (and Im not game to have a malaysian panel beater have a crack at rolling the guards). Car currently has no spacers on the front and 18mm on the back. Rear tyres are 295/30 19s pzeros. Dont know any details on the wheel offset. So my question is can I take the spacers off. Any help would be appreciated
Old Aug 7, 2010 | 09:16 AM
Page's Avatar
Page is a glorious beacon of lightPage is a glorious beacon of lightPage is a glorious beacon of lightPage is a glorious beacon of lightPage is a glorious beacon of lightPage is a glorious beacon of light
You should be able to take the spacers off. You might need a bit more effort. I'm sure they're a bit stuck on with mother nature causing it to adhere to your hub. Also they were probably a snug fit installed.
You might have to bang around them with a rubber mallet and then try to pry them off little by little by going around them. A screw driver would probably mar them if they are aluminum. Maybe use some sort of wooden handle and use that to bang with the hammer around the spacer.
Once you get them off you might want to clean off any oxidation off the rotor hub. Also on mine I had to sand the opening of the spacers so it was more of a looser fit. The rears on mine were tight to get on.
Old Aug 7, 2010 | 04:19 PM
GreggT's Avatar
GreggT is a splendid one to beholdGreggT is a splendid one to beholdGreggT is a splendid one to beholdGreggT is a splendid one to beholdGreggT is a splendid one to beholdGreggT is a splendid one to beholdGreggT is a splendid one to behold
Pretty car.
Yep....as mentioned, spacers can need a good wack if they have not been off in a while.
Looks like the car is lowered.....unless you set yourself up with a very firm suspension you will continue to have rubbing in the rear (possibly even if you go the w/ fender prep route).
Logical solution is get a set of 12mm (or whatever) for rear after you successfully get those 18s off. Car will still look great....only you will know about the 6mm.
Old Aug 7, 2010 | 05:35 PM
pwengland's Avatar
thanks for the thoughts. What I was really wondering though is whether you think I can run these wheels without the spacers at all.. Im not keen on the idea of not being able to use the spare tire, plus with a bit of luck it would stop the rubbing
Old Aug 7, 2010 | 05:45 PM
GreggT's Avatar
Sure.....go for it.
18mm isn't even 3/4 inch...your car would still look great.
Old Aug 7, 2010 | 05:58 PM
MY996TT's Avatar
MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !
Just go with smaller spacer. I had 15mm and rubbed a little when I went thru dips; went to 13mm and no rub now... and still looks good IMO.
Old Aug 8, 2010 | 02:42 AM
pwengland's Avatar
All, thanks for the views.. just had them taken off the car. Verdict, it doesnt look as cool, but no scraping and if I get a flat again at least I can use the spare... will stick with this for now and maybe entertain myself with a purchase of some slimmer ones later..
Old Aug 8, 2010 | 03:31 PM
LiNks's Avatar
LiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond repute
I thought Tech Art wheels came with a much more aggressive offset in the rear, I thought +29 to be exact (that would mean no spacer). Do you have Tech Arts for a narrow body, or are these just not as aggressive?
Old Aug 9, 2010 | 07:24 AM
pwengland's Avatar
just discovered they are only 10 inch rims (put on by previous owner)... !!! Unfortunately in Malaysia these things are a bit hit and miss... anyway will stick with them for now and change somewhere down the track
3WDistributing
31
Oct 27, 2017 01:26 PM
Aug 21, 2015 06:34 AM
PelicanParts.com
Aug 18, 2015 03:51 PM
PelicanParts.com
GT3/GT2/GT Vendor Classifieds
Aug 18, 2015 03:42 PM
