help please....jacking the rear
Old Feb 15, 2005 | 10:13 PM
collin996tt's Avatar
Senior Member
collin996tt is infamous around these parts
i want those formula one built-in jacks, easier for dialing the pss-9's.
Old Feb 16, 2005 | 06:14 AM
Scott in H-town's Avatar
Pioneer Member
Scott in H-town has a reputation beyond reputeScott in H-town has a reputation beyond reputeScott in H-town has a reputation beyond reputeScott in H-town has a reputation beyond reputeScott in H-town has a reputation beyond reputeScott in H-town has a reputation beyond reputeScott in H-town has a reputation beyond reputeScott in H-town has a reputation beyond reputeScott in H-town has a reputation beyond reputeScott in H-town has a reputation beyond reputeScott in H-town has a reputation beyond repute
Originally posted by GreggT
Well, please try to re-read Porsche-Tech's post.
He is using the jack points (to support left & right jack stands)........but it's a tad tough to both jack & stand at one point at the same time.....that's why the engine case lift is a good short cut. If you don't have a good (low-rise) jack to do that, you can use the method of jacking right front (at the jacking point) high enough to set jack stand under the right rear........but the the engine shortcut is better/easier (and for low cars, this is often the method shops also use).
I got it the first time. I just want to see a picture of how to jack it up w/o using the jacking points to lift the car in the first place.
Basically, I don't trust myself to choose the right point w/o seeing a picture to compare it to.
Old Feb 16, 2005 | 07:52 AM
NC Bob's Avatar
NC Bob is infamous around these parts
Pep Boys sells ramps for $50. I use them all the time and trust them a lot more than jack stands.
Old Feb 17, 2005 | 06:46 AM
Pioneer Member
True on the ramps, but for things like brake work, that's not an option.
Old Feb 17, 2005 | 08:40 AM
Senior Member
jacks are too cumbersome and not earth quake proof. i just slide an air mattress underneath the car and inflate it. works like a charm.
Old Feb 17, 2005 | 10:19 AM
Redlinerobert's Avatar
Senior Member
Redlinerobert has a reputation beyond reputeRedlinerobert has a reputation beyond reputeRedlinerobert has a reputation beyond reputeRedlinerobert has a reputation beyond reputeRedlinerobert has a reputation beyond reputeRedlinerobert has a reputation beyond reputeRedlinerobert has a reputation beyond reputeRedlinerobert has a reputation beyond reputeRedlinerobert has a reputation beyond reputeRedlinerobert has a reputation beyond reputeRedlinerobert has a reputation beyond repute
I'd like to see a pic of the contact point for the jack under the car as well.
Old Feb 21, 2005 | 02:27 PM
2kuhl's Avatar
2kuhl is infamous around these parts
That was easy
Following the instructions provided on the Imaginauto.com website, I was able to remove the stock exhaust in about 1.5 hours. I put the jack in the middle of the engine with the wood block like everyone said and it was a piece of cake.
Now, just need to find some time to get the Fabspeed installed. Probably another 10 days before I have a chance to get to it with business and travel. At least its 40 and raining out so not like I'm in a big hurry.
Any comments on how easy it is to get all the sensor cables back into the proper retaining clips?
Also have clear side markers on order and will send my rear bumperettes to Eric and have them painted to match the car. By spring, I'll be stylin'.
Thanks for all the help.
AJUSA.com
997 Vendor Classifieds
Oct 8, 2015 05:50 PM
orbelo
Aug 30, 2015 12:26 PM
gulf gt
Aug 27, 2015 10:27 AM
The Oss
Aug 24, 2015 08:19 PM
Zero911
Aug 24, 2015 06:51 PM
