How to disassemble headlights?
Old Aug 22, 2010 | 01:03 PM
GMendoza's Avatar
GMendoza is a glorious beacon of lightGMendoza is a glorious beacon of lightGMendoza is a glorious beacon of lightGMendoza is a glorious beacon of lightGMendoza is a glorious beacon of lightGMendoza is a glorious beacon of light
I'm having an issue with my headlight turning off. I tracked the problem down to a lose connection between pin #12 and the wiring inside the headlight. Rather than just splicing the wires to a good ground (#3), I would rather get behind the plug to find the problem.
Does anyone know how to take apart the headlight assembly?
Old Aug 22, 2010 | 01:37 PM
NOLA911's Avatar
NOLA911 Is a GOD !NOLA911 Is a GOD !NOLA911 Is a GOD !NOLA911 Is a GOD !NOLA911 Is a GOD !NOLA911 Is a GOD !NOLA911 Is a GOD !NOLA911 Is a GOD !NOLA911 Is a GOD !NOLA911 Is a GOD !NOLA911 Is a GOD !
You don't want to do it. I have taken apart the headlights on 4 of my cars to paint the reflector and chrome trim black. The porsche light was by far the worst.
If you want to brave it anyway, take the allen bolts out from the rear of the light and heat your oven to 500 degrees. Bake the light for 5-10 minutes, or until the glue holding the lense on the carrier starts to melt. Take a heat gun and work the glue while you pry the lens off. That's basically it, but you will find that it's really not that easy with the glue they used and the shape of our lights.
Old Aug 22, 2010 | 04:46 PM
GMendoza's Avatar
You are right. That's not something I want to do. lol
I would like to move somethings out of the way to see if I can get a better view. How does the connector for the flaper (under the low beam) come out?
Old Aug 22, 2010 | 08:07 PM
NOLA911's Avatar
I really dont remember how the back works out. I had one goal in mind and that was to remove the lense.
DYL 911
Oct 20, 2025 05:08 PM
adnanm3
Oct 25, 2016 08:38 AM
Perkman87
Nov 19, 2015 05:31 PM
Needsdecaf
Cayenne 958
10
Oct 12, 2015 03:05 AM
ECS Tuning - BMW
Sep 29, 2015 01:18 PM
