Need help quickly!
Old Aug 25, 2010 | 08:33 AM
007-911's Avatar
007-911 has much to be proud of007-911 has much to be proud of007-911 has much to be proud of007-911 has much to be proud of007-911 has much to be proud of007-911 has much to be proud of007-911 has much to be proud of007-911 has much to be proud of007-911 has much to be proud of
Need help quickly!
Working on installing rear intake pipeing and lowering the motor. I took out the engine mounts and the motor didnt budge an inch. I had a jack under the car the jack lowered but not the motor. Does any one have a DIY? Is tip cars different?
Vince
Old Aug 25, 2010 | 09:11 AM
BlackHorseTurbo's Avatar
BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !
Did you remove the tranny mount?
Vince
Old Aug 25, 2010 | 09:17 AM
007-911's Avatar
no whee is that at?
Old Aug 25, 2010 | 09:24 AM
bimmer81's Avatar
bimmer81 is a splendid one to beholdbimmer81 is a splendid one to beholdbimmer81 is a splendid one to beholdbimmer81 is a splendid one to beholdbimmer81 is a splendid one to beholdbimmer81 is a splendid one to beholdbimmer81 is a splendid one to behold
Thats weird, all i did was remove the 2 bolts for the motormounts and it should lower about 4 inches at most with a jack holding the motor.
here is a pick of my worn out one.
Old Aug 25, 2010 | 09:28 AM
007-911's Avatar
my wrench is saying that you have to remove a bunch of stuff to get to it. Do you have a diy or is the mount just covered by the panal?
Old Aug 25, 2010 | 09:39 AM
Brad Bedell's Avatar
Brad Bedell is a splendid one to beholdBrad Bedell is a splendid one to beholdBrad Bedell is a splendid one to beholdBrad Bedell is a splendid one to beholdBrad Bedell is a splendid one to beholdBrad Bedell is a splendid one to beholdBrad Bedell is a splendid one to beholdBrad Bedell is a splendid one to behold
Wow! Are most tips that way? I get a bit of a drive-line vibration on heavy acceleration. I suspect this mount is the issue.
In the MR2 world, we used a two part urethane mix to fill in the 'voids' for these mounts. Judging from the looks of it, that could/would be a good and inexpensive fix.
Old Aug 25, 2010 | 09:41 AM
OS Inspector's Avatar
OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !
cheap way is 3m Window weld but is it ever messy
Old Aug 25, 2010 | 09:45 AM
007-911's Avatar
So no one has a DIY for this?
Old Aug 25, 2010 | 09:49 AM
This happened on the 4th lap at MSR during my one and only road course stint (16/16g's).
Old Aug 25, 2010 | 09:52 AM
Oh yes it is. But can be made to look nice with a piece of cardboard and mold release agent sprayed on it.
bad107's Avatar
bad107 has a reputation beyond reputebad107 has a reputation beyond reputebad107 has a reputation beyond reputebad107 has a reputation beyond reputebad107 has a reputation beyond reputebad107 has a reputation beyond reputebad107 has a reputation beyond reputebad107 has a reputation beyond reputebad107 has a reputation beyond reputebad107 has a reputation beyond reputebad107 has a reputation beyond repute
Your torque must have been going crazy that day! You were running MS109 at high boost right?
Old Aug 25, 2010 | 09:57 AM
Have you removed the cables and hoses? Something is still holding you up..
Old Aug 25, 2010 | 09:59 AM
I was running 1.3 bar. 550 "ish" lbs of torque. I cooked the ATF and overheated. The trans literally stopped working eventually. I had to let it cool completely before I drove her home.
Old Aug 25, 2010 | 01:18 PM
frankster's Avatar
frankster is a name known to allfrankster is a name known to allfrankster is a name known to allfrankster is a name known to allfrankster is a name known to allfrankster is a name known to all
no where is that at?
Oh boy . . . this is gonna be good. Get the camera ready, here's one for the FAIL BLOG!
