PSS10 install today - quick question
Old Sep 2, 2010 | 07:37 AM
tws_andrew's Avatar
tws_andrew is a name known to alltws_andrew is a name known to alltws_andrew is a name known to alltws_andrew is a name known to alltws_andrew is a name known to alltws_andrew is a name known to all
Where is a good place to start on ride height and anyone have any pure street alignment settings they recommend. Thanks
Old Sep 2, 2010 | 08:14 AM
Page's Avatar
Page is a glorious beacon of lightPage is a glorious beacon of lightPage is a glorious beacon of lightPage is a glorious beacon of lightPage is a glorious beacon of lightPage is a glorious beacon of light
Here's a good starting point for height settings.
These are the Gt2 ride height measurements. Chassis Reference points are located in the picute attached.
FRONT: 118mm to 123mm
REAR: 133mm to 138mm
As for camber, a good street setting would be around -1.5 (closer to -2.0/-2.5 for track) for the front and -2.0 in the rear. 0 on the toe and as much caster the car will give you with the suspension components that you have, but no more then 8.3 degrees.
Any other mods you have done to the suspension; sway bars, dog bone links, adjustable toe links, etc..
Let us know how it works out for you!
Old Nov 5, 2010 | 01:54 AM
Mikkofin's Avatar
Mikkofin is infamous around these parts
My PSS10 set should be here today. Thanks for the useful info!
Old Nov 5, 2010 | 02:45 AM
Terminator's Avatar
Terminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant future
I have mine at GT2 ride height. This is as low as you want to be on the street – otherwise you will be replacing front lip frequently. Make sure you set it 10mm above GT2 height when fitted. In 3 months you will have GT2 height “automatically” as they will set-in and sag. Ask me how I know? Now my height stays solid.
Old Nov 5, 2010 | 02:46 AM
Mikkofin's Avatar
Thanks for the tips! What settings are you running? Mainly street?
Old Nov 5, 2010 | 11:09 AM
Terminator's Avatar
I prefer to be safe on the street. So 7 up front 5 at the rear = neutral with slight understeer. When on track, I crank the fronts to 8 and rears to 10 for tail happier car. However, I also have stabilizer bars fitted, so might be different with you.
Old Nov 5, 2010 | 11:15 AM
Mikkofin's Avatar
Thanks for the input! Appreciated.
AJUSA.com
997 Vendor Classifieds
Oct 8, 2015 05:50 PM
tkebp1275
Aug 31, 2015 06:35 PM
km90265
Aug 31, 2015 11:00 AM
OldBoldPilot
Aug 24, 2015 04:00 PM
