I Wont Stop Making 996TT Parts - New Project
Old Sep 9, 2010 | 07:04 PM
vividracing's Avatar
Not gonna give any details right now except 996TT guys are going to be pumped when they have monster 350mm rotors! Stay tuned and keep reading.
Sneak pics of the rear 996TT kit with 997TT 350mm rotor with stock caliper.
Old Sep 9, 2010 | 07:28 PM
Basic's Avatar
Basic has a brilliant futureBasic has a brilliant futureBasic has a brilliant futureBasic has a brilliant futureBasic has a brilliant futureBasic has a brilliant futureBasic has a brilliant futureBasic has a brilliant futureBasic has a brilliant futureBasic has a brilliant futureBasic has a brilliant future
Not to belittke but its a 10mm spacer with 997tt bolts and oem discs...
Old Sep 10, 2010 | 06:15 AM
joyride's Avatar
joyride has a spectacular aura aboutjoyride has a spectacular aura aboutjoyride has a spectacular aura about
how about some cheaper solid 997TT rotors? GT3 guys are using Cayenne rotors for 120 a pop...
Old Sep 10, 2010 | 07:01 AM
how much is that bracket. can that be done for the front too?
#TeamAIM
Old Sep 10, 2010 | 08:08 AM
Brad Bedell's Avatar
Brad Bedell is a splendid one to beholdBrad Bedell is a splendid one to beholdBrad Bedell is a splendid one to beholdBrad Bedell is a splendid one to beholdBrad Bedell is a splendid one to beholdBrad Bedell is a splendid one to beholdBrad Bedell is a splendid one to beholdBrad Bedell is a splendid one to behold
Do these clear stock wheels?
From my experience with making big brake kits on the 3000gt, you'll want to widen that bracket as much as needed to mate to the stock mounting surface. I had a nasty time with noise unless the footprint for the caliper was wide enough.Great idea! I'm in need of rotors/pads in the next 10k miles; I know what I'm doing...
Old Sep 13, 2010 | 09:04 AM
Basic - If it was always that easy, Home Depot would have a Performance car part section.
Joyride - $120/rotor... that is cheap. Unfortunately we will never make rotors. We sell the better 2pc Brembo rotors that last 3 times longer then stock.
Prodigy - Pricing coming soon... We will have front and rear.
Brad - Yes they clear stock 18" wheels.
Old Sep 13, 2010 | 09:14 AM
joyride's Avatar
Produce some sort of adapter that will allow 996 TT hub to use Gt3 offset rotors? that might not be that hard to produce.
Old Sep 13, 2010 | 09:16 AM
The GT3 and 997TT use the same 350mm rotor. There is a different annulus however to them which the Turbo needs to run the turbo rotor.
Old Sep 13, 2010 | 09:35 AM
I am not talking about cheap 1pc rotors, I am talking about Brembo's 2pc rotor...
View product - http://www.vividracing.com/catalog/b...5-p-61037.html
Read details - http://www.vividracing.com/blog/anno...e-996-and-997/
Old Sep 13, 2010 | 12:05 PM
Just finished the fronts
These will be hard anodized, laser engraved, and include bolts. Rotors can be purchased seperately too
Old Sep 13, 2010 | 03:29 PM
Slider's Avatar
I would suggest that you increase the width of your adapter to perfectly match the width and shape of the caliper so it doesn't look so obvious that there is an adapter there. Right now, it looks like you just bolted something in between that was not intended to be there. Just a design suggestion to make it look like a better fit...
Old Sep 13, 2010 | 04:46 PM
f1crazydriver's Avatar
f1crazydriver Is a GOD !f1crazydriver Is a GOD !f1crazydriver Is a GOD !f1crazydriver Is a GOD !f1crazydriver Is a GOD !f1crazydriver Is a GOD !f1crazydriver Is a GOD !f1crazydriver Is a GOD !f1crazydriver Is a GOD !f1crazydriver Is a GOD !f1crazydriver Is a GOD !
Your mechanic is having an off day. Rotor installed incorrectly. He installed left side on the right side.
Basic, thats pretty much much what it is. I did it for the rear to install the 997tt rotor. My bracket was much closer to tolerence though.
Old Sep 13, 2010 | 04:48 PM
That was for pictures only to test fit. Not installed on that car actually.
Good looking out though!
Old Sep 13, 2010 | 05:27 PM
NathanialHale's Avatar
NathanialHale is infamous around these parts
Dan, come on man, it is that easy... And guys it's not a 10MM spacer. It's a 12mm spacer that can be sourced thru any steel/aluminum flatstock supplier. Mike Kelly and Al Norton did this with their rear calipers, and the fronts are pretty much the same... $50 in materials plus the bolts from your porsche dealer...
Such spooky stuff... Guess we peeked behind the curtain to see the mighty oz.
NH
Old Sep 13, 2010 | 05:32 PM
You can pay IB and promote your $50 product then. Thanks
