Fitting 335/30/18 Toyo R888 in the rear
Old Sep 15, 2010 | 02:31 AM
dgreen78's Avatar
dgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond repute
In my quest to get better traction I have optioned for a set of the new lightweight Forgestar F14s with some sticky R888 tires 245/335. I am wondering if anyone else has installed this setup and how they modified the inner plastics. I test fitted the rears last night and I see I need to either cut out or reshape the liners. I am worried about the lower IC hose vulnerability to road debris without the liners. And yes, I have the fenders rolled and -1.8 camber in the rear. Any thoughts?
Here are some pics comparing my 19X11" with 315/25 to the new 18X12" with 335/30:
Old Sep 15, 2010 | 05:04 AM
Blockhed's Avatar
Blockhed Is a GOD !Blockhed Is a GOD !Blockhed Is a GOD !Blockhed Is a GOD !Blockhed Is a GOD !Blockhed Is a GOD !Blockhed Is a GOD !Blockhed Is a GOD !Blockhed Is a GOD !Blockhed Is a GOD !Blockhed Is a GOD !
those look huge..good luck
I pussied out and went 315's had a deal I couldn't pass
Old Sep 15, 2010 | 06:17 AM
alex55's Avatar
alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !
interesting, good luck!
Old Sep 15, 2010 | 06:54 AM
2muchtime's Avatar
2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute
what offsets do you have on your rear rims? Thoughts on spacers to help push out the rims a little? Personally I'm not a fan of spacers.
Old Sep 15, 2010 | 07:21 AM
landjet's Avatar
Can't remember where I read it but one guy said he heated up the fender well material to reshape it. Good luck, those tires are wide. I stuck with the 315's myself.
Old Sep 15, 2010 | 07:32 AM
how's the offset on the wheels. if it's not to agressive I would space them out to be as far out as you can without the tire grabbing the quarter panel and then go to work on the fender liner. heat it up or/and cut. one thing to watch out for is that charge-pipe....dont wanna rub through that.
#TeamAIM
Old Sep 15, 2010 | 07:40 AM
OS Inspector's Avatar
OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !
art had some drag raidals about that size that swelled up at speed n rubbed the inner liners and popped a tire at 215mph during a goliad run
Old Sep 15, 2010 | 08:32 AM
joyride's Avatar
joyride has a spectacular aura aboutjoyride has a spectacular aura aboutjoyride has a spectacular aura about
Originally Posted by Josh@TPCRACING
What are you using this car for??? Is this thing a drag car are you running road courses.
If you are running road courses, I hate to say it, but you are going to wrong way with this mod. I see in your sig you have a set of JIC coilovers...but no mention of a set of proper sway bars. It's a common misconception, but proper sway bars play a FAR great role in producing cornering grip as well as making the car more planted and confident while doing so. With the chassis properly setup, you'll be able to cut your lap times with tires that are OEM size.
so, what is the stock sway bar size and what size sway bar do you recommend?
is the front or rear more important?
Old Sep 15, 2010 | 06:29 PM
Turbo Fanatic's Avatar
What wheels are you running and what is the offset?
Old Sep 15, 2010 | 08:23 PM
Zippy's Avatar
Take a heat gun to the rear fender liners, where the tires make contact. When hot and pliable, push in the plastic with something like a baseball. Hold that position until the plastic cools and will hold the shape. I moved the lower attachment point, for the drivers side, back about 1". ALSO, Before heating the plastic, bend the fender liner brackets back/inward 3/4" to 1". I actually removed the flimsy bracket on the drivers side, which seems to have the most clearance issues. Camber set for -2.0 all around.
Old Sep 15, 2010 | 09:13 PM
dgreen78's Avatar
Ahh, thanks Zipppy thats what I was looking for! Ill post pics up when I am done. I am not sure on the offsets of the wheels. I was told they were for a 997tt but will work great on my 996tt.
Old Sep 15, 2010 | 09:19 PM
Racin Jason's Avatar
Racin Jason has a brilliant futureRacin Jason has a brilliant futureRacin Jason has a brilliant futureRacin Jason has a brilliant futureRacin Jason has a brilliant futureRacin Jason has a brilliant futureRacin Jason has a brilliant futureRacin Jason has a brilliant futureRacin Jason has a brilliant futureRacin Jason has a brilliant futureRacin Jason has a brilliant future
i have 335 ra1's on my GT2 on 18 x 12 stock wheels with 45mm offsett.
I'm going to heat the inners for a bit more clearance.
Old Sep 15, 2010 | 09:38 PM
c32AMG-DTM's Avatar
c32AMG-DTM Is a GOD !c32AMG-DTM Is a GOD !c32AMG-DTM Is a GOD !c32AMG-DTM Is a GOD !c32AMG-DTM Is a GOD !c32AMG-DTM Is a GOD !c32AMG-DTM Is a GOD !c32AMG-DTM Is a GOD !c32AMG-DTM Is a GOD !c32AMG-DTM Is a GOD !c32AMG-DTM Is a GOD !
Needless to say it takes a lot of money/development/talented engineers to develop winning racecars. This is something that no other company that has the on track racing experience of TPC Racing that is producing professional level products for the general consumer!
While TPC certainly has an impressive racing pedigree and turns some of that knowledge and expertise into consumer products, wouldn't it be fair to state that GMG does as well? Not looking to start anything; just mentioning it. Agree completely with your main point, however: sway bars are a terrific suspension mod for most any vehicle - especially if your stock bars are non-adjustable (as most seem to be). Should be on any enthusiast's short list, if they hold an appreciation for handling performance and lateral grip.
Old Sep 15, 2010 | 10:46 PM
Zippy's Avatar
I used GT3 swaybars with The Racers Group curved front drop links. They seems to do a good job. I think they were about $400 for the pair. I would be interested hearing what the more expensive units from TPCRacing bring to the table.
Old Sep 15, 2010 | 10:48 PM
Zippy's Avatar
No problem. I put that together a few years ago for Tom Kerr when he was interested in getting into the same sizes we have.
