pss9 noise??
Old Oct 5, 2003 | 09:34 AM
fm996tt's Avatar
fm996tt is infamous around these parts
pss9 noise??
I am a beginner at this so if I don't explain things in the best PORSCHE manner please understand. I had pss9's installed a couple of weeks ago and noticed yesterday that I am getting a KLINKING sound at slow speeds when steering left or right. The car is lowered but it’s on a very soft setting. It’s definitely from the front end. It seems just in front of the windshield. Has anyone picked this up before or think that the pss9 are related to this????
Thanks,
Old Oct 5, 2003 | 09:43 AM
jamie's Avatar
I found the same with PSS9's on my M3. The tech left something loose on the brakes (not sure what part), but even after this was tightened, I sensed more noise from the suspension compared to stock.
Old Oct 5, 2003 | 11:00 AM
sharkster's Avatar
Re: pss9 noise??
Thanks,
Check to see your sway bar isn't loose or something. With the added stiffness you've given the car, it may have come loose. Just tighten it up again if so... Also it may be your drop links?
Old Oct 5, 2003 | 12:05 PM
msindi's Avatar
no problems on mine....what sways you using??
Old Oct 5, 2003 | 12:14 PM
fm996tt's Avatar
I have not changed the sway bars they are stock.
Old Oct 5, 2003 | 01:04 PM
ben, lj's Avatar
Senior Member
ben, lj has a spectacular aura aboutben, lj has a spectacular aura about
H&Rs are famous for this but it's the first i've heard of the PSS9s doing it.
Old Oct 5, 2003 | 01:50 PM
KPV's Avatar
KPV
How many times have you heard it, which direction were you turning and how fast were you going?
Old Oct 5, 2003 | 04:20 PM
fm996tt's Avatar
I heard this number of times and not traveling at a fast rate. I have not noticed it on normal driving speeds or driving fast. I notice it the most when at slow speeds, usually when parking the car. I almost want to say that its usually turning to the right that I notice this but not really sure.
Thank you all for your help.
Old Oct 5, 2003 | 04:56 PM
Chris Y.'s Avatar
Chris Y. is infamous around these parts
I had similar noises with my H&R coilovers.
When I was ready to install my RUF coilover set, I had Rob at scargo install some teflon bushings to prevent any noises. So far so good...no noises...quiet as stock.
Give him at call at 415-485-6026 if interested.
Old Oct 5, 2003 | 04:58 PM
sharkster's Avatar
Heya Chris,
Thanks BTW, I got the strut brace and slapped it in
Old Oct 5, 2003 | 05:32 PM
ben, lj's Avatar
Senior Member
"I had similar noises with my H&R coilovers. "
i think we all experience the "clunk" only at low speeds with the H&Rs. isn't this normal for the H&Rs - they say it is?
Old Oct 5, 2003 | 06:55 PM
Chris Y.'s Avatar
H&R support says it's normal, but i don't buy it! I rode in Wilbur's car a few months ago and his car was quiet as stock, suspension wise. He was using the H&R sways and didn't even have any clunking there as many have experienced. Hamman7 has his car now, and I believe things haven't changed suspension wise.
Generally, my experience with coilovers is things do get noisier. First I would make sure everything is tight and go from there. Just make sure you don't have any loose pieces down there.
rob4wellness
Oct 2, 2015 07:32 AM
Ronny-
Sep 30, 2015 07:30 PM
Zero911
Sep 24, 2015 06:33 PM
