Weight of Brakes
Weight of Brakes
Has anyone taken weight measurements of the various 996 braking options? I would have thought that once you have reached the pinnacle of braking performance, that the next step would be to reduce the unsprung weight. Am I missing something?
Cheers.
Cheers.
Daniel...Many members here wish someone could provide the answer to this...Many want the weights on stock TT system, Brembo Gran turismo 8-pod, Brembo Le Mans 8-pod and GT3 with steel rotors set up...
Any volunteers??
Any volunteers??
Any volunteers??
Any volunteers??
Cheers.
Brake Weights
996TT FRONT:
- Stock - Rotor: 23.4 pounds
- Stock - Caliper: 10.1 pounds
- Brembo GT - Rotor: 16.9 pounds
- Brembo GT - Caliper: 10.5 pounds
- Brembo Le Mans - Rotor: 16.9 pounds
- Brembo Le Mans - Caliper: 7.4 pounds (8 piston)
996TT REAR:
- Stock - Rotor: 19.3 pounds
- Stock - Caliper: 12.2 pounds
- Brembo GT - Rotor: 13.6 pounds
- Brembo Le Mans - Rotor: 13.4 pounds
Cheers.
996TT REAR:
Cheers.
wow! now that you say that i think my GT3 brake kit came in three seperate boxes 1) with two rotors/calipers/pads/brake lines (70 lbs) 2) with two rotors/calipers/pads/brake lines (70 lbs) and 3) with the wheel carriers. so your numbers look right which suggest an 80 lb unsprung weight savings. that's spectacular.
Still, a very nice reduction in USW.
msindi,
The Brembo GT front caliper weights are for the 8-piston. Here is a photo of the rear Le Mans caliper:
Here are the available options for 996TT Brembo brake upgrades. The 18" wheel will not accommodate the Le Mans system. Only a "true" 18" wheel (this needs to be measured) will accommodate the Le Mans system. Contact BeastPower for exclusive 6speedonline.com pricing:
Cheers.
Cheers.
Beastpower:
Thanks! Finally hard numbers.
Here are some totals:
Stock to Brembo GT - 27lb USW savings, $185/lb
Stock to Lemans - 39.8 lbs USW savings, $314/lb
I went to Wilwood racing brakes for my Countach and pulled 48 lbs USW off the car. I could notice an improvement in handling over rough surfaces primarily. I didn't have a data acquisition system installed to compare before and after at that time. I did not retune the suspension. I primarily changed the brakes to improve cooling (curved vanes compared to straight stock vanes) but got a real nice performance increase as well.
I will look at upgrading the brakes once I get out on the track.
ModBargains
996 Turbo Vendor Classifieds
Oct 13, 2015 03:52 PM
ModBargains
ModBargains
Panamera Vendor Classifieds
Oct 13, 2015 03:51 PM
ModBargains
Ferrari Vendor Classifieds
Oct 13, 2015 03:47 PM
ModBargains
Lamborghini Vendor Classifieds
