Stock Sl 65 DYNO RESULTS
Old Feb 28, 2005 | 05:56 PM
JOEFIXX's Avatar
JOEFIXX is infamous around these parts
Well today i took my new stock sl65
to the dyno..
there were 2 pulls and the second better pull was
708 ft/lb at 2447 RPM
528 rwhp at 4926 Rpm
Unfortunately the car did not let the RPM's go further since the computer onboard wanted to **** to the 5 th gear.. since the break in period has not been achieved yet
this run was done for baseline purposes
so that i can find out how much more power the renntech mods will give me
EVERYBODY AND ESPECIALLY BRITT
THANKS FOR THE PREVIOUS POSTS
I WILL GET THE SAME DESIGN WHEELS IN THE REAR JUST 20x11 SO THAT I CAN FIT MORE RUBBER (LIKE 315's) SINCE THE CAR IS VERY LOOSE FEELING... WITH THE STOCK 285
Old Feb 28, 2005 | 06:47 PM
alexWS6's Avatar
alexWS6 has much to be proud ofalexWS6 has much to be proud ofalexWS6 has much to be proud ofalexWS6 has much to be proud ofalexWS6 has much to be proud ofalexWS6 has much to be proud ofalexWS6 has much to be proud ofalexWS6 has much to be proud of
Wow!
Old Feb 28, 2005 | 06:55 PM
StephenTi's Avatar
StephenTi is infamous around these parts
What were the hp/tq numbers at the wheel?
HotRodGuy's Avatar
killer
Old Feb 28, 2005 | 06:56 PM
HotRodGuy's Avatar
those look like them
Old Feb 28, 2005 | 06:57 PM
JOEFIXX's Avatar
YES THIS WAS AT THE WHEEL
THE CAR WAS STOCK
AND FRESHLY CALIBRATED DYNO
Old Feb 28, 2005 | 09:00 PM
StephenTi's Avatar
AMAZING!
Old Mar 1, 2005 | 01:20 AM
Fanman's Avatar
Fanman is infamous around these parts
When do you get the Renntech ECU upgrade ? BTW, NICE results.
Also be aware that usually when you get larger wheels you will dyno lower (the wheel inertia is farther out from the center), so the 20" rims will probably take some hp off the dyno #.
Old Mar 1, 2005 | 04:58 AM
JOEFIXX's Avatar
the renntech should be in 2 weekend from now
and thanks for the 20 inch rimms advise i did not know that
Old Mar 1, 2005 | 06:52 AM
Greyghost's Avatar
Greyghost is infamous around these parts
KILLER!!!! What a beast!
Old Mar 1, 2005 | 07:04 AM
JOEFIXX's Avatar
Talking
HERE IS THE DYNO SHEET
2 RUNS RECORDED 45 MINS APART THE SECOND RUN WAS STRONGER
Old Mar 1, 2005 | 08:22 AM
ebaker's Avatar
ebaker is infamous around these parts
What's the engine redline?
Old Mar 1, 2005 | 08:30 AM
JOEFIXX's Avatar
the redline is at 6050
Old Mar 1, 2005 | 08:38 AM
bottomline's Avatar
bottomline is infamous around these partsbottomline is infamous around these parts
B E A U tiful
Old Mar 1, 2005 | 10:17 AM
Paul2x's Avatar
Paul2x is infamous around these parts
Nice #'s
Any pic's of the Twin SC'd Lambo!?!
