heavy clutch
Old Oct 16, 2010 | 11:03 PM
saint01's Avatar
saint01 has much to be proud ofsaint01 has much to be proud ofsaint01 has much to be proud ofsaint01 has much to be proud ofsaint01 has much to be proud ofsaint01 has much to be proud ofsaint01 has much to be proud ofsaint01 has much to be proud of
heavy clutch
Guys...I'm new to being the proud owner of an 02 996tt. Bought from Scott here on the forums and was taken care of like a baby.
I've put 1500 miles on it since rounding about 24k total. The concern I have is that the clutch is VERY heavy on startup. No problems afterwards and no issues found during PPI.
Thoughts on the issue? How about cost? Probably better to get looked at sooner than later but was looking for an idea of the issue prior This taking her in.
Thanks for any insight.
e a baby.
Old Oct 16, 2010 | 11:13 PM
pinoy911tt's Avatar
pinoy911tt is a splendid one to beholdpinoy911tt is a splendid one to beholdpinoy911tt is a splendid one to beholdpinoy911tt is a splendid one to beholdpinoy911tt is a splendid one to beholdpinoy911tt is a splendid one to behold
typical problem clutch accumulator
Old Oct 16, 2010 | 11:54 PM
rdss's Avatar
rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !
Saint 01
Is your car moded ?-Wellcome and congrats,
Old Oct 17, 2010 | 08:45 AM
OS Inspector's Avatar
OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !
when the clutch accumulator and slave are on their way out pedal gets hard when car is off
Old Oct 17, 2010 | 08:54 AM
saint01's Avatar
Thanks guys. Any idea of cost?
Old Oct 17, 2010 | 08:58 AM
700-1500 depends if they just do the accumulator or do the slave too and their labor costs.
Old Oct 17, 2010 | 09:01 AM
saint01's Avatar
Thanks guys! Not sure How the PPI didn't catch this but oh well.
Old Oct 17, 2010 | 01:12 PM
Nor Cal Turbo's Avatar
Nor Cal Turbo Is a GOD !Nor Cal Turbo Is a GOD !Nor Cal Turbo Is a GOD !Nor Cal Turbo Is a GOD !Nor Cal Turbo Is a GOD !Nor Cal Turbo Is a GOD !Nor Cal Turbo Is a GOD !Nor Cal Turbo Is a GOD !Nor Cal Turbo Is a GOD !Nor Cal Turbo Is a GOD !Nor Cal Turbo Is a GOD !
Not likely to be caught during a PPI unless their is active leaking going on from the accumulator or slave. If you had known about the heavy clutch at cold start when the PPI was done, your mechanic could have told you that the accumulator and/or slave is going bad. This is a common problem with the 996tt and 997tt. I am in the exact same boat as you. Bought my car back in May and a couple of months ago I noticed a heavy pedal at cold start after sitting for awhile. I am thinking of going with the GT2 slave conversion and would suggest you look at this rout as well. If you simply fix the accumulator and/or slave you can look forward to doing this reapir again in about 3-5 years. My car had all records when I bought it and had the slave and accumulator redone about 5 years ago so looks like it is right on schedule to go bad again. The GT2 conversion will result in a heavier clutch pedal for normal use since there will no longer be a hydraulic assist but it is a fix that won't reliable brake again in the future. I hate the feel of the hydraulic assist clutch anyway since clutch engagement is so hard to feel. I plan to drive a GT2, GT3, or a 996tt that has the conversion to ensure I like the feel.
Last edited by Nor Cal Turbo; Oct 17, 2010 at 01:13 PM. Reason: grammer and spelling
Old Oct 17, 2010 | 02:50 PM
jimmy k's Avatar
jimmy k is a jewel in the roughjimmy k is a jewel in the roughjimmy k is a jewel in the roughjimmy k is a jewel in the rough
Mine used to have this problem just in the morning before going to work. Then it happened everytime I stepped into the car. Now it even happens occasionally when driving. It really pisses me off.
Can anyone in Atlanta tell me of a place that will install Evoms GT2 kit? The dealers don't seem to want to touch it.
Old Oct 18, 2010 | 09:13 PM
brain police's Avatar
brain police is infamous around these parts
GT2 Slave/Cylinder
Do yourselves a favor and purchase a GT2 clutch slave/cylinder kit. I had two accumulators go on me within three years. Replaced it with the GT2 in April of this year and could not be happier. The clutch is stiffer than OEM 996TT, but that's not saying much. I often get stuck in stop and go and have no gripes about the GT2 clutch. If you've had older 911s (I have a 1987 Carrera) the clutch feel is very similar...much more tactile and overall a better experience. Purchased my GT2 conversion from EVOMS for approx $1000 and am very pleased with the build quality. I wish I had done this conversion after the first failed accumulator, it would have saved me a lot of $$$$.
Old Oct 19, 2010 | 12:16 PM
jqhayden's Avatar
jqhayden is infamous around these parts
Same problem...its the clutch accumulator. Ruf shop told me ~$400 i think to fix. It doesnt bother me since its only on start up so i havent fixed.
Old Oct 19, 2010 | 12:42 PM
Gunther's Avatar
Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !
The part is under $130 from Suncoast. Easy fix with a lift.
Old Oct 21, 2010 | 08:33 PM
saint01's Avatar
You are the man! That was my next question on where to get one. I am not going to switch to the GT2 conversion. My car sees mostly street time (only track 3-4 times per year) and even though I am a bodybuilder I don't want to be sitting in traffic with a heavy clutch. Say what you want but for $130 and a few hours of my time every few years it seems well worth it to have a lighter clutch.
I really appreciate everyone's willingness to respond. You guys are great!
Hybrid
Jun 28, 2024 06:05 AM
Bmw M3 Guy
Feb 21, 2018 09:29 AM
nick49
Jan 26, 2017 01:17 PM
ECS Tuning - BMW
Sep 16, 2015 07:20 AM
ECS Tuning - VW
Sep 9, 2015 12:01 PM
