62k Miles - Compression and Leakdown numbers
Old Oct 19, 2010 | 01:38 PM
RiA's Avatar
RiA
RiA Is a GOD !RiA Is a GOD !RiA Is a GOD !RiA Is a GOD !RiA Is a GOD !RiA Is a GOD !RiA Is a GOD !RiA Is a GOD !RiA Is a GOD !RiA Is a GOD !RiA Is a GOD !
So I've got 62k+ miles (35k with mods) and I've got some numbers that I thought others might be interested in seeing:
Compression = 220 psi on left bank, 225 psi on right bank
Leak down = <5% on all cylinders
I'm very pleased with the numbers. Anyone else have some for comparison?
Old Oct 19, 2010 | 01:45 PM
MBailey's Avatar
Great numbers Rich!
Glad she is behavin for you.
I have not tried compression test yet... Hope I do as well.
Old Oct 19, 2010 | 09:13 PM
RiA's Avatar
RiA
Thanks Mike - she's running quite well these days.
I'd be interested in hearing your numbers whenever you get them.
You going to TX Mile this year?
Old Oct 20, 2010 | 06:46 AM
MBailey's Avatar
I will be there this weekend. Hoping for the magic number!
Old Oct 20, 2010 | 04:49 PM
Tim941NYC's Avatar
Good numbers. The 5 psi bank to bank is most likely do to cam timing. I have yet to open a tt motor that the timing was on.
Old Oct 20, 2010 | 05:19 PM
RiA's Avatar
RiA
Thanks Tim - that is what I suspected.
What other numbers have you seen? I'd like a greater sampling for comparison - I only have a sample size of 1 thus far.
Old Oct 20, 2010 | 05:41 PM
bmoores's Avatar
bmoores Is a GOD !bmoores Is a GOD !bmoores Is a GOD !bmoores Is a GOD !bmoores Is a GOD !bmoores Is a GOD !bmoores Is a GOD !bmoores Is a GOD !bmoores Is a GOD !bmoores Is a GOD !bmoores Is a GOD !
Do I need to bring my helmet
Old Oct 20, 2010 | 06:24 PM
Tim941NYC's Avatar
Honestly I only check the compression on the stand by hand to make sure all is well before I reassembly the rest of the motor. It is common in this motor for one bank to be off, its never a lot. If there is something that I suspect I go right for the leak down. Its more telling of the cylinder condition then a compression test.
Old Oct 20, 2010 | 07:40 PM
pinoy911tt's Avatar
pinoy911tt is a splendid one to beholdpinoy911tt is a splendid one to beholdpinoy911tt is a splendid one to beholdpinoy911tt is a splendid one to beholdpinoy911tt is a splendid one to beholdpinoy911tt is a splendid one to behold
tim, how many miles do you recommened for break in with new rings and non synthetic oil? also, drive it hard or moderate?
Old Oct 20, 2010 | 09:21 PM
RiA's Avatar
RiA
Nobody else has compression and leak-down numbers?
Where are all the builders and technicians with their experiences?
Old Oct 20, 2010 | 09:47 PM
996PCarGo's Avatar
996PCarGo is a splendid one to behold996PCarGo is a splendid one to behold996PCarGo is a splendid one to behold996PCarGo is a splendid one to behold996PCarGo is a splendid one to behold996PCarGo is a splendid one to behold996PCarGo is a splendid one to behold996PCarGo is a splendid one to behold
Decent numbers... Now for your next 60k miles.
Old Oct 20, 2010 | 10:37 PM
Tim941NYC's Avatar
I will bring the car up to temp 3 times on the lift. then dump the oil through a big coffee filter and check it for metal also cut the oil filter and open all the pleats and check for same. new oil and filter run 50 to 100 miles of excelling with a heavy foot but not standing on the boost. dump the oil again as before, if all looks good you are done. If at any of those oil changes show metal take the motor apart and see whats going on. When I pulled my motor apart the first time it had 70,000 miles on it and there was still cross hatching on the sleeves.
Old Oct 21, 2010 | 02:29 AM
legendr34's Avatar
legendr34 has much to be proud oflegendr34 has much to be proud oflegendr34 has much to be proud oflegendr34 has much to be proud oflegendr34 has much to be proud oflegendr34 has much to be proud oflegendr34 has much to be proud oflegendr34 has much to be proud oflegendr34 has much to be proud oflegendr34 has much to be proud of
i'm glad to see these engines last long
Old Oct 21, 2010 | 08:05 AM
pinoy911tt's Avatar
thanks tim. when i took mine apart at 61k and changed the rods it also still had the cross hatchings
Old Oct 21, 2010 | 08:21 AM
Tim941NYC's Avatar
Porsche really did there homework with the sleeves. The counter shaft's bearings always look to be in the worst shape of anything in the motor.
