Pic of my burned clutch + GT2 Conv impressions
Old Oct 29, 2010 | 11:03 PM
TweakitTT's Avatar
TweakitTT is a splendid one to beholdTweakitTT is a splendid one to beholdTweakitTT is a splendid one to beholdTweakitTT is a splendid one to beholdTweakitTT is a splendid one to beholdTweakitTT is a splendid one to beholdTweakitTT is a splendid one to behold
Just completed my CM Stg2 + GT2 conversion by the fine folks at Boost Logic. They also found a 2 inch gash in my intake tube. Can't wait till my break in period is over so I can take the car to the track again. Ran a 13.1 @110 MPH with a slipping clutch and a boost leak.
Initial impression of the new clutch setup is the low engagement point. Stalled a couple of times and couldn't shift into gear (I wasn't pressing the clutch all the way down to the floor) . Should get better over time with practice and as the clutch breaks in. Clutch feel is much better now and the extra pedal effort is minimal.
For those with GT2 conversions + new clutch about how long does it take for the engagement point to return to "normal" ?
Old Oct 30, 2010 | 05:58 AM
OS Inspector's Avatar
OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !
i dont think it ever returns to normal that is why there is all the talk about cutting the slave pin shorter and such to counter act this issue. but lets see what others think.
Old Oct 30, 2010 | 07:56 AM
griggsat's Avatar
griggsat is infamous around these parts
My engagement point is also at the end of the travel of the pedal. But for me that is ok, at least it is consistent! With the stock setup it was all over the place. I think it is mainly a matter of getting used to it.
Old Oct 30, 2010 | 08:08 AM
robertp's Avatar
robertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud of
Yep, the last inch is where they kick in. It makes it difficult to launch from a dig.
Old Oct 30, 2010 | 01:07 PM
TweakitTT's Avatar
Yea, I guess I'll give it sometime. When speed shifting my timing will be off since the engagment is so quick...I worry about breaking my transmission from shifting without the clutch all the way down.
Anyone have ideas on the costs of having it adjusted...in the future?
Old Oct 30, 2010 | 01:25 PM
No SubstiTTute's Avatar
No SubstiTTute is infamous around these parts
Does anyone know if stock 996 GT2s have the same engagement point as the Turbos converted to the GT2 setup?
Old Oct 30, 2010 | 02:14 PM
TweakitTT's Avatar
I did some searching in this forum and it seems the engagement point of the clutch is more dependant on the aftermarket clutch you install. The GT2 conversion only alters the "feel"
Old Oct 30, 2010 | 07:35 PM
Prche951's Avatar
my engagement point is high enough that I installed the RSS tuning clutch stop with the bolt screwed in all the way and I have less than an inch travel to engage now, which is what it was before. Feels much better and I don't stall it as often. Of course the lwfw makes the engine zing so it is hard to engage at low rpms.
Old Oct 31, 2010 | 08:50 AM
robmd99's Avatar
robmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond repute
I had Motorwerks create a custom set up on my clutch so it would have the original engangement point. It feels very good and if you ever are in H town you can give it a test drive.
Cheers
Robert
Old Oct 31, 2010 | 04:43 PM
TweakitTT's Avatar
Cheers
Robert
Great, thanks for the offer! Can you give me an idea of how much it would cost for the adjustment? labor hours etc..
Old Oct 31, 2010 | 08:19 PM
robmd99's Avatar
You need to call Akram at Motorwerks in Houston
Robert
Murf4
New Member Introductions
Sep 3, 2015 10:10 AM
orbelo
Aug 30, 2015 12:26 PM
TrackOne
Aug 20, 2015 12:56 PM
