Tiptronic limits
Old Nov 2, 2010 | 10:09 PM
  #46
Valley996TT's Avatar
Valley996TT is just really niceValley996TT is just really niceValley996TT is just really niceValley996TT is just really nice
Originally Posted by perfuseme2
hey valley 996 how is the miltek exhaust for ya? any drone or anything? im leaning to the quiet speed tech.
so if i run the 24/18 upgrade how much boost should i be running to keep the tippy happy? i assume i can let my tuner know what all my mods are and that i dont wanna make more than 500whp?
again id rather run the 24/18 with lower boost than the 16s maxed out. last thing i need is a blown head gasket.
Perfuseme2,
I like my Miltek, a lot. It sounds absolutely mean at WOT. My wife does not like it, but she doesn't ride in my car very often. There is a little drone somewhere between 2k-3k rpm, but it is VERY brief and the sound at normal driving speeds it sounds nice. As far as how it sounds at WOT, a C6 Z06 owner I raced a few months ago said that I sounded like a freight train as I went past him and pulled away. The only thing I didn't like about my Miltek was the PRICE! If you are looking for more of a quiet sound then you may want to go with the speed tech.
What part of Houston do you live in?
Old Nov 3, 2010 | 06:22 AM
  #47
Shotcaller's Avatar
Shotcaller has much to be proud ofShotcaller has much to be proud ofShotcaller has much to be proud ofShotcaller has much to be proud ofShotcaller has much to be proud ofShotcaller has much to be proud ofShotcaller has much to be proud ofShotcaller has much to be proud ofShotcaller has much to be proud of
Originally Posted by WhiteKnight
dear friends,
i have build six 997tt tiptronic till now all working with more than 600hp
without any problem.
most of them has 3076 turbos
i made also oil cooler which helps above 100km/h , it drops the heat about 10 degrees
torque converter don't touch it no needed
very soon i will make a 996 tip i will let you know the results
the gearbox of 997 and 996 are similar and the valvebody is same
changing the valvebody is making shifting very fast and sometimes very similar to Pdk but you have to upgrade also the tcu to get better results
P.S. don't forget to control the central differential oil because the weakest part of the car is center diff . if the oil is not red then problem starts.
997tt has different cental diff than 996tt . i have also reinforced 997tt center diff .
regards
emre
i
Sound interesting
Old Jul 21, 2014 | 10:34 AM
  #48
Drew959's Avatar
Drew959 is a jewel in the roughDrew959 is a jewel in the roughDrew959 is a jewel in the rough
Bumping an old thread.. Any other experiences with Tip limits??
Old Jul 21, 2014 | 11:12 AM
  #49
gregp714's Avatar
gregp714 has a spectacular aura aboutgregp714 has a spectacular aura aboutgregp714 has a spectacular aura about
Interested too. New tip owner with mods in mind but my turbo has a tip too. The build sheet says Tip S - is that different than a normal tip?
Just Cruise
Canada
11
Jan 8, 2017 08:04 PM
Texas1
Sep 20, 2015 09:12 AM
bobolouie
Macan
Sep 11, 2015 09:08 AM
