Streetable 700 AWHP 996 Turbo
Old Nov 7, 2010 | 05:35 PM
  #31
9Eleven's Avatar
9Eleven has a reputation beyond repute9Eleven has a reputation beyond repute9Eleven has a reputation beyond repute9Eleven has a reputation beyond repute9Eleven has a reputation beyond repute9Eleven has a reputation beyond repute9Eleven has a reputation beyond repute9Eleven has a reputation beyond repute9Eleven has a reputation beyond repute9Eleven has a reputation beyond repute9Eleven has a reputation beyond repute
Yea, but the OP was talking about 700 awhp on 91 octane, not 700 rwhp on 93. That is a pretty big difference. 700 rwhp on 93 can be done, but 700 awhp on 91 with stock internals? I wouldn't try it.
Old Nov 7, 2010 | 05:38 PM
  #32
Divexxtreme's Avatar
It says "91-93 octane". 91 octane with meth injection would work as well.
  #33
besiktas's Avatar
besiktas is infamous around these partsbesiktas is infamous around these parts
Originally Posted by Dr_jitsu
Tip will never handle 700 whp...I have told several people that, they didn't listen and learned the hard way.
It's old news. My car (997tt) has well over 700whp and our modified tiptronic handles it just fine. Actually, on pbox graph, the shifting is at 0.1 second, which is the same with PDK
Old Nov 7, 2010 | 05:53 PM
  #34
unvmy996's Avatar
+1 for markski , im also running his kit , turbos , and couldnt be happyer
Old Nov 7, 2010 | 05:57 PM
  #35
9Eleven's Avatar
rwhp or awhp?
Old Nov 7, 2010 | 05:58 PM
  #36
TT VIPER's Avatar
TT VIPER is infamous around these parts
Dr. jitsu, don't be hatin.
There is great information here. From what I'm reading and based on personal experience of owners, I think it is possible to achieve 700 AWHP on 91 Octane gas. And maybe even higher using methanol. I'm ok with building the internals of the engine. I'm not familiar with 996 Turbo engines but replacing the pistons, rods, rings, bearings, and studs should not cost an arm and a leg. You are not replacing the crankshaft, or the mains, or sleeves, etc. I want the turbos to kick in as early as possible. I would rather have 680 AWHP that spools at 3000 - 3500 rpm rather than 980 AWHP up at 5000 rpm.
Markski, how much AWHP does your Ski 850GT kit make on 91 Octane gas?
Then, the real question is how much of an AWD will the 996 Turbo be at 700 AWHP level? Does the front differential become almost useless at these power levels? I want to have something like 30% - 70% or 40% - 60% front-rear traction at these levels. IS there a way to lock the front-rear distribution or electronically change it on the fly from the ****pit? Yes, I want to make AWD slides or 3500 - 4000 rpm AWD launches. Is the 996 Turbo correct platform for this?
If it's going to become a basically RWD high HP car, I already have a 1100 RWHP on pump gas and over 1300 RWHP on C16 Twin Turbo Viper.
Old Nov 7, 2010 | 06:09 PM
  #37
joetwint's Avatar
joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !
Keep in mind that this is a far more complex motor to build than the V10 in your Viper.It requires about 5K dollars in specialized tools just to assemble it!Not to mention the amount of experience one needs to have to do it right.Just an FYI.
Old Nov 7, 2010 | 06:10 PM
  #38
unvmy996's Avatar
even with a built motor , 700 whp on 91 without meth will be hard.
also, you would be suprised how much it costs to build the 996 tt motor.
Old Nov 7, 2010 | 06:20 PM
  #39
pinoy911tt's Avatar
pinoy911tt is a splendid one to beholdpinoy911tt is a splendid one to beholdpinoy911tt is a splendid one to beholdpinoy911tt is a splendid one to beholdpinoy911tt is a splendid one to beholdpinoy911tt is a splendid one to behold
so 91 oct with pure meth is like running 93 oct or higher? glad i'm running meth
it's funny scott we have almost same set up except the turbos. i just built my motor with the only aftermarket internal part pauter rods.
Old Nov 7, 2010 | 06:22 PM
  #40
TT VIPER's Avatar
How much does it cost to build a 996 Turbo engine with forged internals, say CP pistons, Crower rods, rings, bearings, and studs, all assembled and balanced?
And again the real question that I'm interested in is how much of an AWD will the 996 Turbo be at 700 AWHP level? Is it possible to have 30% - 70% or 40% - 60% front-rear traction at these HP levels? Or does the front differential become useless, making the car basically a RWD?
Old Nov 7, 2010 | 06:25 PM
  #41
"Pure" meth with 91 octane is like running MS109 (105 octane). Meth adds the equivalent of 10-15 octane points depending on the amount being used.
I think we have different ICs and exhaust as well. But ya, very similar.
Old Nov 7, 2010 | 06:58 PM
  #42
Blockhed's Avatar
Blockhed Is a GOD !Blockhed Is a GOD !Blockhed Is a GOD !Blockhed Is a GOD !Blockhed Is a GOD !Blockhed Is a GOD !Blockhed Is a GOD !Blockhed Is a GOD !Blockhed Is a GOD !Blockhed Is a GOD !Blockhed Is a GOD !
since we are going off topic here whats the real news on c16 and how often you have to change spark plugs?
Old Nov 7, 2010 | 07:02 PM
  #43
If you run a full tank of unleaded after every two tanks of leaded, the plugs can last 2 or 3 years.
Old Nov 7, 2010 | 07:04 PM
  #44
besiktas's Avatar
CP pistons are about $5k
Pauter rods are about $2k, don't know about crowers.
Good studs (12mm) are about $1,200
Bearings should be another $1k
and the labor of these should be around $5k or so. you are looking something close to $15k including the labor.
Old Nov 7, 2010 | 07:17 PM
  #45
TT VIPER's Avatar
Wow. The CP pistons in my V10 (8.5 to 1 ratio) cost $150 each in just parts and I have 10 of them, not 6.
Your car is AWD tiptronic, right? How much of an AWD does your car drive like at 700 AWHP? Are there major differences between the AWD drivetrain of 996 Turbo vs 997 Turbo?
