Shortening clutch pushrod when doing GT2 mod ?
Old Nov 17, 2010 | 06:46 AM
jjbravo's Avatar
jjbravo Is a GOD !jjbravo Is a GOD !jjbravo Is a GOD !jjbravo Is a GOD !jjbravo Is a GOD !jjbravo Is a GOD !jjbravo Is a GOD !jjbravo Is a GOD !jjbravo Is a GOD !jjbravo Is a GOD !jjbravo Is a GOD !
(Probably should have said lengthening...)
Finally going to install my kit I've had sitting around.
I notice that many have a near the floor engagement point, and have read somewhere here that some have shortened the pushrod to bring the engagement point up a bit.
Anyone care to chime in about how much they removed?
Old Nov 17, 2010 | 02:17 PM
Scottslaw's Avatar
Scottslaw has a reputation beyond reputeScottslaw has a reputation beyond reputeScottslaw has a reputation beyond reputeScottslaw has a reputation beyond reputeScottslaw has a reputation beyond reputeScottslaw has a reputation beyond reputeScottslaw has a reputation beyond reputeScottslaw has a reputation beyond reputeScottslaw has a reputation beyond reputeScottslaw has a reputation beyond reputeScottslaw has a reputation beyond repute
Hi there...Just got my car back from evo after getting their stage 3 clutch and gt2 convesion done. The car feels awesome, but the engagement is lower than stock. It doesn't really bother me, but their new head tech thinks it is too low so they are fabbing a longer pin and will install it while I wait when I bring the car back. Every car/clutch combo is different apparently. You can also shim something to bring it closer to the clutch, which has the effect of raising the engagement point, but I'm not positive on the details (they did this to my car as well). Good luck...very nice mod, although there is more pedal effort (but it doesn't bother me in the least). I've only driven the car 20 minutes but I"m already used to the new feel!
Old Nov 17, 2010 | 02:28 PM
jjbravo's Avatar
I had forgotten I posted this the other day. Later I thought about it, and quickly realized the longer pin was needed, or machine a bit off the front edge of the EVOMS slave bracket so the slave sits a bit more rearward.
If you could, please mic your old and new pins...
Inquiring minds would like to know.
Old Nov 17, 2010 | 02:31 PM
Scottslaw's Avatar
I got a box with a bunch of my old parts, I'll see what I have in there. Also, what do you mean by "mic"? If you are asking me to measure something on the car, I'd be happy to do so, just tell me where to look.
Old Nov 17, 2010 | 02:36 PM
jjbravo's Avatar
It would be nice to know the exact length of the stock pushrod and the longer one EVOMS proposes. Probably a couple of mm"s but...?
Old Nov 17, 2010 | 04:28 PM
OS Inspector's Avatar
OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !
mic = Micrometer IE a measure tool for machined parts with deviations to the .0001 on a good unit.
Old Nov 17, 2010 | 06:37 PM
dgreen78's Avatar
dgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond repute
I have the opposite problem with my GT2 slave, CM stg 3, Aasco LWFW. The engagement point it too high! I think an adjustable rod would be a great idea:
Old Nov 17, 2010 | 10:23 PM
TweakitTT's Avatar
TweakitTT is a splendid one to beholdTweakitTT is a splendid one to beholdTweakitTT is a splendid one to beholdTweakitTT is a splendid one to beholdTweakitTT is a splendid one to beholdTweakitTT is a splendid one to beholdTweakitTT is a splendid one to behold
Best to try the new engagement point for a month before paying for the modification. I just had my GT2 conversion done and was in the same boat as you. Since I am still breaking in my clutch I haven't taken it to the track, but I am pretty much used to it now.
Houston Motorwerks (Akram) has done the engagement point adjustment if you need details.
Old Nov 18, 2010 | 05:27 AM
tbarcelo's Avatar
tbarcelo is a glorious beacon of lighttbarcelo is a glorious beacon of lighttbarcelo is a glorious beacon of lighttbarcelo is a glorious beacon of lighttbarcelo is a glorious beacon of light
All,
How difficult is it to change the pin/rod after install? Based on what I know of the setup, I figured you would have to do the whole process over, but if Scott thinks EVOMS can redo it while he waits then maybe it's faster than I think ...
Old Nov 18, 2010 | 06:23 AM
jimmy k's Avatar
jimmy k is a jewel in the roughjimmy k is a jewel in the roughjimmy k is a jewel in the roughjimmy k is a jewel in the rough
My engagement point is quite low, about 1" from the floor. At 1st I hated it, but I'm getting used to it.
Old Nov 18, 2010 | 06:49 AM
tvurt's Avatar
tvurt has much to be proud oftvurt has much to be proud oftvurt has much to be proud oftvurt has much to be proud oftvurt has much to be proud oftvurt has much to be proud oftvurt has much to be proud oftvurt has much to be proud oftvurt has much to be proud of
Originally Posted by tbarcelo
All,
You should be able to change the rod by removing the two bolts that hold the slave to the bracket and sliding it out. You can do this on a lift pretty easily.
I have a spare GT2 slave rod if anyone wants it, dunno if it is shorter or longer though.
dgreen78 - I have the same "problem" as you do, I am using a RSS clutch stop, and it is perfect!
Tom
Old Nov 18, 2010 | 08:06 AM
tvurt's Avatar
Some pics, for those thinking bout this mod:
This was done with the trans in place fyi. This pic is from my transmission rebuild.
RallyBird
Oct 7, 2015 01:20 PM
irish100p
Aug 31, 2015 01:04 PM
hacellular
Aug 31, 2015 08:34 AM
orbelo
Aug 30, 2015 12:26 PM
TrackOne
Aug 20, 2015 12:56 PM
