Need to replace my PCM 1 system...
Old Nov 25, 2010 | 10:03 PM
VAGscum's Avatar
Unhappy Need to replace my PCM 1 system...
I have been trying to get my ipod interface to work with my nav unit and have had no luck. I normally do not play CDs, but I tried the CD changer/player to see if it would work. My thought was that seeing the ipod interface uses the CD changer input on the nav unit, this would tell me if the radio part is bad or the interface for the ipod. I found that my CD changer doesn't work properly either. The PCM recognizes the CD changer but when trying to play audio it cycles through all CDs and eventually shows "no CDs" when selected. So neither are working. I like the OEM setup for it's clean stock look and do not want to go with an aftermarket unit if I don't have to. Does anyone have a spare PCM1 unit they want to part with? Will the non-nav becker radio unit work in place of the PCM 1? If so what all is involved with the retrofit? Thanks.
Old Nov 26, 2010 | 08:46 AM
Slider's Avatar
I replaced my head unit with a Pioneer AVIC 120BT. In the long run, it would probably be simpler for you to do the same. To change the head unit (with another PCM1), you would also have to change the AMP (because of the security code) and it sounds like there may be a problem with your CD player, so you may have to change that too. I paid about $1,800 for the pioneer and $200 for the install kit from Loi at Euromotorspeed on EBay and added SAT radio and IPod interface for a few more bucks. The new head unit gives you all the interfaces you could possibly want - your IPod would be very happy there.
Old Nov 26, 2010 | 10:38 AM
VAGscum's Avatar
I have looked at those and my one concern is matching the interior. I like it to look as though it was there from the factory. If it becomes an issue, I may just live with the CD changer issues and find another way to use my IPOD.
Old Nov 26, 2010 | 11:19 AM
Slider's Avatar
That's what the installation kit is for... The new head unit looks totally stock (... well, for a 2010 model car).
Old Nov 26, 2010 | 07:42 PM
Mike01996TT's Avatar
Mike01996TT is infamous around these parts
I have a PCM1 system that I removed from my 01 turbo. I was just getting ready to put it on ebay. PM me if you are interested and let me know what parts you are interested in.
Mike
Old Nov 27, 2010 | 07:15 AM
fdorn's Avatar
fdorn has much to be proud offdorn has much to be proud offdorn has much to be proud offdorn has much to be proud offdorn has much to be proud offdorn has much to be proud offdorn has much to be proud offdorn has much to be proud offdorn has much to be proud of
I installed the Pioneer z110bt - couldn't be happier to get rid of the PCM1
Old Nov 27, 2010 | 09:44 AM
Slider's Avatar
Loi's kit has a textured faceplate that looks even more OEM...
Old Nov 27, 2010 | 11:40 AM
alex55's Avatar
alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !
Slider, do you have the full leather option?
Old Nov 28, 2010 | 09:18 AM
Slider's Avatar
Yes - but I did all the carbon fiber work myself (except for the shifter).
Old Nov 28, 2010 | 10:22 AM
alex55's Avatar
I saw that your cover steering column is in leather, nice!
Old Dec 21, 2010 | 07:29 PM
porsche510's Avatar
porsche510 is infamous around these parts
Ok I'll compare them all then. Interesting that both Pioneers are now under 1K and here is a pretty cool picture that amazon has for one of them:
Old Dec 21, 2010 | 09:13 PM
kosmo96's Avatar
kosmo96 is infamous around these parts
I had a similar problem with my cd changer. If you have a regular cd or nav cd in your pcm unit, remove it, disconnect the battery for 5 minutes, and reconnect it without the cd in the pcm. Put you cd's in the changer and see if the cd changer now functions properly. This solved the malfunction for me.
Old Dec 2, 2013 | 12:36 AM
johnny.dangerous's Avatar
johnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud of
I did a search for this and this thread came up,, ive got a couple of questions you guys may be able to answer, I pretty much understand the best way to do it is to go with the kit from Loi and I have this saved, is it literally plug and play? I have a 2002 Turbo with the Bose system and PCM1 not the PCM2 MOST system, I presume I can just take out the CD multiplayer as I will use MP3.
Old Dec 2, 2013 | 12:43 AM
Urban's Avatar
Urban has a spectacular aura aboutUrban has a spectacular aura about
Here is mine, just installed a few months ago. Just needed to upgrade the sub woofer I think but pretty much plug and play.
Old Dec 2, 2013 | 12:44 AM
Urban's Avatar
You must have a 6 disc CD system, I was confused with the CD holder so edited my post accordingly.
