Terrible time at the Track
Finally broke my new clutch in so decided to take my car back to the strip to see what it could do. I really just wanted to hit stock ET and Mph...but ended up with much worse. Clutch had no issue but every time I went WOT on 1st or 2nd gear car would just wheel hop and I would shut it down.
Out of 7 runs I only finished 1 with @ 110mph. All the other times I shut it down due to severe wheel hop. So frustrating...
My tire got stuck with all kinds of crap from the track which made wheel hop even worse as the night went on.
Which upgrades will reduce this problem the most? mounts, wheels, suspension...Can't believe I am having this problem on stock power.
Which coil over is best for reducing this problem? Do you guys feather the throttle when you feel wheel hop coming on or just keep on WOT until it eventually hooks up? Maybe I am driving this car wrong...
MT drag radials... 20 psi lets say....
dont need anything else... other then practice...
2001 996TT 3.6L and stock ECU
Yup. All that crap on your tires is supposed to stay on the track. I run Nitto's at 16-18psi. Keep the revs around 3500-4000rpm and slide the clutch out smoothly and quickly while applying generous throttle. Don't dump the clutch at any RPM. Wheel hop is what breaks stuff...like axles...
Do you guys gradually press the throttle on 1st and 2nd? My wheel hop actually wasn't on the launch since I was not launching that hard...1-3k rpm. The wheel hop came on once I stomped on the gas and hit 5500k rpm. Maybe these pirellis just suck. Other AWD cars don't seem to have this problem...(GTR/Audi)
I think I going to go for below:
1. Check mounts
2. Replace all 4 tires
3. Go RWD?
Guys on a similar note can some1 explain to me how the 4WD system in a 996TT works. Is it normal to feel a big jolt when the power is sent to the front wheels? Its been really cold here in the UK over the last few nites and as I've only had the car a short while I've been flooring the pedal in first gear after a gentle pull away just to learn the reactions of the car. the back twitches (LSD doing its work) then it jolts and the front starts hopping. Is this the way its meant to happen?
Jul 29, 2019 11:13 AM
