Short Shifter for 996 TT
Old Dec 2, 2010 | 02:13 PM
rdss's Avatar
rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !
Originally Posted by alex55
Rdss how about a thread about your car and some pics?
I will do that my friend Alex,i just need to find the right good looking chick to improve my car's view
Old Dec 2, 2010 | 02:56 PM
krpt176's Avatar
krpt176 is a splendid one to beholdkrpt176 is a splendid one to beholdkrpt176 is a splendid one to beholdkrpt176 is a splendid one to beholdkrpt176 is a splendid one to beholdkrpt176 is a splendid one to behold
Thank everyone for your very helpful posts.
Based on the reviews sounds like the 997 SSK is the way to go.
I was mainly concerned about compatibility but it seems as though everyone is happy with theirs which sounds great.
Old Dec 2, 2010 | 03:15 PM
996PCarGo's Avatar
996PCarGo is a splendid one to behold996PCarGo is a splendid one to behold996PCarGo is a splendid one to behold996PCarGo is a splendid one to behold996PCarGo is a splendid one to behold996PCarGo is a splendid one to behold996PCarGo is a splendid one to behold996PCarGo is a splendid one to behold
Arrow Imho...
...you should install the billet link while you are in there.
The combination of SSK and link are nothing short of awesome.
I have the Schnell**... others have the EVO etc... Billet links rock !
Check out the B&M shifter installation instructions (pdf. file attached below)...
Check post about marking cables front & rear before removal of old shifter and link.
https://www.6speedonline.com/forums/996/227663-997ssk-ssla-billet-link-installation.html
Then check out the billet link installation DIY below (nicely illustrated)...
http://gallery.rennlist.com/gallery/album122?page=1
Hope this helps...
**Schnell link on sale at Vertex right now... inexpensive !
File Type: pdf
Old Dec 2, 2010 | 03:21 PM
996PCarGo's Avatar
Arrow FYI, the...
...997SSK is made by B&M for Porsche...
997SSK has a similar feel, & slightly longer throw, without metal bushings fore and aft.
IMHO, you should do the billet link as well when you R&R the B&M to SSK.
Originally Posted by gsr355
I bought my car with the B&M short shifter and did not like the way it feels, it's too notchy for me. I just bought a 997ssk off another member on the forum and should be receiving it sometime next week. I'm looking forward to installing after all the reviews I've read about it. I will have the B&M up for sale if anyone is interested in giving it a try.
Old Dec 3, 2010 | 09:48 AM
krpt176's Avatar
excuse my ignorance but what exactly are the benefits to the billet link change?
Old Dec 3, 2010 | 11:13 AM
raineycd's Avatar
excuse my ignorance but what exaclty are the benefits to the billet link change?
It helps your wallet get lighter... Unless you are racing or putting a lot of stress on your shifter...
Old Dec 3, 2010 | 11:39 AM
Simi_996's Avatar
Simi_996 is infamous around these partsSimi_996 is infamous around these parts
I have the 997SSK. It is the only SS I put in from stock, so I can't say if it is better than any others. However, it does feel a little heavy, but very crisp and precise. I would recommend trying others and seeing which one you like best.
Old Dec 3, 2010 | 12:19 PM
porka's Avatar
porka has a brilliant futureporka has a brilliant futureporka has a brilliant futureporka has a brilliant futureporka has a brilliant futureporka has a brilliant futureporka has a brilliant futureporka has a brilliant futureporka has a brilliant futureporka has a brilliant futureporka has a brilliant future
Ok let me clear something up
The billet shift link is used to replace the plastic shift link that are prone to breaking. They connect the shift cables to the bottom of the shifter. Kind of ball and socket set up
I just had mine break and it left me stranded at the roadside.
Now if you want a cheap fix, evoms sells a billet shift link. That can be used with the stock shifter cables.
The better alternative but pricey is to have cup car shifter cables installed. They are thicker and stronger than stock cables and are 100% metal construction no plastic parts that can break.
Also note that the gt3 shift cables don’t have any rubber on them for sound dampening so they might be a little louder than stock
I plan to put gt3 shift cables paired with a 997 GT3 shifter. IMO the 997ssk is just too short.
The gt3 shifter has reinforced shift bushings and is slightly shorter than the regular 997 version. I sat in a gt3 recently and the shifts are perfect. They are a perfect throw and the gears go in perfectly. Unlike the ssk which sometimes wont engage 3rd easily.
Now I’m no expert, I’m just sharing my observations.
Here is a great link to show you the cup car cable comparison.
http://forums.rennlist.com/rennforums/997-gt2-gt3-forum/592174-996-cup-shift-cable-to-the-fix.html
Mike
Old Dec 3, 2010 | 02:57 PM
TDarby's Avatar
TDarby is just really niceTDarby is just really niceTDarby is just really niceTDarby is just really nice
does anybody in northern nj have the 997 ssk that i could check out
Old Dec 3, 2010 | 03:09 PM
996PCarGo's Avatar
Arrow Despite what our fellow 6speed member says...
...the billet link replaces a poorly made plastic piece that is more prone to failure. Whan it fails it leaves you stranded as you will be unable to shift.
The billet piece has a robust nylon socket to couple with the end of the shifter instead of the totally inferior and inherently weak stock plastic cup.
Wallet only "affected" to the tune of $33 to $85 depending on link choice.
To me its a no-brainer. I have the link and forward shifting peace of mind.
2 cents... deposited.
Old Dec 3, 2010 | 04:14 PM
ReeknHavic's Avatar
ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !
Of all my mods my 997ssk is one of my favorite ones. I got mine a few years ago and simply love it. I had a stock 996 shifter (horrible) so there wasn't anywhere to go but up from there.
Old Dec 3, 2010 | 08:18 PM
JohnN's Avatar
JohnN is infamous around these parts
I am in North Jersey! Just ordered a 997SSK. PM me and you can check it out when I install this week!
John
Jul 29, 2019 11:13 AM
pnoob2
Oct 31, 2015 06:34 PM
steve.rinaldi
Sep 5, 2015 06:52 AM
LiquidElephant
Aug 27, 2015 06:17 PM
ECS Tuning - VW
Aug 19, 2015 08:58 AM
