996 tt door trim
Old Dec 15, 2010 | 04:16 AM
escort racing's Avatar
escort racing is infamous around these parts
996 tt door trim
Hi guys I have a slight rattle inside my drivers side door,And would like to know how to take door trim of with out setting off drivers side air bag,Any help would be great. peter!!!!!!
Old Dec 15, 2010 | 04:41 AM
alex55's Avatar
alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !
Take out the cable from the battery first of all and you will be fine. I think that you may find around here some DIY
Old Dec 15, 2010 | 08:31 AM
Slider's Avatar
There are two large bolts under the forward plastic trim (take the plastic trim off first) and one small Phillips screw. You have to pull out the little air bag label and remove the little bolt behind it. There is a small plastic screw inside the storage cubby. Remove the plastic trim behind the side mirror. Then work your way around the edge to pop all the little clips out. Lift up to take the panel off. You'll have to disconnect a few wires while you are at it. Your rattle is probably the screws holding the speaker enclosure in place. Put a little 1/2 inch square of dynamat on the screws after they are tightened - that should stop them from coming loose again. The second time you do this it will take you about 3 minutes.
Old Dec 15, 2010 | 09:28 AM
buzzm's Avatar
buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !
my rattle wasnt screws, i'm pretty sure it was a cable rattling against the metal of the door, i added some dynamat and taped all cables more securely and the rattle went away
getting rid of rattles is possibly one of the most satisfying things in the world
Old Dec 16, 2010 | 04:58 AM
Thanks guys for all your help, But slider were abouts are you, Im in scoresby melb should try to chatch up.
Old Dec 16, 2010 | 11:22 AM
Slider's Avatar
Hey Escort - happy to meet up, but I think it's going to be a long ride for one of us - I'm in Canada!
Old Dec 18, 2010 | 05:21 AM
Hey slider i think your right,
RallyBird
Oct 7, 2015 01:20 PM
SRC4S
Sep 1, 2015 09:22 AM
pogeybait
Aug 28, 2015 04:47 PM
spreeon
Aug 27, 2015 08:14 PM
