Console shelf - Double Din Install
Old Dec 18, 2010 | 11:51 AM
JSBear's Avatar
JSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond repute
I'm installing a double din headunit, I purchased a kit that includes the faceplate to relocate the HVAC down to the very bottom. Currently I have a small shelf in this position, which I have removed.
Prior owner had installed an Alpine XM standalone RF unit in the the 2nd position from the bottom, I have removed this piece of RF junk. So I will need to put a shelf in this position (2nd from bottom). It doesn't look like I can just move the shelf up as the contours in the bottom position are much different. I have a 2002, I assume I can order a shelf ? Does anyone happen to know the part number(s) to add shelf here ?
Much appreciated.
Old Dec 18, 2010 | 12:54 PM
RickyN F355's Avatar
RickyN F355 is infamous around these partsRickyN F355 is infamous around these parts
pics to how mine looks...i didnt do any of the work but here is what the end product looks like...
https://www.6speedonline.com/forums/...o-my-03-a.html
Old Dec 18, 2010 | 05:10 PM
JSBear's Avatar
Thanks for the pics, problem is
I don't have the middle shelf (2nd from bottom), so I can either order one, or install the HVAC in the second spot from the bottom, I would then have to grind down the original trim piece to make it fit, since my double din kit came with the factory piece to move the HVAC to the bottom, it make be easier to just order a shelf that will fit the second position from the bottom.
Was hoping someone may know the part number.
Hopefully this makes sense, I assume them make them ?
Old Dec 18, 2010 | 09:51 PM
Duane996tt's Avatar
Duane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond repute
Call Sunset Porsche. They can fix you up with all the factory trim parts so your center consol doesn't looked hacked up.
Sales@RSW
Sep 3, 2015 09:34 AM
Steven997TT
Aug 27, 2015 02:56 PM
gulf gt
Aug 27, 2015 10:27 AM
