oil change question - almost done
Almost through an oil change and had a question. When changing the filter, the old filter had a single rubber washer in the final groove. the new filter came with a single rubber washer as well.
The Oil Change DIY on Renntech says to replace both rubber oil washers?
I assume a single is all that is needed?
Keith
Keith
HI,I have been changing my own oil and filter for over 2 yrs now,,,,And I only have had the large O ring for the outside canister,where the top of the threads are, that the filter fits in......So,what other small o ring is there??Unless you are talking about the solid o ring for the drain plug...
https://www.6speedonline.com/forums/...-m97-70-a.html
There should be a gasket for the filter, and small crush rings for the plugs. I'm not sure about the turbochargers, as VTG turbos do not have drain plugs.
That does clear things up. I guess I'll just wait till the next oil change to replace. They really should make this part of the oil filter kit as I'm sure I'm not the only one who didn't order the right parts.
Keith
Keith
Hi Guys,,,,,Just wanted to let you know this......I went to two local Porsche dealers to get that little o-ring.......And Both said they do not stock them and never did......Talked to the Porsche mechanics there.....And they said they never changed those???????
That is strange that the dealers said they did not have them -- I just got a filter and the crush washers and o-rings from my dealer this morning (Hennessy in Atlanta) and my service advisor specifically pointed out to me the large and small o-rings and told me where both of them go. I seem to recall a similar small o-ring on my E46 M3 as well.
YES,I agree......So,when I change my oil this weekend,Chicago is going to have a heat wave,,50 temps......lol....I am going to take a close look at that small washer for wear,crush thickness .And then find out which deal in the surrounding area has them......But I would bet ,when someone gets it done at those dealers that I went to,they get charged for that o ring in there oil change.........Have a great day
Keith
Keith
So do some kits offer both small and larger O-rings while some do not? I know that BMW has a kit for oil changes - it comes with all the O rings, and washer etc...
Does Porsche not have the same for the 996TT? If so is it not standardized to include the same items??
http://www.suncoastparts.com/product...de=996ttoilfil
Based on my invoice, it appears that the filter and large o-ring come together, but then there are separate part numbers for the small o-ring and the 4 crush washers (2 for the turbo drain plugs, one for the crankcase, one for the oil tank). So it doesn't appear that there is an official Porsche "kit." I think Suncoast sells all of them together as a package, except I am not sure if they include the small o-ring or not.
