Volumetric Efficiency Comparo
Old Dec 31, 2010 | 03:13 PM
TTdude's Avatar
TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !
Mike was kind enough to send me a datalog of one his runs. So I compared his VEs (996t, A28s) to mine (997.1t, upgraded vtgs). Mike ran a very fast 5.5s 60-130 (4th gear, 0 shift) and my set-up did a 6.9 (4th, gear, 0 shift). While there is nothing better than real-world data, VEs are interesting in that engine output can be compared without secondary factors like car weight, tailwind, % decline, etc... There is a pretty dramatic difference in VEs as would be expected but look at the low-mid range and area under the curve. Very impressive. For reference, a completely stock 997.1t VE will max out around 185.
Thanks again Mike for sharing your data with me. Happy New Year Bro!
Old Dec 31, 2010 | 03:56 PM
The Bogg's Avatar
Wow! Those A28s are really something, but I guess that was obvious from the 5.5second time!
Old Jan 1, 2011 | 12:14 AM
MBailey's Avatar
Dave,
Thanks for going to the trouble of calculating and ploting my VE!!
For those of you that dont know Dave, he has a tremendous grasp of the theory and science behind turbocharging and engines. He has tried to show me how to express VE mathematically.
For those of you that are like me, some explanation might be helpful. Volumetric efficiency (in reference to gas engines) is a measure of how well an engine can move air and fuel in and out of the cylinders. It is expressed as a ratio or percentage volume of fuel and air actually admitted into the engine compared to the piston displacement volume. Thinking of an engine as an air pump, the greater power is produced by pumping more air and fuel through the engine/unit time (ie increasing VE).
Typical auto engines run VEs of 85-90%. DOHC, multiple valve/cylinder engines can have VEs above 100% up to 130%. Forced induction engines, like ours, can have VEs approaching 300%.
One point I would add to Dave's plot is that VE in a turbo engine is affected by more factors than just turbo choice. The engine's efficiency is affected by ease of getting air/fuel into and out of the engine ie intake, fuel system, and exhaust flow. Thus, I believe, the above differences in VE probably involve more than just efficiency of A28s vs. modded VTGs.
If you have any questions, ask Dave!!
Old Jan 1, 2011 | 08:32 AM
bonehead's Avatar
bonehead Is a GOD !bonehead Is a GOD !bonehead Is a GOD !bonehead Is a GOD !bonehead Is a GOD !bonehead Is a GOD !bonehead Is a GOD !bonehead Is a GOD !bonehead Is a GOD !bonehead Is a GOD !bonehead Is a GOD !
Phew. Thanks Mike for the explanation. Though it was a given that everyone knew the meaning of VE
oh and thanks Dave for doing all the work:P
Old Jan 1, 2011 | 08:57 AM
bbywu's Avatar
Dave, what size VTGs are you running?
Old Jan 1, 2011 | 09:04 AM
FAST FWD's Avatar
FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !
Interesting data. Could you tell us more about how volumetric efficiency is calculated? Is it perhaps related to the "Engine Load" reported by Duramteric?
Thanks,
Jon
Old Jan 1, 2011 | 09:12 AM
bbywu's Avatar
Dave's going deep into comparing these turbos. + rep for doing the math! This is the data that many members are looking for when one tuner tells us how much better their turbos are. Better info than a dyno, which fails to show boost threshold and other parameters.
Dave, do you have an easier way to calculate this? My understanding is 3 parameters need to be logged from the sensors:
Engine speed, MAF rate, and IAT.
Once you have that info, you calculate for d2
t1 = Temperature of air for a known density (32 °F @ 0.0808 lb/ft3)
t2 = Temperature of the intake air measured by Durametric
d1 = Density of air for a known temperature (0.0808 lb/ft3 @ 32 °F)
d2 = Density of the intake air (lb/ft3)
once you have d2, you can calculate the two major variables for VE:
AVF = Actual volumetric flow rate (ft3/minute)
MFk = Mass flow rate taken from Durametric (lb/minute)
d2 = Density of air for the intake air (lb/ft3)
and
rpm = maximum design rpm
TAF = Theoretical air flow (ft3/minute)
VE = Volumetric efficiency (100% theoretical)
ED = Engine displacement (in3)
ES = Engine stroke (2 for a four stroke engine)
C = Conversion factor from in3 to ft3
to plug into this:
Old Jan 1, 2011 | 11:25 AM
FAST FWD's Avatar
Thanks,
In the expression for TAF, are you sure that VE appears in the numerator? Seems circular definition of VE from the next equation.
Jon
Old Jan 1, 2011 | 11:36 AM
bbywu's Avatar
VE expressed in that equation should be 1.00 (theoretical volumetric efficiency.) At least that's how I understand it (I didn't come up with this myself...just info from someone else's explanation.)
bob
Old Jan 1, 2011 | 12:18 PM
TTdude's Avatar
Hey Boggster, You might want to reconsider vtgs and go with a pair of alphas.
Originally Posted by MBailey
Dave,
Many thanks Mike but you're way too generous! I just like fiddling around with equations and couldn't have described VE any better than what you just said. I certainly didn't invent any thing here that isn't already known. One disclaimer-- I can't claim to be an expert by any means but I figure if I threw something out there that wasn't right then a true expert would correct me.
I believe the compressor is 63.5 with clipped turbine. As you know, when I first started this modding business, I was truly clueless but since a significant amount of my income was going into my car, I figured I better educate myself.
Thanks Ed. It's all fun and keeps me out of trouble. I hope you're enjoying your "new" ride. It would interesting to compare your set-up to Mike's, since the supporting mods are more similar than mine.
Thanks,
Jon
The equations Bobby listed are what I used to plot the data. Engine load is a calculated parameter and is closely related to VE, if not the same in some cases. There are different ways to calculate engine load and I do not know how the motronic does this. I've asked around but have never gotten an answer. If you calculate your VE and compare it to what Durametric Engine Load reads out, the numbers are close but not exactly the same.
That is correct. I have an excel spreadsheet that I programmed in the equations so all you have to do is input RPM, MAF, and IAT and it spits out VE. MBailey's data is below. Give me a while and I can upload the excel spreadsheet so people can download it and plug in their own values.
Old Jan 1, 2011 | 01:04 PM
TTdude's Avatar
VE Spreadsheet
Well, I tried to upload the spreadsheet but evidently Excel is not a file type that is acceptable for uploading. So if you want me to send you the spreadsheet just email me at ttdude997@gmail.com.
All one has to do is to input RPM, MAF, and IAT from your datalog. It does not necessarily have to be from Durametric although the spreadsheet is designed to use metric units which Durametric records. Use the plotting function in Excel to generate your graph. This calculation assumes air density at sea level and 3.6L engine. A little tweaking of the density parameter would be necessary if you're running in the mountains or displacement for stroked engine. Peak VE would correspond to peak torque. This is like a "poor man's" dyno. Have fun.
Old Jan 1, 2011 | 01:55 PM
emadelta86's Avatar
emadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond repute
Oh great!! This is some GOOD info...thanks TTdude!
Old Jan 1, 2011 | 03:28 PM
996ttalot's Avatar
996ttalot has a reputation beyond repute996ttalot has a reputation beyond repute996ttalot has a reputation beyond repute996ttalot has a reputation beyond repute996ttalot has a reputation beyond repute996ttalot has a reputation beyond repute996ttalot has a reputation beyond repute996ttalot has a reputation beyond repute996ttalot has a reputation beyond repute996ttalot has a reputation beyond repute996ttalot has a reputation beyond repute
TTDude - just sent you my file for my set up which would be good to graph on your original graph.
Old Jan 1, 2011 | 03:32 PM
ttboost's Avatar
Have you done any 60-130's or any other performance testing? I am looking into 20g's and was looking for baseline info. I realize you are a Tip, but it would be close enough.
Old Jan 1, 2011 | 03:38 PM
996ttalot's Avatar
I am in the list with 6.66 60-130 but that was at 1.3 bar. I haven't had a real chance to improve on that but I know she will do high 5 seconds for sure at 1.5bar.
Here are some testing figures.
New record at Bruntingthorpe (20/11/2010)
0-100 in 6.27 secs (1.5 bar)
0-138.9mph in 10.82 secs 1/4 mile. (1.5bar)
Current Performance times (Vbox verified at Bruntingthorpe 14/10/2010)
Speed v Time (1.3bar)
0-60 3.2
0-100 6.6
0-150 13.7
0-160 15.8
0-170 18.4
0-180 21.8
0-186 24.0
0-200 30.8
0-200 unverified (no SD card but photo) of 29.8
In terms of speed v distance (1.3bar)
1/4 mile 135mph
1/2 mile 165mph
3/4 mile 182mph
1 mile 192mph
1.19miles 200mph
Other verified vbox runs.
0-60mph 3.3sec @ 1.3bar
0-100mph 6.6sec @ 1.3bar
0-130mph 10.48sec @ 1.3bar
60-100mph 2.67 sec @ 1.5bar
60-100mph 3.05 sec @ 1.3bar
0-150mph 14.3sec @ 1.3bar
0-150mph 13.89sec @ 1.41bar
60-130mph 6.66 @ 1.3bar
1/4 mile @ 10.81 @ 135.3mph
I just haven't had a real chance at 1.5 bar with good conditions and I haven't done a dedicated 60-130 run for a long time. Will do so in the next month.
