Does anyone have a dyno of a K24/18G WITHOUT an Exhaust?
Old Jan 11, 2011 | 08:20 AM
seth_horwitz's Avatar
seth_horwitz Is a GOD !seth_horwitz Is a GOD !seth_horwitz Is a GOD !seth_horwitz Is a GOD !seth_horwitz Is a GOD !seth_horwitz Is a GOD !seth_horwitz Is a GOD !seth_horwitz Is a GOD !seth_horwitz Is a GOD !seth_horwitz Is a GOD !seth_horwitz Is a GOD !
I really don't want to change my exhaust, have already flashed my K24s, and am thinking about going to the 18g setup for more power. I know that the stock exhaust choked out some power in the high rpm range when I originally did the flash. I'm curious how the 18g dyno would look while maintaining the same exhaust restriction. I have a Tip, and I don't want to deal with drone, so I'm told that the Europipe Quiet is really the only option if I want to upgrade the exhaust. I want to see how much power I'm leaving on the table before I spend $5G AND make my car louder than it already is. (The Euro is getting beaten up, though, so at least the exhaust is cheaper than it was last year. ) To be honest, it's more about the noise than the money, though. Thanks.
Old Jan 11, 2011 | 01:00 PM
johnspeed's Avatar
Hi,No......BUT.......I was chipped[GIAC] for my first mod with the k24's with a stock exhaust it did not spool like I thought it should have.I was in the same boat as you with sound....I picked the Cargraphics Medium sound/TUV approved.It woke up the car /response noticably....Happy with power increase,let the map work, and the sound was just enough to still make it no bother.....Made 503 H.P. on a 2 wheel dyno jet with that combo.....Maybe I might sell this system to get a more free flow/louder one because of my K24/18 set-up now??????Hope this helped.......
Old Jan 11, 2011 | 01:28 PM
Mr Freefall's Avatar
Mr Freefall is infamous around these parts
If your gbox (tip) is std, then the clutch pack in the box will not withstand the k24/18g set up. There is too much power for the box to handle. They have to be upgraded, and the TCU has to be upgraded as you go over the boundarys of the tq limits.
They gbox will start to slip in 3rd gear, then you will need a rebuild.
Mr F
Old Jan 11, 2011 | 01:37 PM
emadelta86's Avatar
emadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond repute
You may want to give a try to Ken's modified stock exhaust...
Old Jan 11, 2011 | 01:44 PM
XLR82XS's Avatar
If I ever run 24/18s on my car with stock exhaust I'll glady throw it on my dyno and post results.
Old Jan 11, 2011 | 01:53 PM
BlackHorseTurbo's Avatar
BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !
Mr F
mine didn't hold up to k16/16g's. Try the Miltek Sport exhaust, NO drone at all on the tip.
Old Jan 11, 2011 | 02:03 PM
sc_trojan's Avatar
sc_trojan has a spectacular aura aboutsc_trojan has a spectacular aura about
well, you should have bought my alpha 28s that were for sale and now sold the alpha 28s will do much better than the 24/18s on a tiptronic. I know because I had the 24/18s on my car before as well. Like yourself, my wife liked the stock exhaust more than my speedtech x-flow. My car was a tiptronic. It started to slip when I installed the aquamist meth kit.
Old Jan 11, 2011 | 02:41 PM
Wasn't there some other issue before you blew up your box? As the official King of Tips, do you think the 24/18g will work on the stock tranny if I don't puh it too hard? I've heard that the stock box can take up to 700hp (crank).
Same question I asked BlackHorse. -^ Are you sure?
How was the car before the meth kit? What kind of HP were you putting out beforehand, and did the tranny seem to be getting ANY weaker?
Thanks for the help, guys.
Old Jan 11, 2011 | 03:17 PM
ttboost's Avatar
No actual dyno's, but based on my experience, with my car, I would think you could easily get 500whp with 18g's and stock exhaust. I think you might only be able to run 1.0-1.2 bar though. Too much restriction. Counter productive at that point. My FVD exhaust was a 20whp improvement. My car made 525 with 18g's and exhaust alone, so I figure with stock exhaust, that day, 505ish?
Old Jan 11, 2011 | 03:31 PM
skandalis447's Avatar
skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !
I dont think there is a single car with 18g turbos and stock exhaust here...Buy REMUS or Speedtech crossflow exhaust and you will love the drone free sound...on the other hand by leaving your stock exhaust you dont let your turbos operate proper resulting in increased EGT from increased backpressure...that could cause you troubles at high speed runs...Just get the right exhaust for you,dont run the turbos with stock exhaust...
Just my 0,2Euros...
Old Jan 11, 2011 | 03:48 PM
My tranny was fine before it started to slip. 25k miles on it or so at stock boost. It really had troubles at 550whp.
Old Jan 11, 2011 | 03:55 PM
Originally Posted by skandalis447
Just my 0,2Euros...
Thanks, man. Better than 2 cents. (At least today.) Ha.
I don't suppose you were around the 500whp level too long to check the durability, then. I KNOW that I don't want to start messing with the tranny. This argument of going with or without an exhaust seems moot if I'd need to rebuild the tranny, on a car with 10K miles, anyway.
Old Jan 11, 2011 | 04:20 PM
I would feel safe at 500whp on the stock tip. I ran around with a tune and exhaust for about 3 months. But what would that be, 430whp? Low boost for me after my 16/16's was about 525whp and the tranny was just fine with zero noticeable slip.
Old Jan 11, 2011 | 05:26 PM
boca996tt's Avatar
boca996tt is just really niceboca996tt is just really niceboca996tt is just really niceboca996tt is just really nice
is the 16/16 a better set up then the 24/18 for the tip car? better meaning safe for the transmission
Old Jan 11, 2011 | 06:16 PM
What kind of boost were you pushing, producing how much horsepower, before the tranny went boom? My flashed K24s are putting out around 400whp without an exhaust. Couldn't the K24/18g be custom tuned to around 500whp, by keeping the boost down, and keep things safe? I'd think the power curve could be flattened out a bit, as well, as your peak wouldn't be as high, so there's less of a fall-off.
