Wallpaper to share * pix
Old Mar 18, 2005 | 12:01 PM
DJ_Demi's Avatar
DJ_Demi is infamous around these parts
Hello
this is a wallpaper of my car~
(Wallpaper Style : copied from the dub magazine websites)
I would like to share~
and please share some of your Pcar wallpapers here
thx ~
there are 1280 x 1024 at demi911.com
thx
Old Mar 18, 2005 | 01:07 PM
Itzkirb's Avatar
Here's mine...
Old Mar 18, 2005 | 01:41 PM
Greyghost's Avatar
Greyghost is infamous around these parts
Nicely done.
Old Mar 18, 2005 | 02:36 PM
Craig's Avatar
Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !
I have a quick question for the photoshop experts in the house: How do you cut out your car from a photograph in order to put it against a different background. I can not cut it out cleanly using the manual option and the option that distinguishes by colors does not do it effectively.
Thanks for your help,
Craig
Old Mar 18, 2005 | 03:43 PM
Benjamin Choi's Avatar
Benjamin Choi is infamous around these parts
that is one novel of a signature
Old Mar 18, 2005 | 04:23 PM
Z0RR0's Avatar
Z0RR0 has a brilliant futureZ0RR0 has a brilliant futureZ0RR0 has a brilliant futureZ0RR0 has a brilliant futureZ0RR0 has a brilliant futureZ0RR0 has a brilliant futureZ0RR0 has a brilliant futureZ0RR0 has a brilliant futureZ0RR0 has a brilliant futureZ0RR0 has a brilliant futureZ0RR0 has a brilliant future
Craig
I'm not really an expert, but can pull off minor tricks.
Try the Magnetic Lasso tool (it "sees" the contrast between colors). If the colors are too close and it picks too much or too little, you can go with a Mask.
Although more time consuming, a mask allows you to get it perfectly if you have a bit of patience.
Quick tutorial for a mask.
Make sure you are in the correct layer.
Create Mask (by clicking the little circle-in-square icon under your layer list)
Now take the paintbrush, select a soft edge and adequate size (large at first ... but it all depends ont he resolution of the pic, so I can't tell you 200 or 30 ...). Make sure the fore and backgorund are respectively black and white (you can do so by clicking the tiny icon at the left bottom of the color mini-window).
Now paint black everything you don't want to see. If you go too far, swap the colors and paint white ... it will re-appear. Do so, reducing the brush size until the result is acceptable ...
I usually cheat and use a bit of every method (magic wand, magnetic lasso and mask).
I rarely use the Extract tool because I just can't get the hang of it, always makes crappy results.
Old Mar 18, 2005 | 04:28 PM
20C4S's Avatar
Craig i need to show u in house
Old Mar 18, 2005 | 05:03 PM
Craig's Avatar
Thanks Zorro . . . Im going to take you up on that Arling
Craig
Old Mar 18, 2005 | 05:22 PM
20C4S's Avatar
not hard if u have a high res pic to work with. u need to be able to zoom in to see what u're actually selecting.
COBB Tuning
Jan 5, 2016 07:06 AM
Oct 2, 2015 02:23 PM
markski@markskituning
Oct 1, 2015 03:44 PM
