White Gauge Face
Old Feb 27, 2011 | 10:41 AM
LO_996tt's Avatar
LO_996tt is infamous around these parts
White Gauge Face
I am considering adding white gauge faces to my cluster. I am looking for a vesion with the "turbo" script in the tach (see pic).
I have noticed some Factory tachs have the script and some do not. Same with GT2 and GT3--some w/ some w/o.
Questions #1: Which after market is closest to factory look/function(lighting) without spending a fortune? (prices are all over $35-$350)
Question#2: Is there a vendor that sells faces with the script?
Questions#3: Is there a "script" font available where I could create my own decal and apply it to an after market gauge? (BTW: I have searched everywhere for the font--no luck)
Thanks for your help!!
Old Feb 27, 2011 | 11:20 AM
dark911's Avatar
dark911 has a spectacular aura aboutdark911 has a spectacular aura aboutdark911 has a spectacular aura about
I found something on eBay. FVD sells them too, but cost over $700.
Old Feb 27, 2011 | 11:26 AM
jpflip's Avatar
A lot at Pelican but no "turbo" writing... http://www.pelicanparts.com/catalog/...INTdsh_pg1.htm
Old Feb 27, 2011 | 12:35 PM
Nor Cal Turbo's Avatar
Nor Cal Turbo Is a GOD !Nor Cal Turbo Is a GOD !Nor Cal Turbo Is a GOD !Nor Cal Turbo Is a GOD !Nor Cal Turbo Is a GOD !Nor Cal Turbo Is a GOD !Nor Cal Turbo Is a GOD !Nor Cal Turbo Is a GOD !Nor Cal Turbo Is a GOD !Nor Cal Turbo Is a GOD !Nor Cal Turbo Is a GOD !
I've been looking at Meister Auto Works. Read from some previous threads that they have good quality gauge faces. They will put whatever writing you desire in the gauges, turbo, GT2, badass ****, etc.
www dot meistergaugefaces.com/html/gaugefaces/996.php
Old Feb 27, 2011 | 02:49 PM
LO_996tt's Avatar
I am thinking of going slilver/grey on the sides and white on the tach only.
Thoughts?
Old Feb 28, 2011 | 05:19 AM
pete95zhn's Avatar
pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !
I bought mine from here: http://stores.ebay.de/Heiler-Tachode...id=p4340.l2563
Serves also in English. Full set with that "turbo" text €99,- . Main reason for change was US-->Euro conversion, but that text was a nice addition.
While in there also changed broken shafts for dim & clock and installed new ***** for those.
Old Feb 28, 2011 | 06:00 AM
MBailey's Avatar
Its a very tedious job to change the faces, so be prepared for a PITA!
Old Feb 28, 2011 | 07:17 AM
emadelta86's Avatar
emadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond repute
Where did you take the shafts Pete??
Old Feb 28, 2011 | 07:25 AM
pete95zhn's Avatar
brianp@nfld.com
HI PETE
Shafts are still available $39.95 each and shipping is $6.95 total for one or more shafts,..
I accept Paypal, check, money order, cash.
Brian
Old Feb 28, 2011 | 12:29 PM
LO_996tt's Avatar
Pete-- are these overlay type or do you have to take off the old and install the new ones?
The ones from "whitegauges.com" are over-lays and are advertised "easy" to install... needles don't need to be removed.
http://whitegauges.net/products/2002...02%252d05.html
Old Feb 28, 2011 | 01:37 PM
pete95zhn's Avatar
Not overlays, see the picture... Anyway the whole job took about 2 hours. Three if removing and installing from & to the car is counted.
Old Feb 28, 2011 | 01:57 PM
emadelta86's Avatar
How would you judge the quality of these? I mean, fit and finish, colour, etc..
Old Feb 28, 2011 | 02:02 PM
LO_996tt's Avatar
Pete-thanks--
Looks like the "turbo" is backlit, yes?
Old Mar 7, 2011 | 06:26 AM
pete95zhn's Avatar
"turbo" could be backlit, ie it's transparent, but unfortunately there's no source of light in that area.
Quality:
+fitment is perfect
+scales are correct
+colour is what I wanted, also lettering can be chosen
+dimmimg works, so transparent areas are not too thick
(-) those coutouts are slightly rough, but that's paractically invisible when the instrument panel is installed
- blinker and driving light indications are not stealth, as they're in an original. Again when the instrument panel is installed that's almost invisible, unless sun shines directly to it, or you take a photo with a flash. Then it's IMO annoying, but I'm slightly ****...
What's a big + is that you can for example alter the redline...in mine it start's from 7k, like my limiter.
Old Mar 7, 2011 | 10:44 AM
Dr Kans's Avatar
Dr Kans is infamous around these parts
I love the WHITE !
How do you get to them to replace, what has to be removed?
Feelgood MD
Mar 24, 2016 09:35 AM
ss2z06
Sep 9, 2015 11:46 AM
zoo
Sep 3, 2015 10:46 AM
