DIY Clutch Install
Old Mar 9, 2011 | 04:16 PM
  #31
IAPorscheDoc's Avatar
IAPorscheDoc has a reputation beyond reputeIAPorscheDoc has a reputation beyond reputeIAPorscheDoc has a reputation beyond reputeIAPorscheDoc has a reputation beyond reputeIAPorscheDoc has a reputation beyond reputeIAPorscheDoc has a reputation beyond reputeIAPorscheDoc has a reputation beyond reputeIAPorscheDoc has a reputation beyond reputeIAPorscheDoc has a reputation beyond reputeIAPorscheDoc has a reputation beyond reputeIAPorscheDoc has a reputation beyond repute
Originally Posted by Talisman013
That is EXACTLY right. Whoa, I am glad you reminded me of that, I was fearing the worst. You cannot put it on wrong. I should have taken more pics. I had the intention of doing the DIY all along, but when you are in the swing of things and making progress, you forget to take pics/video.
Not only is there an alignment pin, but unless you get it lined up with the pin, the bolt holes will not line up. They look perfectly even, but if you rotate the flywheel in any other direction on the crankshaft, you can't get all 9 bolts to line up with the holes. Essentially, it is impossible to put it on wrong.
Old Mar 10, 2011 | 06:24 PM
  #32
pumalex's Avatar
pumalex has a reputation beyond reputepumalex has a reputation beyond reputepumalex has a reputation beyond reputepumalex has a reputation beyond reputepumalex has a reputation beyond reputepumalex has a reputation beyond reputepumalex has a reputation beyond reputepumalex has a reputation beyond reputepumalex has a reputation beyond reputepumalex has a reputation beyond reputepumalex has a reputation beyond repute
here, i took a picture today of a transmission i removed
Old Mar 10, 2011 | 06:44 PM
  #33
tonka858's Avatar
tonka858 has much to be proud oftonka858 has much to be proud oftonka858 has much to be proud oftonka858 has much to be proud oftonka858 has much to be proud oftonka858 has much to be proud oftonka858 has much to be proud oftonka858 has much to be proud oftonka858 has much to be proud oftonka858 has much to be proud of
you change out the Pilot bearing?
Old Mar 10, 2011 | 08:07 PM
  #34
Talisman013's Avatar
Talisman013 has a reputation beyond reputeTalisman013 has a reputation beyond reputeTalisman013 has a reputation beyond reputeTalisman013 has a reputation beyond reputeTalisman013 has a reputation beyond reputeTalisman013 has a reputation beyond reputeTalisman013 has a reputation beyond reputeTalisman013 has a reputation beyond reputeTalisman013 has a reputation beyond reputeTalisman013 has a reputation beyond reputeTalisman013 has a reputation beyond repute
Yes, it comes in most flywheels.
Old Mar 20, 2011 | 11:52 AM
  #35
Glacier's Avatar
Glacier is a jewel in the roughGlacier is a jewel in the roughGlacier is a jewel in the roughGlacier is a jewel in the rough
Hi,
Thanks to this DIY I have gone ahead and attempted my own clutch / flywheel swap. I have been able to do it using larger jack stands! So far so good. The transmission is completely out. I ended up removing the starter which allowed me to push the rod and cap out, and it worked well.
When I am done I will try to post comments on the few things I got stuck on.
However, I am now stumped. I am assembling the new clutch release bearing on to the new pressure plate, and I am not 100% confident that I have done it right. In order not to hijack this thread, I started a new thread:
https://www.6speedonline.com/forums/...-question.html
Can anyone confirm that I have assembled it correctly?
g
Old Mar 20, 2011 | 12:08 PM
  #36
0396's Avatar
0396 has a reputation beyond repute0396 has a reputation beyond repute0396 has a reputation beyond repute0396 has a reputation beyond repute0396 has a reputation beyond repute0396 has a reputation beyond repute0396 has a reputation beyond repute0396 has a reputation beyond repute0396 has a reputation beyond repute0396 has a reputation beyond repute0396 has a reputation beyond repute
Thanks for sharing your experience, great write up – with videos too!
Old Mar 20, 2011 | 02:25 PM
  #37
tjj7ff's Avatar
tjj7ff is infamous around these parts
Assume writeup!!! Thanks for taking the time to share your experience.
Old Apr 2, 2011 | 02:58 PM
  #38
DubSport's Avatar
DubSport is infamous around these parts
Thanks for your thorough contribution!!
Old Apr 3, 2011 | 02:34 PM
  #39
Everyone is very welcome. It was fun doing it.
Thank you puma, porschedoc and anyone else who adds to this DIY. Every bit of info is going to help the guy who is on the fence about doing his own clutch job. If I had pumas advice when I did mine, I would have saved 45 minutes at least.
Old Apr 4, 2011 | 09:29 PM
  #40
JBFMCAR's Avatar
JBFMCAR is infamous around these partsJBFMCAR is infamous around these parts
Great write up and great job but i think i will leave this one to the pros!
Old Apr 28, 2011 | 11:25 PM
  #41
code7rpd's Avatar
code7rpd has a spectacular aura aboutcode7rpd has a spectacular aura about
Great write up! I plan on doing mine in a few weeks. What kind of tranny Jack did you use? I don't want to spend a lot but don't want to get a cheap unit that may cause the tranny to fall. How much does the tranny weigh anyway?
Old Apr 29, 2011 | 01:18 PM
  #42
TurboTodd's Avatar
TurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond repute
Wouldn't be nice if you could just use one of those hydraulic throw out bearing units. Slide the bearing over the transmission shaft and run the lines out the hole. done!
Great write up. Thanks for taking the time to do it.
Old Nov 23, 2011 | 07:48 AM
  #43
smistry007's Avatar
smistry007 has a reputation beyond reputesmistry007 has a reputation beyond reputesmistry007 has a reputation beyond reputesmistry007 has a reputation beyond reputesmistry007 has a reputation beyond reputesmistry007 has a reputation beyond reputesmistry007 has a reputation beyond reputesmistry007 has a reputation beyond reputesmistry007 has a reputation beyond reputesmistry007 has a reputation beyond reputesmistry007 has a reputation beyond repute
excellent write up with pics and video as well!
my clutch is slipping and I need to get it replaced- had I a car lift, I'd attempt it myself after reading your write up! Maybe next time
thanks again
Old Nov 24, 2011 | 05:10 PM
  #44
Glacier's Avatar
Jack Stand Lift
Hey,
It can be done using Jack stands. I did it last winter. You need 4 large truck jackstands and 2 5ft pieces of 2x4 steel. Put the steel in place between the jacking points on each side of the car. Place your floor jack under the steel, aproximately inline with the front of the door handle (balance point), and jack it up a few inches. Set jack stands and repeat on the other side. Just go back and forth about 4 inches on each side until the car is high enough.
Here's proof!
Old Nov 25, 2011 | 01:05 AM
  #45
Zmydust's Avatar
Zmydust is a name known to allZmydust is a name known to allZmydust is a name known to allZmydust is a name known to allZmydust is a name known to allZmydust is a name known to all
Thats a manly set of stands!
