Need Volk TE37 Offset Help
Old Mar 7, 2011 | 10:41 PM
Y3LO 01's Avatar
Y3LO 01 has much to be proud ofY3LO 01 has much to be proud ofY3LO 01 has much to be proud ofY3LO 01 has much to be proud ofY3LO 01 has much to be proud ofY3LO 01 has much to be proud ofY3LO 01 has much to be proud ofY3LO 01 has much to be proud of
I’m considering purchasing a set of 19” TE37 wheels for my 996 turbo.
For the rears, it seems they offer 19 x11 with either +45 or +63 offset. As for the fronts they only offer 19 x 8.5 (either +45 or +52) or 19 x 9.5 with a +40.
I’d like to run a 305/30 out back and 235/35 up front. I've rolled the fenders to add additional clearance.
Can anyone suggest which would fit best?
Thanks.
Old Mar 7, 2011 | 10:50 PM
ETW 360's Avatar
ETW 360 has a brilliant futureETW 360 has a brilliant futureETW 360 has a brilliant futureETW 360 has a brilliant futureETW 360 has a brilliant futureETW 360 has a brilliant futureETW 360 has a brilliant futureETW 360 has a brilliant futureETW 360 has a brilliant futureETW 360 has a brilliant futureETW 360 has a brilliant future
19x11 +45
19x8.5 +45
Old Mar 7, 2011 | 10:52 PM
Y3LO 01's Avatar
Thanks. Is it possible to run any wider or is 305 pretty much the limit without running GT2 inner fenders?
Old Mar 7, 2011 | 11:12 PM
TekNiC3's Avatar
TekNiC3 is infamous around these partsTekNiC3 is infamous around these parts
315/25/19 will work with the correct offset.
Old Mar 7, 2011 | 11:15 PM
Y3LO 01's Avatar
Given the above choices, what would you suggest?
Old Mar 7, 2011 | 11:27 PM
ETW 360's Avatar
315/25/19s will fit fine with the 19x11 +45 rears. Thats the most common 19" rear tire size for the car
Old Mar 7, 2011 | 11:31 PM
TekNiC3's Avatar
Agree. You can even run 7mm - 15mm spacers to give a more flush look.
Old Mar 7, 2011 | 11:51 PM
ASLAN's Avatar
ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !
I know it's a hotly debated topic, but to be certain you will not burn up your differential, you have to go with the 315/25 in the rear with the 235/35 up front. Depending on brand of rubber, it may vary slightly also. Some say they have had no "issues" with the 305/30 rear set up with those fronts, but I would not want to confuse good luck with good practice. Do a search and you will find may threads addressing this topic.
Old Mar 7, 2011 | 11:55 PM
ASLAN's Avatar
I just saw you are in SoCal. I just bought a pair of PS2 315/25/19's for a great price locally. PM me if you decide to go that route.
Boldgt
Mar 23, 2016 11:07 AM
3WDistributing
Nissan GTR Vendor Classifieds
Dec 15, 2015 03:42 PM
s6spd
Oct 6, 2015 08:20 PM
Sakred
Sep 30, 2015 03:51 PM
SaviniWheels
Wheels/Tires
Sep 29, 2015 07:04 PM
