Toe Links/Tie Rods with bumpsteer worth the $$?
Old Mar 9, 2011 | 10:17 AM
uurfantasy's Avatar
uurfantasy has a spectacular aura aboutuurfantasy has a spectacular aura aboutuurfantasy has a spectacular aura about
Need some opinions.
I want to make my suspension more predictable and less "jumpy".
I am currently running RUF PSS9's and the rest of the suspension is all stock.
I feel the car to be scary in corners and high speeds and it just doesn't feel planted. I had the car aligned by a reputable shop in Sacramento called G12.
I was advised by my Indy to get tarret toe links and tie rods both with bumpsteer and it would make a HUGE difference in how stable the car felt.
Is this true and are there any other suspension components I should be looking at to help stability and make the car feel as if it's more planted?
Thanks in advance.
Old Mar 9, 2011 | 12:11 PM
GT3 Chuck's Avatar
Administrator
while you can spend the extra money for toe links w/bumpsteer the bumpsteer links are not essential...you would be better served getting the non-bumpsteer tarret toe links but with locking plates so your car will hold it's alignment...otherwise the eccentrics will alter the alignment even with the good toe links...if your car feels that jumpy I would forget the alignment shop you have been going to and make a run to Tony at TC Design in Milpitas...have him corner balance at the same time...you might also want to consider Tarret rear upper monoballs and adjustable drop links front and rear to eliminate sway bar pre-load...do you have the specs for your current alignment and sway settings?
Old Mar 9, 2011 | 12:17 PM
TT Gasman's Avatar
TT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant future
Are you sure about the locking plates? The reason being, I looked into these but a couple of race shops told me it was a non issue on these cars if you have a proper toe link. What symptoms would you see with wandering eccentrics?
Old Mar 9, 2011 | 12:18 PM
uurfantasy's Avatar
Do I need drop links even with stock sway bars?
I do have the alignment specs and my Indy IPB here in Sac were looking them over and he said they looked good.
Bump steer is what my Indy was saying was causing the jumpy feeling.
Old Mar 9, 2011 | 12:25 PM
TT Gasman's Avatar
You can use the OEM drop links, the aftermarket jobs are heavier duty but also very noisy. The OEMs are good enough for the factory GT2 . There is a trade off with suspensions between street and track, every change is a compromise, what's great on the track can be a PIA on the daily commute.
Old Mar 9, 2011 | 12:36 PM
GT3 Chuck's Avatar
Administrator
a non-issue?...yes it is a non issue once you have the locking plates...it might be a non-issue on a race car cuz you would be changing the alignment for every event...but I doubt the eccentrics could hold up under race conditions...the eccentrics on these cars can move (especially when you run Rcomp tires) and your alignment (toe) can change with them...the plates are cheap and will significantly reduce your alignment costs over time...
as for the drop links..they are not necessary..but the oem ones can bend and come apart easily...the adjustable ones are much stronger plus they have the added bonus of relieving sway pre-load as it comes from the factory, which makes sway bar adjustments at the track that much easier
Old Mar 9, 2011 | 01:26 PM
heavychevy's Avatar
Jumpy in the turns is not about Toe links. By scary in the turns do you mean oversteer? The TT is one of the least scary in the turns cars I've ever driven, especially in AWD if that's what you are.
Unless your coilovers are bad or a bad setup, you should not have to buy a whole lot of extra stuff to make it planted in the turns.
Unless your TT is RWD, you should not have any problems feeling stable in the turns. Maybe sway bars at most. I get annoyed whenever dudes are encouraged to spend thousands to drive on the street.
Sound like a damper issue, and the Toe Links won't even come close to fixing that jumpiness issue. Car needs to be lower and stiffer (sways) and have a very good alignment. That should solve the scary in the turns issue.
Old Mar 9, 2011 | 05:04 PM
VID997's Avatar
VID997 Is a GOD !VID997 Is a GOD !VID997 Is a GOD !VID997 Is a GOD !VID997 Is a GOD !VID997 Is a GOD !VID997 Is a GOD !VID997 Is a GOD !VID997 Is a GOD !VID997 Is a GOD !VID997 Is a GOD !
Sounds like your shocks may be setup too stiffly for street use and possibly too much tire pressure (air).
+1 for Tony at TC designs or check with Rich at Jerry Woods in Campbell.
Old Mar 9, 2011 | 05:47 PM
farfinator's Avatar
farfinator is infamous around these parts
+1 GT3 Chuck
And you might consider the ERP A-Arm Solid Mount Discs.
Old Mar 9, 2011 | 07:29 PM
pwdrhound's Avatar
Originally Posted by uurfantasy
Need some opinions.
Thanks in advance.
The question no one has asked is what ride height you are at? The PSS9/10 coilovers have a specific ride height they need to be set up at for the shocks to function properly and avoid hitting the bumpstops. Per the PSS9/10 bilstein installation instructions, there is only a 10mm (20mm for PSS9) variance of ride height adjustment in the front, 5mm in the rear. If you are too low (i.e. GT2 height) and are on the bumpstops, you WILL have issues.
The following is an excerpt from page 7 of the PSS10 mounting instructions published by Bilstein and available on their US website. PSS9 instructions are identical except for the part numbers and the fact that the front setting range is 20mm (75mm-95mm). The same information is also contained in the PSS10 TUV certificate:
"The adjustment range of the spring plates is only approved within the range of the values given in the table below. Adjustments must be set so that the body is level when the vehicle is empty apart from the driver. The LOWEST approved adjustment and the permissible adjustment range are to be entered, stating the fixed axle reference points. (Example, see below).
Manufacturer PORSCHE
ABE-/ EG- BE- No. e13*98/14*0059*..
type designation 996 Turbo (4WD)
model 996 Turbo
FRONT according to permissible axle load and adjusting dimensions
spring part number
main spring E4-FD1-Y623A00
helper spring E4-FD1-Z349A00
shock absorber part number with damping force adjustment VM3-E716
maximum permissible axle load 825 kg (1815 lb)
80 – 90 mm* = 10 mm range
* measurement:
top edge of spring seat down to the center of mounting screw
REAR according to permissible axle load and adjusting dimensions
spring part number main spring E4-FD1-Y518A00
helper spring E4-FD1-Y504A01
shock absorber part number with damping force adjustment BM5-D541
maximum permissible axle load 1250 kg (2750 lb)
205 - 210 mm* = 5 mm range
* measurement:
�� There are no technical objections against the use of all O.E. wheel/tire combinations.
�� The ground clearance in unladen state is reduced by the installation of special springs. It is the approximate equivalent of that of a partially laden stock vehicle. When the vehicle is loaded to the permissible axle loads the ground clearance does not change as compared to the stock vehicle. If spoilers, rear aprons and special exhaust systems are mounted, however, the reduced angle of slope must be noted (travelling on ramps etc.).
�� The specified minimum height of the coupling ball above the road surface with the permissible total weight of the vehicle (acc. DIN 74058) is 350 mm."
I think this makes it clear why some people that drive the car hard encounter problems if they have the suspension height set up at a height other that what is spelled out by Bilstein. Am I the only one that has read this document as it seems to put this "handling mystery" to bed? It seems clear to me now that if you want your PSS9/10s to perform properly on the 996tt, you must mount it at the specific ride height at described in the installation instructions with a 10mm variance in the front (20mm for PSS9) and 5mm variance in the rear. BTW, 10mm is only .39 inches and 5mm is only .195 inches, so clearly the PSS9/10 kit does not give you very much leeway as to where to set the ride height if you want the suspension to perform properly.....
Hope this helps. If I were you, I'd first check and see if you are set up per the above ride height requirements before you start throwing thousands of dollars at parts that in your case probably won't make any difference.
Old Mar 9, 2011 | 08:18 PM
uurfantasy's Avatar
model 996 Turbo
spring part number
* measurement:
* measurement:
I was always aware that for optimal performance out of the pss9's I could not lower my car that much. My car is probably just as low as a gt2 and I have stated that to TC Design and my Indy knows this as well.
They state that the pss9 are not the BEST for my ride height but nonetheless I should be able to relieve the issue I have with handling and stability with rear toe links with bump steer/corner balance/ and proper alignment.
I was wondering also if the front tie rods w/bump steer are very necessary or can be avoided without many drawbacks.
Old Mar 9, 2011 | 10:24 PM
pwdrhound's Avatar
If you are bouncing off the bump stops in the corners your car will feel very unsettled / out of control since your suspension is not able to soak up any bumps and instead is skipping along. I'm not sure why you think rear toe links or a corner balance will sort out your underlying problem. BTW, what are your alignment settings?
Old Mar 9, 2011 | 10:37 PM
uurfantasy's Avatar
That is the thing. The car isn't bouncing off the bump Stops.
That's why I know that the ride height is not the main issue.
Old Mar 10, 2011 | 12:11 AM
VID997's Avatar
Maybe you should go back to a stock dampers and just add sway bars, H&R Springs, and a shock tower brace.
What are your main intentions for the car, street or track?
See attached scan...the stuff in blue...
Old Mar 10, 2011 | 12:15 AM
pwdrhound's Avatar
How do you know that you are NOT hitting the bump stops? Does the car feel unsettled when the road is smooth or only when the road is a little rough?
