Help - Spark plug tightening torque advice
Old Mar 22, 2011 | 07:42 PM
pwdrhound's Avatar
I just did my plugs and coils and had a question with regards to the proper tightening torque for the spark plugs. The Porsche maintenance manual states the tightening torque as 22 ft/lb +2. I was a little confused by this but I initially tightened the plugs to 22 ft/lb and then added 2 ft/lb and tightened to 24 ft/lb. Is that correct or should I have tightened each plug only to 22 ft/lb?? I still haven't reinstalled the intercoolers so I could go back in to re-torque it if need be. Thanks
Old Mar 22, 2011 | 11:32 PM
code7rpd's Avatar
code7rpd has a spectacular aura aboutcode7rpd has a spectacular aura about
It should be + or - 2 which would mean either 18 or 24 ft lbs as the range so you are fine.
rzmnco
Cayenne 955/957
Oct 7, 2025 03:12 PM
su_maverick
Sep 8, 2015 11:12 AM
ECS Tuning - VW
Sep 2, 2015 01:47 PM
ECS Tuning - VW
Sep 2, 2015 01:19 PM
ECS Tuning - VW
Sep 2, 2015 12:58 PM
