which spacers are best
Old Mar 27, 2011 | 07:40 PM
snopdog911's Avatar
snopdog911 is infamous around these parts
are any spacers fine for tracking?
which are the best ones to go with?
Old Mar 27, 2011 | 09:21 PM
REVS11's Avatar
REVS11 has a reputation beyond reputeREVS11 has a reputation beyond reputeREVS11 has a reputation beyond reputeREVS11 has a reputation beyond reputeREVS11 has a reputation beyond reputeREVS11 has a reputation beyond reputeREVS11 has a reputation beyond reputeREVS11 has a reputation beyond reputeREVS11 has a reputation beyond reputeREVS11 has a reputation beyond reputeREVS11 has a reputation beyond repute
Bimmec.
Get them at AE Performance (www.aeperformance.com)
Old Mar 29, 2011 | 01:06 PM
rgriep's Avatar
rgriep is infamous around these parts
I was advices not to use any.
Old Mar 29, 2011 | 04:02 PM
KoalaSlim's Avatar
KoalaSlim is a splendid one to beholdKoalaSlim is a splendid one to beholdKoalaSlim is a splendid one to beholdKoalaSlim is a splendid one to beholdKoalaSlim is a splendid one to beholdKoalaSlim is a splendid one to beholdKoalaSlim is a splendid one to behold
None!
Old Mar 29, 2011 | 04:11 PM
2muchtime's Avatar
2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute
what size are you thinking of? front and rear? I track 7mm rear only with no problems
Old Mar 29, 2011 | 04:17 PM
MY996TT's Avatar
MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !
I had H&R (15mm) and some off brand from Ebay (12mm & 9mm); they don't feel any difference to me; and I have been running those off brand pretty hard too. I believe as long as the lugs are long enough, you should be fine.
Old Mar 29, 2011 | 05:35 PM
snopdog911's Avatar
how do you determine the right lug nut length?
Old Mar 29, 2011 | 06:21 PM
MY996TT's Avatar
When I bought the 15mms, I bought a set of lugs from Vivid (don't know how long). I have been using them for 12mm and 9mm also. I tried using the OEM lugs with the 9mm and they were too short. So unless you are running 3mm, I suggest you should get longer sets. PM Vivid of what you need.
Old Mar 30, 2011 | 01:24 AM
ASLAN's Avatar
ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !
Standard lugs have a 29mm shank. So, whatever size spacer you add you need to add at least the same amount in your bolts. I have 7mm front spacers with 38mm bolts, and 15mm rear spacers with 45mm bolts.
Old Mar 30, 2011 | 06:41 AM
Prche951's Avatar
I have the true porsche spacers on my car and they work differently than what others are stating here. My spacers bolt on with the original wheel lug bolts. Then you have studs sticking out of the spacers which you attach aftermarket lug nuts to. This system is solid, the only disadvantage is the extra weight from an extra set of nuts.
Old Mar 30, 2011 | 07:35 AM
MY996TT's Avatar
I had those that came with my OEM Techno wheels; they came with a 17mm (i think) hubcentric spacers since those wheels weren't really meant for turbos.
Those hubcentrics wouldn't work with my HREs (had vibration) and the normal (just a plate) kind worked just fine.
Old Mar 30, 2011 | 07:52 AM
Prche951's Avatar
mine are 15mm rears, no fronts. It basically gives the stock wheelset the GT2 look.
Old Mar 30, 2011 | 08:00 AM
MY996TT's Avatar
I think the Techno wheels come in +63 offset and a 17mm would bring it to +46, which still doesn't look good.
Boldgt
Mar 23, 2016 11:07 AM
djhill
Oct 29, 2015 07:04 PM
DYL 911
Oct 1, 2015 02:47 PM
Pcar991
Sep 29, 2015 05:20 AM
