Meister Gauge Faces - First Impressions
Old Mar 30, 2011 | 06:43 PM
Slider's Avatar
I received my Meister gauge faces today and made some notes while I installed. Overall the instructions are quite good with the few exceptions noted in the writeup below. This was the only place I could find faces with KPH except the other company that sells the faces for $600+.
These faces cost $210 including the "Turbo" script I had added on. It took 30 days from the order date to receive the goods (note they had to go to Canada).
The only thing I am not totally thrilled with is the look with the lights on, but that could be me - what do you think?
Old Mar 30, 2011 | 06:51 PM
tonka858's Avatar
tonka858 has much to be proud oftonka858 has much to be proud oftonka858 has much to be proud oftonka858 has much to be proud oftonka858 has much to be proud oftonka858 has much to be proud oftonka858 has much to be proud oftonka858 has much to be proud oftonka858 has much to be proud oftonka858 has much to be proud of
you have a before with lights on?
I don't think it looks that bad, maybe change the bulb colors.
Old Mar 30, 2011 | 06:56 PM
Slider's Avatar
No, I didn't think to do that, and I'm not putting the old ones back to try it. Can someone with stock gauges post a pic for us?
Old Mar 30, 2011 | 07:30 PM
powderjay's Avatar
powderjay is a splendid one to beholdpowderjay is a splendid one to beholdpowderjay is a splendid one to beholdpowderjay is a splendid one to beholdpowderjay is a splendid one to beholdpowderjay is a splendid one to beholdpowderjay is a splendid one to beholdpowderjay is a splendid one to behold
Gutsy move, tougher than it looks. I messed up some needles on a 944 gauge years ago. Like you said be careful installing them. I like the look of the white nice job.
Old Mar 30, 2011 | 08:34 PM
Jcusa's Avatar
Jcusa is a splendid one to beholdJcusa is a splendid one to beholdJcusa is a splendid one to beholdJcusa is a splendid one to beholdJcusa is a splendid one to beholdJcusa is a splendid one to beholdJcusa is a splendid one to behold
I think it looks good. Based on those pics, can't really tell any difference.
Old Mar 30, 2011 | 11:00 PM
Slider's Avatar
OK, they are starting to row on me. I went out tonight and by the time I came back I was starting to dig the new look. One thing to note, the high beam indicator as well as the signals are not as clear as the OEM ones but it's not that significant in view of the cost.
I included some pics of the OEM tach below. One picture shows the face illuminated form the front, one from the back. You can see the high beam indicator perfectly clearly, the new faces are a little more blurry (even though my pictures are pretty blurry too). Overall I think I am happier with the switch.
Size:  174.4 KBName:  Gauge11.jpg
Size:  136.7 KBName:  Gauge12.jpg
Old Mar 30, 2011 | 11:06 PM
tonka858's Avatar
Yes needles are tough..even fixing cars for 20 plus years I would hold my breath when doing it..more afraid of that then air bags.
If your town has a speedo shop I would take it to them all apart,
and let them do it.be hour or so labor but they won't mess it up
Oh nice write up as well ...
Old Mar 30, 2011 | 11:15 PM
996TWINS's Avatar
996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute
Slider, great pics and write up. Rep point for you.
I am probably going to get the faces from Pelican and have someone else add the "Turbo" script and do the intstall.
Old Mar 30, 2011 | 11:52 PM
dragonman4's Avatar
dragonman4 has a reputation beyond reputedragonman4 has a reputation beyond reputedragonman4 has a reputation beyond reputedragonman4 has a reputation beyond reputedragonman4 has a reputation beyond reputedragonman4 has a reputation beyond reputedragonman4 has a reputation beyond reputedragonman4 has a reputation beyond reputedragonman4 has a reputation beyond reputedragonman4 has a reputation beyond reputedragonman4 has a reputation beyond repute
Looks good. Have you considered changing to a higher lumen bulb to get more light through? Or even an led? Not sure is anyone has tried it or if it's feasible in case there needs to be resistors involved but just a thought.
Old Mar 31, 2011 | 12:03 AM
pete95zhn's Avatar
pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !
I did mine on the other day...and yes, those needles are scary. I broke one from a 944 panel, so I was pretty cautious when removing these. BUT the construction is now different and less prone to braking.
https://www.6speedonline.com/forums/...auge-face.html
tonka858's Avatar
found write of a guy doing it on a dodge
http://dodgeforum.com/forum/2nd-gen-...sh-lights.html
web site selling LED cheap even
http://autolumination.com/74.htm
can not tell from his post though if the bulbs are the twist kind like most cars.
Old Mar 31, 2011 | 12:27 AM
jpflip's Avatar
Very good DIY Slider. Thanks a lot!
Old Mar 31, 2011 | 01:02 AM
dragonman4's Avatar
Nice find. That seems like a logical next step to take things up a notch. Although I bet it will be a pretty big pita to accomplish lol.
Old Mar 31, 2011 | 08:11 AM
looks good with the lights off...
#TeamAIM
Old Mar 31, 2011 | 08:54 AM
Nor Cal Turbo's Avatar
Nor Cal Turbo Is a GOD !Nor Cal Turbo Is a GOD !Nor Cal Turbo Is a GOD !Nor Cal Turbo Is a GOD !Nor Cal Turbo Is a GOD !Nor Cal Turbo Is a GOD !Nor Cal Turbo Is a GOD !Nor Cal Turbo Is a GOD !Nor Cal Turbo Is a GOD !Nor Cal Turbo Is a GOD !Nor Cal Turbo Is a GOD !
Thanks for the write up slider. That process does look like a PITA. Gauges look great with the lights off. Not sure if I dig the look with the lights on, but if you are happy that is all that matters.
