Swapping guage cluster keep mileage???
Old Apr 26, 2011 | 07:39 PM
ek9max's Avatar
ek9max has much to be proud ofek9max has much to be proud ofek9max has much to be proud ofek9max has much to be proud ofek9max has much to be proud ofek9max has much to be proud ofek9max has much to be proud ofek9max has much to be proud ofek9max has much to be proud of
Ok long story short, I'm looking at buying an excellent condition 996 turbo.
The owner tells me that his original guage cluster stopped working, so he purchased a new one from the dealer.
Now my question is..... should I trust what the mileage states on the cluster? Or would he have started back at 0 when he installed the new one?
Old Apr 26, 2011 | 07:56 PM
jpflip's Avatar
You have to get the ecu data (PIWIS, Durametric or PST2) it will give you the engine hours. And the average is about 30 miles per hour.... ex: 1232 hours mean about 36960 miles. It give you rough idea....
Old May 24, 2011 | 08:04 PM
ek9max's Avatar
So the car would read the new clusters' milage unless I read the ECU?
Old May 25, 2011 | 01:03 AM
Duane996tt's Avatar
Duane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond repute
Jp is correct. The ECU will read out the hours on the car even if the cluster has been changed. I would not trust the milage on the cluster unless it was done at a dealer and fully documented. You should do a PPI on it anyway. Check for type 2 over revs etc. PIWIS show all kinds of interesting stuff.
Old May 25, 2011 | 07:29 AM
Mileage is stored in the cluster and when a dealer installs a new cluster they program the mileage into it. ECU has run time, which can vary alot based on how the car was used most of its life. Run carfax and look at the mileage history and you can also request paperwork from the dealer.
#TeamAIM
Old May 25, 2011 | 06:05 PM
jayster's Avatar
jayster is infamous around these parts
The DME logs distance in kilometers, you should adapt the cluster to the DME's figure.
BTW, have the mileage pulled off the DME before you buy....
7thsign
Dec 12, 2015 07:43 PM
Perkman87
Nov 19, 2015 05:31 PM
speedsterr
Oct 26, 2015 09:18 AM
alpha motoring
Oct 2, 2015 12:04 PM
JWrightPNH
Oct 1, 2015 01:21 PM
