2002 Turbo build (from the ground UP)
Old May 8, 2011 | 01:33 PM
hasauto's Avatar
hasauto is infamous around these parts
Picked her up last fall from the auction, Turns out I knew the old owner who smacked it on the track
SO the rebuild has started and should be off for paint by the end of the week!
Old May 8, 2011 | 01:36 PM
jpflip's Avatar
Nice project! If you ever need access to s PST2 or Durametric let me know I think I'm not far from where you are
Old May 8, 2011 | 01:50 PM
hasauto's Avatar
Why are my images comming up one beside the other and not under each other???
Old May 8, 2011 | 03:15 PM
rgriep's Avatar
rgriep is infamous around these parts
Great job!
Old May 8, 2011 | 03:20 PM
ETW 360's Avatar
ETW 360 has a brilliant futureETW 360 has a brilliant futureETW 360 has a brilliant futureETW 360 has a brilliant futureETW 360 has a brilliant futureETW 360 has a brilliant futureETW 360 has a brilliant futureETW 360 has a brilliant futureETW 360 has a brilliant futureETW 360 has a brilliant futureETW 360 has a brilliant future
Good luck with the rest. Is the car going to be painted green like the piping?
Old May 8, 2011 | 03:32 PM
porka's Avatar
porka has a brilliant futureporka has a brilliant futureporka has a brilliant futureporka has a brilliant futureporka has a brilliant futureporka has a brilliant futureporka has a brilliant futureporka has a brilliant futureporka has a brilliant futureporka has a brilliant futureporka has a brilliant future
that exahust is not stock
did you get the car cheap? i hope this rebuild does not set you back too much.
Old May 8, 2011 | 06:43 PM
boca996tt's Avatar
boca996tt is just really niceboca996tt is just really niceboca996tt is just really niceboca996tt is just really nice
nice color
Old May 8, 2011 | 07:43 PM
hasauto's Avatar
Whats PST2 or Durametric ???
Ya will be about 35k when done,, keep in mind I have like 10k in mods....
k24 turbos, fabspeed cats and exhaust, Evoms intake, Evoms diverter valves, 5bar FPR, Utronics Tunned....
But I need HELP first... where does this connector go?? its part of the fuel pump harness but am not sure where it plugs to??
Old May 9, 2011 | 12:16 PM
Apex Factor's Avatar
Apex Factor is a jewel in the roughApex Factor is a jewel in the roughApex Factor is a jewel in the rough
Sorry I can't help you with the fuel pump harness. But nice project; keep the pics/posts going I love watching projects like this.
Old May 9, 2011 | 01:10 PM
Tim941NYC's Avatar
It just so happens that I have the battery and plate under it out. There is only two plugs I can see, the one to the vacuum line and the one that is inside the the foam wrap.
Old May 9, 2011 | 05:55 PM
hasauto's Avatar
Exactly... the vacuum one. does it have a vacuum line connected to it or does it just stay like mine is in the pic..
and the one with the foam arround it,, where does it connect to???
thanks a million!
Tyler
12 hour day and she now looks like this:
Old May 9, 2011 | 08:10 PM
Tim941NYC's Avatar
vacuum line stays open like you have but the foam covered connector is all strapped in tight. I will look under the car tomorrow.
Old May 9, 2011 | 08:26 PM
hasauto's Avatar
Ya so it comes from the same harness as the fuel pump. then goes into a foam thing where there is an extention and then continues to ???
thanks!
Old May 10, 2011 | 07:40 PM
hasauto's Avatar
no news on that connector?
Old May 10, 2011 | 08:10 PM
Tim941NYC's Avatar
Sorry I was in and out of my office all day. I have some mandatory continuing education for my license with NYC for the next two days too. I looked quick and the only thing I could quickly see was maybe the brake pad sensor on pass side? no wire goes behind the tank.
