need help with tire size
Old May 8, 2011 | 09:20 PM
melsta's Avatar
melsta has a spectacular aura aboutmelsta has a spectacular aura aboutmelsta has a spectacular aura about
planning to get some slick for the track but not sure what size to get. i am leaning towards a set of kumho Ecsta V710.
my current rim size are 18x9 in the front and 18x12 in the rear so the question is if i can use the same size tires as my street tires without rubbing or do i have to move one size down for the rears?
Old May 8, 2011 | 10:56 PM
nick49's Avatar
nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !
I have a set of near new OZ Ultraleggera 19" x 8.5, 12 wheels with Hoosier slicks FS. PM me if interested.
Old May 9, 2011 | 08:26 AM
Joe Weinstein's Avatar
You have two choices with the Kumho 710:
for near-stock wheels:
245/35R18 8-9.5" NA 24.8"
285/30R18 9.5-10.5" 11.4" 24.8"
or for your larger wheels:
245/40R18 8-9.5" 9.1" 25.7"
305/30R18 10.5-11.5" 12.3" 25.5"
I know the smaller tires won't rub. I don't know about the
larger ones, but when I wear out my smallers, I will be
trying those larger ones next.
HTH,
Joe
Old May 9, 2011 | 09:59 AM
Tj Hunter's Avatar
Tj Hunter is infamous around these parts
OT - Melsta, high res of your avatar??? Looks VERY nice!
Old May 9, 2011 | 02:36 PM
melsta's Avatar
have you tried the HoosierA6 and R6? any rubbing with the 245's up front? so i should stay away from the 315's for the rear? Thanks
HTH,
Joe
Old May 9, 2011 | 02:37 PM
melsta's Avatar
i think its in my old computer i'll try to look for it
Old May 9, 2011 | 02:53 PM
For Hoosier, for stock wheels:
P255/35ZR18 10.3" 24.8"
P285/30ZR18 10.9" 24.9"
for your larger wheels,
P245/40ZR-18 M 9.3" 25.3"
P315/30ZR-18 M 11.4" 25.6"
I can't be sure about rubbing with any big tires.
Old May 10, 2011 | 08:23 PM
joe731's Avatar
joe731 is a splendid one to beholdjoe731 is a splendid one to beholdjoe731 is a splendid one to beholdjoe731 is a splendid one to beholdjoe731 is a splendid one to beholdjoe731 is a splendid one to beholdjoe731 is a splendid one to behold
Hoosiers
Joe, why choose a narrower rear wheel setup for track on stock rims. Wouldn't the logical Hoosier track set up be
R6 245/40/18 8-9.5" rim 25.7" diameter
R6 315/30/18 11-12" rim 25.6" diameter
Old May 10, 2011 | 09:08 PM
Nikolas's Avatar
Nikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant future
For straightline performance the narrower width will have greater forward directional traction. For road course, the one's you have listed will be better.
Old May 10, 2011 | 09:50 PM
I suspect that the larger ones may rub, but if they don't, that would be the way to go.
Old May 10, 2011 | 09:54 PM
Nikolas's Avatar
I have 315/30 rears and they don't rub with stock rims. I just added 15 mm spacers and no rubbing on the outside either.
Old May 10, 2011 | 10:06 PM
And how about the fronts? No rubbing at large steering angles? (I'd tolerate that).
Is your car lowered at all?
COBB Tuning
Nov 9, 2015 08:02 PM
ModBargains
Audi Vendor Classifieds
Sep 1, 2015 05:26 PM
ModBargains
Aug 20, 2015 12:28 PM
Aug 19, 2015 06:35 PM
