PSM/ABS lights on
Old Apr 12, 2005 | 06:59 PM
jaewoo0's Avatar
jaewoo0 is infamous around these parts
Unhappy PSM/ABS lights on
After installing EVO intake, I over revved in the first gear and PSM/ABS lights came on. after 5 minutes ENGINE light came on also.
OMG.. now I have to take it to the dealer.
I tried resetting the ecu and try install intake again but nothing worked.
Old Apr 12, 2005 | 07:02 PM
FAT-911's Avatar
FAT-911 is infamous around these parts
Disconnect the battery for 15 minutes.
Old Apr 12, 2005 | 07:03 PM
jaewoo0's Avatar
also intake didnt fit perfectly.
impression? sound did not change much. you can hear it only when you change the gear you hear BOV kind sound.
but I think I liked performance.
MBailey's Avatar
Its probably an air leak or your MAF is being overwhelmed by the new strong air flow. You could try changing out a with a friends MAF before taking it in. Just a thought but Iam no expert.
jaewoo0's Avatar
I tried disconnecting battery for 10 minutes but still..
Old Apr 12, 2005 | 07:05 PM
jaewoo0's Avatar
I think you are right. I will have to take it to dealer. I have some rattles to fix so...
FAT-911's Avatar
Check your connections and make sure everything has been tightened correctly.
Old Apr 12, 2005 | 07:09 PM
jaewoo0's Avatar
tried
Old Apr 12, 2005 | 07:22 PM
Johnfromjersey's Avatar
Johnfromjersey is infamous around these parts
good luck and please keep us updated
Old Apr 12, 2005 | 07:23 PM
Gilhart Racing's Avatar
Gilhart Racing is infamous around these parts
When you say over-revved, did you simply bounce the engine off the rev-limiter on acceleration or did you miss a downshift and send the rpm's to the moon?
Bouncing the engine off the rev-limiter on acceleration shouldn't hurt the motor as long as you don't make it a habit. On the other hand, missing a down-shift say going from 3rd to 1st can send bit's and piece' out of the exhaust.
Rick
Old Apr 12, 2005 | 07:44 PM
jaewoo0's Avatar
Rick
Bouncing the engine off the rev-limiter on acceleration.
I will keep you updated.
Old Apr 12, 2005 | 07:49 PM
That's good news, it should be fine. Hopefully it turn's out to be something simple.
Rick
Old Apr 12, 2005 | 08:02 PM
gneypiks's Avatar
gneypiks is infamous around these partsgneypiks is infamous around these parts
can you elaborate more on the installation.,you had mentioned it did not fit well?will be recieving mine soon sure hope the fit is better than their rear strut brace!!!!
Old Apr 13, 2005 | 02:13 PM
jaewoo0's Avatar
Tech says too much power caused those problems. I don't think its intake's fault.
maybe my driving was too hard. that caused something break.
tried erasing fault codes but didnt work. so I had to make an appointment on 27th.
Old Apr 14, 2005 | 11:04 AM
MBailey's Avatar
Did you try putting the old airbox back on and see if codes disappear?
