996TT buyer's guide and information thread
Old Jun 28, 2011 | 08:35 AM
RFFG's Avatar
RFFG Is a GOD !RFFG Is a GOD !RFFG Is a GOD !RFFG Is a GOD !RFFG Is a GOD !RFFG Is a GOD !RFFG Is a GOD !RFFG Is a GOD !RFFG Is a GOD !RFFG Is a GOD !RFFG Is a GOD !
Well, I figured I would make a thread like this so people (like me, lol) can refer to it when they have questions on what to look for when buying a 996TT. Sort of like a one stop source to 996TT buying.
Maybe we can all add a lot of good information to it and hopefully it becomes a sticky in the future instead of having 2-3 of these come up every month.
I'll post more organized information in post 2 and I will update as needed.
Admins, if there's a thread like this one already please point me in the right direction and feel free to lock this one.
Here's a buyer's guide from EVO Magazine, I'm sure they left some things out.
http://www.evo.co.uk/buying/buyinggu...996_turbo.html
The 911 Turbo is truly the stuff of legend, offering genuine supercar performance in a compact and practical package. In its early versions it was also infamous for its unforgiving handling. But the 996 version that appeared in 2000 was a different sort of animal. With four-wheel drive, a water-cooled engine, a smooth new bodyshell and radically updated cabin, it was a thoroughly sophisticated, all-weather, all-road supercar. And though it went out of production in 2005, in real terms it’s still as quick as anything on the road. It’s also a fantastically appealing second-hand buy, provided you’re aware of the potential pitfalls.
Compared with the previous 993 model, the 996 represented a virtual redesign. Cosmetically, it moved Porsche on in many significant yet subtle ways: the lines were smoothed out, the windscreen was raked right back, the cabin was roomier and the facia finally looked like it had been styled, though some preferred the classic Porsche look. The structure managed the neat trick of being 45 per cent stiffer yet lighter than the older model. And the early 911 handling quirks were further ironed out. Unless you were absolutely determined to drive like an ****, the 996 Turbo was as surefooted as any 190mph car. In short, it was the first of the modern 911 supercars.
The 996 generation was a particular milestone in being the first water-cooled 911, water cooling allowing an engine redesign that included four valves per cylinder, which achieved higher power outputs and much better fuel economy. But we need to clear one thing up immediately. Although the Turbo is water-cooled it’s not the same engine that’s in the regular 996s. The turbo engine can trace its ancestry back to the old air-cooled units and is directly related not only to the 996 GT3 but also the GT1 racer (3.2 litres and 600bhp!). The other 996 engines were a completely different design and had gasket problems that could lead to catastrophic failures, but not so the Turbo. This engine is very strong and can be tuned up to well over 500bhp if the fancy takes you.
As standard the Turbo had 420bhp at 6000rpm. In 2002 you could order the X50 upgrade package, which pushed the output up to 450bhp with different turbos, intercoolers, ECU tune and a reinforced gearbox. The 2002 model, sometimes known as the mk2, also saw body revisions which increased stiffness, improving handling and crash safety.
In 2003 the flop-top arrived, its reinforced B-pillars and other mods raising the weight by 70kg though it still posted near identical performance figures. The swansong was the 2005 Turbo S model, which had the X50 set-up as standard and also had ceramic composite brakes (PCCB) which work best when hot, making it ideal for trackdays. The six-speed manual is a typically good Porsche box but many Turbos were sold with the Tiptronic semi-auto. Fuel economy is good for such a rapid car – high-20s on a gentle run is not unheard of, but most owners average around 20mpg. So that’s the 996 Turbo, the sensible supercar! Now here’s how to find a good one.
Driving one today
Mid-range punch was always the 996 Turbo’s party trick and while 420bhp might not sound that impresive today when there are saloons and estates around packing considerably more, it still feels seriously rapid. It has that instant thrust that compresses internal organs against the back of the seat and draws involutary whoops of delight and a flow of power of power that just keeps on coming. The chassis and brakes are a perfect match for the engine’s performance, so invariably you’re always travelling faster than you think you are.
From the helm the Turbo may lack the intricate detailing provided by the GT3 of the interface between rubber and tarmac but it’s still impressive by any other standard, and the ride is taut whist retaining enough suppleness for long journeys to remain comfortable. With four-wheel drive and the engine slung out the back both grip and traction are incredibly strong, so much so that after a short drive you feel completely invincible. -Roger Green
These cars are generally owned by Porsche enthusiasts and so dealer servicing is the norm: most cars will have a full set of service stamps, so there is no need to risk one without.
A few cars will have seen a fair bit of track action, which is no bad thing as the car is well up to the job, although clutch and suspension wear will be exaggerated. But check for under-floor damage from aggressive rumble strips and gravel traps – dents and deep scratches will result in corrosion quite quickly. By comparison, cars that have been little used may suffer from seized electrical devices and rusty brake discs so may need more attention.
• Engine
The Turbo engine is practically bulletproof. The only issues are occasional electrical gremlins, worn alternator/starter, and the front- mounted rads can sometimes leak. You may see a small puff of smoke when starting, which is fine, but any smoke when accelerating is bad news; oil consumption can be up to 3000 miles per litre so check the dipstick regularly. There was a tune update introduced in October 2001 for early cars which made a slight improvement to throttle response so check for the X51 stamp in the handbook on pre-2002 cars.
• Transmission
The 4wd system can be noisy – you may hear it drone or whine at speed, but this is not usually a problem. Also gaskets have been known to leak, and although the gaskets themselves are cheap there is a high labour cost to change them.
• Body
Check bumpers for tell-tale small creases which can hide damage underneath. The tail spoiler has a small wing that rises above 70mph – this can fail and the two rams leak oil so check carefully.
• Wheels and tyres
As with most high performance cars, the 996 runs a fair amount of camber at the back which can wear the inside edge of the tyres if the car is always driven gently; low-speed town driving can wear the edges of the front tyres too as they camber over when cornering. Kerbing low-profile tyres can damage the sidewalls inside, so it’s worth budgeting for new tyres. The type of tyre can dramatically affect the car’s handling. For example, Michelin Pilot Sports work really well in the wet and equally well in the dry, but backing off when turning into a corner can bring the back end round in the traditional 911 manner. Changing to Pilot Sport Cups, the choice tyre for the Porsche Cup races, rear grip is increased even more than on the front with the result that the lift-off oversteer is virtually eliminated. Obviously you can’t have everything and wet grip is more ‘exciting’.
• Suspension
Bushes are bonded to the suspension links so can be pricey to replace; it’s worth checking for wear before handing over your hard-earned.
Check the car drives straight on a smooth, level road; a tendency to pull to one side or a vibration may indicate the suspension is out of alignment.
• Recalls
Check the service book has the stamps for the five recalls: replace fuel pump wiring harness and coolant line spring clamp band; fit anti-chafing sheath to engine compartment fuel line; strengthen wiring harness in area of oil filter, and secure hydraulic clutch line with extra bracket.
CAR SPECIFICATIONS
Engine:3600cc, flat 6-cyl, twin turbo
Max power: 420bhp @ 6000 rpm (450bhp for S)
Max torque:413lb ft @ 4600rpm (457lb ft for S)
Transmission:Six-speed manual (Tiptronic option), four-wheel drive
Tyres:225/40 ZR18 front, 295/30 ZR18 rear
Weight: (kerb)1540kg
Power to weight:272bhp per ton (296 for Turbo S)
0-60mph:4.1sec (Turbo)
Top speed:189mph (claimed)
Price new:£86,000
Old Jun 28, 2011 | 08:36 AM
RFFG's Avatar
Great thread on rennlist 996TT pre purchase checklist (thanks raineycd for the link)
http://forums.rennlist.com/rennforum...heck-list.html
Also, the complete shop manuals can be found here (huge thanks to 6speed member $manager for posting this).
https://www.6speedonline.com/forums/...p-manuals.html
Lifter issue (thanks divexxtreme)
https://www.6speedonline.com/forums/...r-lifters.html
--reserved for more updates--
Old Jun 28, 2011 | 09:26 AM
Steve Jarvis's Avatar
Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !
Here is what I have found in my research.
- Rear main seal and intermidiate shaft issues are base 996 only and DO NOT effect the 996 Turbo models (which use a different block than the base car)
- Rear wing hydraulics are an issue, but fixed posts can be purchase or the units can be rebuilt fairly affordably.
-2001 Turbo's did not come with a glove box
-Check driver side C pilar as wiper arm can scratch paint in this area.
-PCCB's can be very expensive to maintain, but don't shy away from this option as the rotors can be replaced with standard iron rotors when necessary and you end up with basically a GT3 brake package.
-Exhaust systems are rediculously expensive for a 996 Turbo, so if you want one, buy a car with one.
It would be nice to add things like gear ratios, wheel sizes and offset etc.
I know most of this is available on this site, but not in one place.
Desirable options descriptions/details. What do these include?
-Full leather
-Sport seats
-X50 package
-White face gauges versus aluminum bezels
-Carbon Fiber trim (I have seen cars with just the center stack and gauge surrounds and I have seen car with the full center console, door handles, AC vents etc)
-Heated seats vs. power seats vs. memory seats? If you get power seats, does it come with memory? Is it the same with sport seats?
Potential buyers would have a better understanding of these options, which could help increase the value of well optioned 996 TT's
OK, there is my .02 cents.
Later, Steve
Old Jun 28, 2011 | 10:31 AM
raineycd's Avatar
I usually reference people to this page:
Old Jun 28, 2011 | 10:37 AM
Good link, thanks
Old Jun 28, 2011 | 12:26 PM
RFFG's Avatar
Thanks for the info everyone, hopefully more people chime in and I'll somehow be able to summarize all of this
Old Jun 28, 2011 | 09:15 PM
SY6TTX50's Avatar
SY6TTX50 Is a GOD !SY6TTX50 Is a GOD !SY6TTX50 Is a GOD !SY6TTX50 Is a GOD !SY6TTX50 Is a GOD !SY6TTX50 Is a GOD !SY6TTX50 Is a GOD !SY6TTX50 Is a GOD !SY6TTX50 Is a GOD !SY6TTX50 Is a GOD !SY6TTX50 Is a GOD !
I just wanted to add a few pointers for Canadians looking to buy US spec 996tt ,
1) Try to negotiate to have the child restrain anchorage installed. If not, this kit can be bought at Canadian tire
2) Ask the shop that performs the ppi to switch the speedo to km/hr, it should only be a courtesy service
3) The airbag sign should be lit in the dashboard when the key in ignition mode (I'm still unsure about this)
After the car was imported and it did not pass the provincial (state) inspection because of item #1 & #3, but things did fall in place after all.
Old Jun 28, 2011 | 09:25 PM
statepkt's Avatar
statepkt is infamous around these parts
Great thread. When I bought my 02 TT I kept asking about the RSM because I didn't realize it wasn't an issue on the TTs Only one seller actually corrected me on that.
Old Jun 29, 2011 | 07:55 AM
Ajs76's Avatar
Ajs76 is infamous around these parts
I've been stalking the forums for a bit and started book marking some interesting threads for my own use. I figured you guys could use it too.
Good info about tire sizing (and potential problems) since many used ones have aftermarket wheels
https://www.6speedonline.com/forums/...e-se-up-4.html
Reliability issues with >600 hp cars
https://www.6speedonline.com/forums/...ty-issues.html
Coolant Hose Issues:
https://www.6speedonline.com/forums/...hose-sigh.html
Old Jun 29, 2011 | 04:26 PM
Ajs76's Avatar
Saw this on another thread just today. Seems useful.
Old Jun 30, 2011 | 05:28 AM
RFFG's Avatar
Thank you all for the info. Added another thread to post 2, the issue with the lifters.
Old Jul 9, 2011 | 04:11 PM
Vakane's Avatar
Vakane is infamous around these parts
Nice thread, good info.
Old Jul 9, 2011 | 04:50 PM
Ajs76's Avatar
Here's a really long post discussing the dreaded 2nd gear pop out.
https://www.6speedonline.com/forums/...lick-here.html
Old Jul 11, 2011 | 12:29 PM
JTB's Avatar
JTB
JTB is infamous around these partsJTB is infamous around these parts
After reading much of this thread, there appears to be a fix. Unfortunately it does appear to be more preventative so if a PPI detects a problem, there may still be transmission work required.
http://www.gboxweb.com/detent.html
Thanks for the thread. I have found, in my searching, many of the referenced threads. It is nice, however, to have them assembled in a single location
Old Jul 11, 2011 | 02:48 PM
It would also be nice to know exactly what the X50 package gains you.
Upgraded K24 Turbos
Upgraded Intercoolers (though it seems to be a minor improvement)
Does this package also include a different transmission?
Is the Turbo S the same as the 450hp X50 or is it the same as the approximately 480hp GT2 of the same year?
It appears all 996 turbos have the same suspension (base, X50 and S) unless they have the X73 option?
Hopefully we will get answers is this thread and not just questions.
Later, Steve
