DAS Roll Bar fitment issue
Old 06-28-2011, 03:03 PM
rossignol24's Avatar
rossignol24 will become famous soon enoughrossignol24 will become famous soon enough
I purchased a new DAS roll bar from DAS a couple weeks ago. I tried fitting it last nite but the rear flanges that bolt to the rear strut tower aren't wide enough... The flanges rub against middle electronic board so the flange can't sit perfectly on top. I measured around the flange to the strut tower and the angle is right but just not wide enough.. Have any of you guys ran into this proble? I don't think it be any different because it's a gt2..
Old 06-28-2011, 03:07 PM
DAS isn't getting back to me for some reason, It's either cut little part of the flange on each side or notch out the metal board where it sits. But it's bolt in idk why I'm having this problem
Old 06-28-2011, 03:20 PM
IAPorscheDoc's Avatar
IAPorscheDoc has a reputation beyond reputeIAPorscheDoc has a reputation beyond reputeIAPorscheDoc has a reputation beyond reputeIAPorscheDoc has a reputation beyond reputeIAPorscheDoc has a reputation beyond reputeIAPorscheDoc has a reputation beyond reputeIAPorscheDoc has a reputation beyond reputeIAPorscheDoc has a reputation beyond reputeIAPorscheDoc has a reputation beyond reputeIAPorscheDoc has a reputation beyond reputeIAPorscheDoc has a reputation beyond repute
It has been a couple of years since i have installed a das bar, but have you tried removing the two nuts to the metal plate and pulling it up out of the way, drop the bar in place and get that installed, then install the metal plate back in place last?
Old 06-28-2011, 03:23 PM
That's definitely an option I just didn't want to mess with that metal plate.. dumb question but what does it hold.. stereo equipment
Old 06-28-2011, 04:48 PM
FAST FWD's Avatar
FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !
The plate holds the engine ECU on the passenger side.
I had the same issue, and just removed the plate and sliced off the corner with tin snips.
Jon
Old 06-28-2011, 05:59 PM
joetwint's Avatar
joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !
+1 Thats how you do it...
Old 06-28-2011, 06:47 PM
Thanks guys! I just finished.. I ended up just slipping the flange underneath the metal plate and putting all the screws back in other than the one on each side because plate was elevated.. It's rigid enough it's not going anywhere
04-28-2022 12:38 AM
Vellano Wheels
Other British Cars
11-25-2015 08:57 PM
The Oss
08-24-2015 08:19 PM
markski@markskituning
08-24-2015 10:07 AM
TrackOne
08-20-2015 12:56 PM
Quick Reply: DAS Roll Bar fitment issue
