First Track day, pads needed?
Old Jul 12, 2011 | 10:14 PM
ra996tt's Avatar
ra996tt is infamous around these parts
Hello friends,
Now that I have the dragstrip, autox and other mexican activities out of the way, I am going to be attending a test and tune at a fairly fast track in about two weeks. I was wondering if changing just the fluid to motul rbf600 and upgrading to gt3 brake ducts would be sufficient for a novice group runner like me. If not, I was going to go with carbotech xp10/8's. Any other advice would be appreciated for a newbie
Mods are as follows:
EPL Flash, straight pipes, BBM ssk, Advan Neova AD08's.
Old Jul 13, 2011 | 06:48 AM
seth_horwitz's Avatar
seth_horwitz Is a GOD !seth_horwitz Is a GOD !seth_horwitz Is a GOD !seth_horwitz Is a GOD !seth_horwitz Is a GOD !seth_horwitz Is a GOD !seth_horwitz Is a GOD !seth_horwitz Is a GOD !seth_horwitz Is a GOD !seth_horwitz Is a GOD !seth_horwitz Is a GOD !
For your first day, I think the stock pads are fine as long as they are in good shape. You won't be pushing the car anywhere near its limits, in my opinion. (I know I didn't.) I have a tech inspection sheet from my last track day that I can probably dig up and send to you, if you want, that details the procedures that needed to be done for them to deem the car safe. (I'm told that these guys are oversensitive when it comes to safety, which is fine in my book. They've been known to black flag guys on the first lap for driving stupidly, sending them packing.)
Old Jul 13, 2011 | 09:23 AM
Etchhead's Avatar
Etchhead has a reputation beyond reputeEtchhead has a reputation beyond reputeEtchhead has a reputation beyond reputeEtchhead has a reputation beyond reputeEtchhead has a reputation beyond reputeEtchhead has a reputation beyond reputeEtchhead has a reputation beyond reputeEtchhead has a reputation beyond reputeEtchhead has a reputation beyond reputeEtchhead has a reputation beyond reputeEtchhead has a reputation beyond repute
Agree- stock worked great for me first few DDs. Good call in the ducts and fluid change.
Have a great time, buy it's super addictive!
Old Jul 13, 2011 | 09:24 AM
i ate stocks in one track day
#TeamAIM
Old Jul 13, 2011 | 09:34 AM
z06801's Avatar
z06801 has a reputation beyond reputez06801 has a reputation beyond reputez06801 has a reputation beyond reputez06801 has a reputation beyond reputez06801 has a reputation beyond reputez06801 has a reputation beyond reputez06801 has a reputation beyond reputez06801 has a reputation beyond reputez06801 has a reputation beyond reputez06801 has a reputation beyond reputez06801 has a reputation beyond repute
Brake fluid for sure! Castrol SRF and be prepared to go back for more its very addicting
Old Jul 13, 2011 | 09:57 AM
Nikolas's Avatar
Nikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant future
The general rule of thumb is to have at least 50% of the pad material and you should be good to go.
Old Jul 13, 2011 | 10:47 AM
FAST FWD's Avatar
FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !
Whether the stock pads are adequate depends a lot on you. These cars are fast and heavy, so they do tax your brakes. Newbies tend to be harder on brakes than more experienced drivers, because they tend to use them more to over-slow their cars. In any case, definitely change to fresh fluid. I use Motul 600, and it works fine for me, and it's a lot less expensive than Castrol SRF.
If you expect to do more DE's, I'd recommend getting Pagid RS-29 (yellow) in front, and RS-14 (black) in the rear. This combination seems to help brake bias.
Good luck!
Jon
Old Jul 13, 2011 | 11:24 AM
rdss's Avatar
rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !
Good luck!
Jon
Jon if you use those pads for tracking,can you change them for stock while you are not tracking ? then put the tracking pads on when you come back to the track.Can you do this back and forth ?
Rolando
Old Jul 13, 2011 | 12:45 PM
FAST FWD's Avatar
Rolando
Hi Rolando,
I leave the RS-29 front pads in, because I have the GT3 calipers and I don't have a set of street pads for them. They are dusty, but don't make much noise in my car. I swap out the rears for stock pads. I just go out and put a few hard stops on them when I swap them back and forth.
No doubt that someone will tell me this is really dumb, but it seems to work fine for me.
Jon
Old Jul 13, 2011 | 12:49 PM
heavychevy's Avatar
Good luck!
Jon
^^^ Do what he says ^^^^
What track are you going to?
You need to check your pad level and make sure there is plenty left. The lower the pad level, the more heat gets into your brake fluid, the softer the pedal gets, the more likely you are to boil the fluid and have a brake failure. Especially in the summer time when it's likely to be hot. (Been there)
As Jon says, as a new driver you will likely be harder (meaning pressing as hard, but longer and over slowing for the turns which kills brake pads and builds lots of heat, which stockers are helpless against).
Rolando
Yes, only takes about 15 minutes to swap out the front pads once you get used to it. But I doubt you need to with yellows (unless they squeal too much on the street for you, mine don't squeal at all). I would bet Yellows might last the life of the car on the street (no matter how many miles). Those things are beast!
But going back to stock is no problem, probably switch the whole set in under an hour (taking off and putting on wheels included).
Old Jul 13, 2011 | 02:53 PM
rdss's Avatar
Hi Rolando,
Jon
Thanks Jon,i'll do that....change both.
Old Jul 13, 2011 | 02:55 PM
FAST FWD's Avatar
+1
Once you have done it a couple of times, it will take you max 15-20 minutes per side (front and rear). Even faster if you have one of those TraqJunk gadgets to compress the spring holding the pads.
I have a little chunk of rubber that I cut from a truck mudflap that I put on the outside of the caliper and then use a pair of channel lock pliers to push back the pads.
Old Jul 13, 2011 | 03:18 PM
rdss's Avatar
Thanks HEAVYCHEVY ,do the yellow ones last as long as the stock doing tracking and street ?? I don't care the noise.
But going back to stock is no problem, probably switch the whole set in under an hour (taking off and putting on wheels included).[/quote]
Old Jul 13, 2011 | 03:35 PM
ra996tt's Avatar
Good luck!
Jon
Thanks everyone. I do tend to drive like a madman, so I will probably change my earlier decision and end up with track pads. Anyone have experience with Carbotech XP10's? They are a lot cheaper and about the same temps as pagid yellows. I have heard good things about them. As well as ATE brake fluid. Thoughts?
Old Jul 13, 2011 | 05:55 PM
FAST FWD's Avatar
No experience with Carbotech pads.
Ate has a lower bp than Motul, and they are almost the same price. I'd strongly recommend the Motul instead.
Jon
