Warm start, air con on and engine off sometimes...
SubscribeLooks like a MAF issue? It only happens on the engine is not cold, probably after dinner or got off for a while, start car, air con on and run, rev may drop to off. But then turn it back on, run first maybe 5 second, in order to turn on the air con, it is fine. Any idea? Thanks.
Not a MAF. Clean your throttle body with some started fluid first. It is free and a dirty throttle body can cause wierd things to happen. If that doesn't help I would check for vacuum leaks.
any of you have a LWFW?
disconnect the positive from the battery for a few minutes then see if the car turns over...
Quote:
I have stock flywheel with stg2 clutch. What does disconnecting the battery point to? I'll try this out tomorrow.Originally Posted by MARKSKI@911tuning
resets itself... clears soft codes etc... check underneath and see if the black colors o2s are closer to turbos... and see if they are connected on top......
Quote:
It shouldn't be because the SAI pump shouldn't be running on warm start IIRC.Originally Posted by boyg
Besides, I have the secondary air injection code (P0492), but I believe they are not the same case right?
Here is a video of exactly what happens to my car. Warm start after about leaving it for 1 hour (dinner). Took this video just a few hours ago. Every shop I have spoke to says this is hard to pinpoint and can be many things...expect to pay 5-10 hrs for trouble shooting.
So I am think I mine as use that money to replace my alternator and get the TB cleaned. Looking at the video it looks like my voltage reading is low which causes the car to stall?
http://www.youtube.com/watch?v=Pr25KyyjynA
Tags
6speedonline, 996, air, aircond, con, condition, engine, hard, hot, leak, powered, stall, stalling, start, turbo, vacuum, vbulletin, vehicle
- FS MA USA 2002 Subaru WRX STI RASpec Impreza time attack / road race car
- Vivid Racing : Fabspeed Performance Packages for 991 Carrera.
- Vivid Racing :Armytrix Super Sport Performance Exhaust Porsche 997 Carerra | S
- 1965 Chevrolet Corvair YENKO STINGER Stage 1
- :: ECS Tuning :: ROW Air Box Kits For Your M156 Engine
