TT AWD H&R Spring install help?
Old Sep 4, 2011 | 09:59 PM
nick49's Avatar
nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !
I'd like to put H&R Sport springs on that reduce the ride height by about an inch. I have the springs, a spring compressor, tools to separate the front strut nut from the shaft, jacks, etc.
I'd like to know the easiest and most straight forward approach to removing and replacing just the springs. I have no instructions. Will I be able to remove the springs from the struts without removing the struts first?
Any help would be much appreciated. I've seen pics of removing struts from a C2, but it's not quite the same with front axles that limit the amount the hub can be dropped.
TIA, Nick
Old Sep 5, 2011 | 10:43 AM
Paseb's Avatar
Paseb is infamous around these parts
nope you can't
i have an 03 c4s and its pretty much the same
you have the remove the entire strut to change spring
from what i remember when i did last year
front:
remove wheel
remove calipers and zip tie them
remove sway bars and drop links from strut
disconnect drive shaft from diff
remove top 3 mounting bolts
disconnect brake sensors from strut
remove the strut bolt from body
the hardest part is to remove the strut from his hole
you have to pry down your hub and rotor with your foot and pass the strut under the fender, be careful it will rub, so use blanket
you will pass 1 bolt, than a 2nd and finally the third,
patience and strengh is the key lol
not the best explanations and sry for english mistakes, but you got the stuff
as for the rear, pretty much the same thing
i had to use a big piece of wood under the hub to be able to remove the bolt from the rear shock
good luck and dont forget you need alignement after
offtopic:
i installed bilstein sports and h&r spring by myself, took lot of times for a first timer job, but im sure you can do it
last week, ive installed bilstein and eibach kit on my dad's cayman s, and i will remove them cause i just bought him jic coilver, couldnt pass this deal lol
almost same procedure
porsche are nice to work on, always a pleasure to mod them by yourself
Old Sep 5, 2011 | 10:57 AM
TT996-2002's Avatar
TT996-2002 is a jewel in the roughTT996-2002 is a jewel in the roughTT996-2002 is a jewel in the roughTT996-2002 is a jewel in the rough
There is a much easier way. I did a write up on it. Call me and I will guide u through
8502175003
Old Sep 5, 2011 | 11:02 AM
Paseb's Avatar
8502175003
why dont you post it, so that everyone can read and learn
my way is from other write up took in rennlist/renntech
Old Sep 5, 2011 | 04:13 PM
TT996-2002's Avatar
It is posted if u would just look. The last time I posted it everyone had something to say negative.
Everyone with a keyboard is now a mechanic. Lol
Old Sep 5, 2011 | 04:56 PM
Paseb's Avatar
dude you sound like a jerkass,
just helping out this guy the best i can,
i dont care to look at your thread, and if everyone is saying bad things about it, then there is a reason. you should just stop doing mechanic.
now gtfo
Old Sep 5, 2011 | 06:47 PM
teflon_jones's Avatar
teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !
If you want the repair manual that you can reverse engineer on how to replace springs and struts, I can email it to you. I only have it locally on my hard drive and it's 44+ meg.
Somewhere I have the actual good instructions from somebody that did it, but I can't find them for some reason!
Old Sep 5, 2011 | 06:50 PM
nick49's Avatar
Guys, please let's all just get along!
I appreciate you all trying to do anything to help me and any others that are reading this to do a job. Like anything else, there's more than one way to skin a cat and it's up to the person doing the task to decide which is the best and easiest for him.
I thank you both and I welcome any other ideas. I have a lot of mechanical skill and wrench for a living, mainly scratch building custom motorcycles and hot rod motors. I don't enjoy wrenching on my own vehicles in fact I actually can't stand it, I'd rather be hiking or climbing or riding my GSXR.
But the kicker is I'd rather wrench on my own stuff than pay way too much to have someone else break several things along the way and end up doing a poor job at that. Happens everytime, from an oil change on my Jeep, to the Lexus dealer do a warranty fix on the old ladies cage.
Peace!
Old Sep 5, 2011 | 06:51 PM
Paseb's Avatar
i also have the instructions somewhere,
i just throwed to the guy some stuff he has to do,
its not in order at all, i just write down what i remember when i did 1 year ago
i dont see any problem
Old Sep 5, 2011 | 06:53 PM
nick49's Avatar
Thanks, I have the 996TT service manual that I downloaded from this site, but maybe I looked in the wrong area. I didn't find any helpful info there as to a step by step disassy.
Is what you have different?
cnebrask
Oct 3, 2024 08:19 PM
MadWhip
Sep 3, 2015 02:04 PM
Regent
Aug 21, 2015 11:14 AM
